Project: Quark
Discussion in 'Project Logs' started by buchans, 23 Aug 2004.
  1. buchans
    buchans What's a Dremel?
    28 Jun 2004
    Found an old salvaged server whilst moving flat.... got this way before I got into modding and was planning on binning it but now I see some possibilities :D
    I could do with some suggestions before I start stripping it down. Its going to be a always on downloader/fileserver.
    this really does not convey the scale of this beast
    not sure what to do about these SCSI raid hot swap bays (I think its going to be SATA)
    some of the biggest PC fans I've seen - they make WAY to much noise (planning a budget water system)
    space for 2 PSU easy and many many drives.. I'm planning on a custom drive storage
    monster fans !
    I like the way the case it split - keeps the hot PSUs away from the MB and nice for stealthing wires
  2. drinn
    drinn What's a Dremel?
    16 Jul 2004
    80mm Fans = Monster fans?? :D
    This thread sounds interesting.. :rolleyes:
  3. buchans
    28 Jun 2004
    ok so they sound like monster fans, will be checking tonight.
  4. nem
    nem What's a Dremel?
    25 Feb 2003
    Using the drives as a base for comparrison, it would appear they are 120mm fans not 80mm.
    Just an observation.
  5. Dmc
    Dmc Minimodder
    13 Jul 2004
    Quick observation, where the 3 120 fans are could you fit a thermo3 rad there? now that would be a wicked water setup :D
  6. Le Tordu
    Le Tordu What's a Dremel?
    16 Jan 2004
    That could be interesting !
    Bix3 is your friend ! :rock:
    /me like big server cases... good work ! :dremel:
  7. buchans
    28 Jun 2004
    I like that idea :D thats a definite consideration.
    I was planning on including a rad but didn't think there would be one that was quite that perfect
  8. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    That is one huge radiator :jawdrop: :jawdrop: :jawdrop:
    I might just have to think about that for convergence :D
  9. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    That radiator might be HUGE but it doesnt mean it performs better then the black ice extreme 2 2x120mm fan :hehe: pwned
  10. LF Hazard
    LF Hazard What's a Dremel?
    29 Jul 2004
    i think this rad has 3 120mm fans on it
    correct me if im wrong
  11. Go4t
    Go4t i
    13 Dec 2003
    yay another massive server case mod :thumb:
    whats the specs of whats in it?
  12. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Big is beautiful :D
  13. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Nice case with lots of potential :thumb: .
    However, Ideas/Plans/Pics of unmodded cases belong in Modding as per the Project Logs Rules. When you have started modding work on it and posted the pics, let an admin or moderator know and we'll move it to Project Logs.
    Good luck with it all and I look forward to seeing what you do with the case! :dremel: :)
  14. buchans
    28 Jun 2004
    sorry! & will do
  15. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    I will be following this one with great interest....these big @$$ server cases allow for so much creativity, and this one has a LOT of potential.
    Paint job? Window mods? With the size of that thing, you could actually put in a real window! (note: not an actual recommendation)
    With all the extra space and such a pimpin' rig, how about some fuzzy dice hanging from the ceiling? :hip: (that actually IS a recommendation)
  16. buchans
    28 Jun 2004
    Stipped it all down..... there is way more space than I had hoped for :D
    Anyway my first decision, I would like to reuse the PSU (nice removable connector unsure of its rating but its not likely to be too low as it a 120mm fan!)
    Maybe someone can help clarify (before I start checking with a meter) if PSUs always have the same volts on the same colours? I hope so as its prob. worth salvaging.
  17. Dmc
    Dmc Minimodder
    13 Jul 2004
    That should be some big @$$ psu cause it could run how many scsi H/D plus cd-roms and all the fans in the case
  18. Go4t
    Go4t i
    13 Dec 2003
    wow that looks like it has 4 atx connectors
    the voltages wont tell you how many watts it produces, your best bet would be to look around online for the model number
    btw dell has a habit of rearranging the pins on atx conectors
  19. buchans
    28 Jun 2004
    The PSU can cope with 6 HDs, 4 CDROMS and a dual pro MB :thumb: many hours of work it rewire it tho... right now I think it will be worth it :dremel:
    does anyone have any feedback on these... "Cape Coolplex 50 extern" Res
    I will fit (just) I really like the look
  20. buchans
    28 Jun 2004
    some progress:
    - stipped down and rivits removed for painting
    - del PSU is way to non-standard, considering replacing it even though its 700W
    - got the plexi (mirror and transparent)
    - 70% case design complete
    - building drive mounting cage
    I have this current spec: I'm not sure about the WC components
    MB : Abit AN7 Guru nForce2 Ultra (10/100 LAN, USB 2.0, 1394, 6Ch Audio, SATA, Raid)
    CPU : AMD XP 2500+
    RAM : 512Mb DDR PC3200
    STORAGE : 2xSATA (120Gb Seagate Barracuda) 4xIDE (200Gb Maxtor, 200Gb Western Digital, 90Gb Seagate, 20Gb IBM 2.5)
    VIDEO : XFX GeForce FX5500 256MB TV DVI
    COOLING : CPU-Cuplex Rev. 1.3 S462B Cuplex GPU-Undecided CHIP-Twinplex NB PUMP-Eheim 1048 RAD-Black Ice Pro II Dual 120mm RES-Cape Coolplex 25 AIR-2x 120mm low db fans (type undecided)
