Project: QbiX Water Cooled \o/ (aluminium cube)
Discussion in 'Project Logs' started by The_Resetter, 28 Mar 2004.
  1. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Right I dint mod for 2 day’s because I just got my drivers licence, so I had to pick up my mate and go to the mac drive. (golden moments :p )
    I still needed some stuff, so I got into my car :hehe: and whent tho the local hardware shop.
    With the nice weather the dwarf rabbit of my sister is loose in the backyard, the temptation was hard to resist but I dint mod him in the end.
    The mitre box works like a charm. :D
    The bottomplate is the only plate where ill be putting in pop rivets, cant see it anyway when its on the ground :p
    Closeup rivet.
    And the whole thing with evrything in place, it was a bit dark and the cam dint make a nice picture, not even with the flash on. :confused:
  2. Providence
    Providence What's a Dremel?
    23 Jan 2004
    I wear my "No I will not fix your computer" shirt whenever I mod too :D
  3. The_Resetter
    6 Oct 2003
    casemoddin geeks like us need to keep our reputation on every photo. ;) :p :naughty:
  4. The_Resetter
    6 Oct 2003
    Aaaigt some new pix
    So time for a quick tutorial :p to make a baseplate.
    First get 4 pieces of alu and saw it in the mitre box.
    Then mark the places for the holes.
    Then just whack in a centerpoint for your drill and convenience ;) :hehe: then just drill the holes (duh)
    And u end up with this :D
    After that its just a matter of tapping in some screw wire or put in some pop rivets.
    A lot of work but well worth it as u can see :D :lol:
  5. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    lmao sweet man
    Better call the animal abuse line now :eek:
  6. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    If the mods don't kill you for that huge sig, I will hunt you down and do it myself :p
    Nice mod there sir, kind of reminds me of an xbox sorta... :thumb:
  7. The_Resetter
    6 Oct 2003
    Yea that sig is amazing I want one of those to :p
    And I've head that before :rock:
  8. The_Resetter
    6 Oct 2003
    I kinda noticed their werent to many reply’s in my thread, what do I have to make to get you peepz wild ;)
    Todat it was time to mount some plexi into the frame. ;)
    I marked some holes and started drilling.
    Then just clamp a piece of plexi behind it, mark it and drill it sloooowly.
    Then I made a little hole for the fan, I did this using my 7 hole saw in my faithful Bosch handdrill ;) :hehe:
    Actually I find it a small wonder that it went right the first time without breaking the pexiglas :p :naughty: :lol:
    /me placed a sidepannel just for the fun of it, u can see its getting shape a bit ;)
  9. Langer
    Langer Jesse Lang
    24 Jan 2004
    extremely well done... and i dont know how you resisted the temptation to "Mod" the bunny, you are clearly a very patient man.
    I love the look of the side panel, hard work pays off.
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Mod the bunny! Mod the bunny! :rock:
    Cool project so far. Love the rivets and the alu/plexi combo.
  11. naelq
    naelq What's a Dremel?
    14 Oct 2003
    it's getting really hot! :rock:
  12. Sc0rian
    23 Feb 2003
    hehe
    Yeh i know, I changed it. I just wanted a big sig for a day...Felt like i should stand out :sigh:
  13. Yo-DUH_87
    6 Mar 2002
    hehe, the title "Banned/Suspended" would make you stand out a lot :p
    Looking great man!
  14. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    ah, nice update =)
    do you use a battery-powerd drill for all tyour work? even for the ****load of holes you've just drilled?? =) if so, respect for that lol ;)
  15. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    Nice alum. work. Looking forward to seeing this one progress along. GJ.
  16. The_Resetter
    6 Oct 2003
    Hell no, only the ones I cant reach with the drillpress (if thats the correct word)
  17. sojumk
    sojumk What's a Dremel?
    11 Sep 2002
    wow an amazing job~ well done
  18. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    how thick are those sheets of alumium, i hade some 1/16 and it cut fine with a few passes of a razor blade with a super clean edge
  19. STellY
    STellY What's a Dremel?
    24 Aug 2003
    wpw this mod is looking extremely nice.... i can tell it will end up good.... good work so far, i'll be watching closely
  20. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    i absolutely love what you are doing for the case. you seem to be taking your time, not rushing into things, so your not making constant mistakes. AWESOME! job on the sides. I hope the updates will be just as nice as they have been
