Project: QbiX Water Cooled \o/ (aluminium cube)
Discussion in 'Project Logs' started by The_Resetter, 28 Mar 2004.
  1. magicpixel
    magicpixel What's a Dremel?
    11 May 2004
    :thumb: Damn this looks good! All that hard work is defenatly paying off!
    Mod on man,... mod on :thumb:
    I'm going to follow this one. :D
    Cheers,
    Chris.
  2. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Yes 2 leds on 1 transistor.
    No i got it from someone else,
  3. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    damn sweet mod
  4. The_Resetter
    6 Oct 2003
    Hurraaaaaaay he’s back again \o/ ;) with some serious moddin ;) :p
    In my pc are some HDD’s pretty obvious but those things make some noise that’s because its passes its vibrations onto the case, so I needed an HDD suspension.
    So I did my magic on some aluminium, measured a bit, drilled a bit, bended some, and presto Resetter got’s himself a cewl HDD rack.
    I precent you, The HDD rack :naughty:.
    Bended corners \o/
    Then mix in some paint :D :p
    You take some eheim pump decouplers, and add them to your rack, and voilà you have yourself a nice anti vibration rack.
    Real simpel but verry effective, i cant even hear those disks anymore.
    Sweeeeetaaaa :dremel:
  5. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Looking good, but who has 4 hard drives?
  6. Jedateach
    Jedateach What's a Dremel?
    22 May 2004
    its a server .. isnt it?
    he could be flash and have some sort of fancy RAID array
    or he could just be planning ahead :D
    MOD ON MAN :dremel: :dremel:
  7. The_Resetter
    6 Oct 2003
    No its not the server, read the first post again ;), but my normal rig just has 4 hdd's 4x 120 gig of witch 2 SATA in raid 0
  8. The_Resetter
    6 Oct 2003
    Time for that reservoir ;)
    I welded the top on, and added some holes so i can use it as “window” in the case.
    Then I added some UV colouring to check for any leaks, none \o/.
    But I wont be using UV green, instead its going to be UV red.
    And the final shot, the reservoir on my last casemod made of plexiglas, Project Plexicus iLLuminati.
  9. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    omg im in love wit that res
    might i be able to presuade u to make me a res for some $bling bling of course
    and were did u score the beveled plexi? :naughty:
  10. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    OW!!! omg that looked painfull! Man im afraid to work on my comp now!! Was super worried about that when i was cutting out my frame. Its my worst night mare relized! Course my saw was just about crotch level while i was working!
  11. The_Resetter
    6 Oct 2003
    I was playing around with some stuff I got from my sponsor, whilst I was testing my home made solid state relay, I accidentally pulled a lazer leds close to the reservoir, I was pleased with the effect, what kind of effect I hear you say, well just read on and find out.
    The lazerleds itself has a chromed plastic cover, obviously chrome wont stick to my Plexiglas reservoir ;)
    So I sanded the bottom of the lazerleds to the bare plastic so I could weld it ok with chloroform.
    Before.
    After some sanding a nice and flat surface.
    Just lay them out on the reservoir add some chloroform, and those b!tches wont come off for a loooooong time ;) :p
    Do note that I’m temporarily using UV green dye, when I’m finished it will contain UV red dye
    And here is the effect, ill let the pictures do the talking for me :).
    Top of the water.
    :D:D:D:D:D:D:D:D
  12. Goblin Tinkerer
    24 May 2004
    WOW!! That looks awsome! How did you get those bubbles? Are they always in a liquid cooled system? Or do you need somthing special for em?
  13. The_Resetter
    6 Oct 2003
    As u might have noticed their are some holes around the reservoir, and their there for a reason, I mentioned before I wanted a water reservoir / window.
    And it turned out to be just that, the end result is stunning, if u ask me.
    Some measuring and predrilled some holes.
    And after 10 minutes of handsaw action, I end up with this.
    And some filing around the edges to smooth everything.
    Closeup corner.
    And brushed, here without its protective layer of lacquer so away with those greasy fingers :p :p :naughty:
    And after the lacquer.
    Don’t mind the colour, its the results of the lighting in my room :)
    This picture nicely demonstrates the result of some find handwork and craftsmanship ;)
    Shibbyyyyy ;)
    Ill mount the reservoir in a few hours, ill update u with it ASAP :D
    Hope you enjoyed this part of the log, the case is coming together bit by bit.
  14. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    :jawdrop: Gorgeous... absolutely gorgeous! (your mod's not bad either ;))
    Am I right in thinking those thin lines in the water are just because the camera was set to a long exposure when you took the picture? Or is there something in your water? :worried:
  15. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    that resivour is just breath taking, I mean OMG beutiful effect.
    JEEVES
  16. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    i'm missing something :confused:
  17. coorz
    coorz Miffed
    25 Apr 2003
    That res is simply amazing dude :thumb: . How about another 2 UV lazerleds on top of it.
  18. Ben
    Ben What's a Dremel?
    11 Aug 2003
    dam missed this one.
    looks extremely good, the res is amassing how did you get the water to do that.
    Ben
  19. The_Resetter
    6 Oct 2003
    Yea, because of the extended exposure.
  20. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    Question....
    Hey, been a while since I posted, but d-a-m-n! Resetter, great job on this thing!
    Where did you get these things? (the black standoff things on the screws)
    [hijack] I am in major need of something just like it for my computer case. I need the mobo to standoff. [/hijack]
    Anyways, keep it up. I love the lighting. :) :clap: :rock: :rock:
