Scratch Build – In Progress Project: R2-D2 (on a low budget)
Discussion in 'Project Logs' started by Frenkie, 29 Feb 2008.
  1. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    Project: R2-D2
    This is the worklog of my R2-D2 casemod, which is an ultra-low budget project.
    So far I have spend about 120 dollars on it. Let me show you how I did it.
    Basis of this mod is a written-off garbage can that I was told to get rid of. From the internet I gathered pictures of R2, and started my first dremel-cuts, based upon guessing the size*.
    I am making this mod in three big chunks; the Dome, the Body and the Legs. I am building all three simultaneously, so I’ll be jumping from one to another all the time.
    Body.
    The base, an old garbage can, about to be thrown away.
    Let’s get an old PC case from the attic.
    Quickly disassembled.
    And what is left over, a mobo tray and a backplane.
    Hmm, a bit too big. Got to make that a bit smaller.
    From the many pictures of the net, I estimated the length-width ratio, and decided to cut off a big
    chunk. I used this pneumatic tool, sort-off giant air dremel.
    For all you starting casemodders; always wear eye protection. Trust me.
    Also used some ear protection, as the bin was working as a drum.
    That’s off, now the sharp edges.
    Let’s try the tray. I see I have to fold the edges.
    *let me get back to that guessing part. áfter I started, then I came upon Astromech and the guys
    from the R2-builders club. They kindly provided me with the original blueprints of the real R2. I
    found out, my R2 was 75% of the real deal. Also the blueprints were in inches. So now I am
    constantly recalculating the blueprint to 75 % and then from inches to millimeters. :)
    The back, looking good.
    For use as "vents" I dug up these ancient ( 1984 ) grills from speaker boxes.
    Used the dremel to cut the hole for the vent.
    Later on, I see the vents don't stick out at all. I made a small container to hold the fans.
    I made it from Vikureen
    which is a polystyrene.
    My sponsor SpacePromotion provided me with two 60
    mm fans with white LEDs. ( No, It will still be low-budget, not because I get a lot sponsored )
    Hmm... that doesn’t fit because of the extra wires for those LEDs.
    Bit of creative cutting.
  2. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Nice start there. And let me be the first to say: May the Force be with you! ;)
  3. -Nick-
    -Nick- What's a Dremel?
    23 Jan 2008
    haha excellent idea, keep it up (Y)
  4. iwog
    iwog Linux cursed
    14 Jun 2007
    hmmm this looks interesting, lets follow this one.
  5. Frenkie
    3 Jul 2006
    Thanks guys, I am sure that even non-star wars fans ( yes there such people ! )
    won't be disappointed at the end. Let's continue with the next part:
    LEGS.
    A stack of MDF wood and some wood-glue.
    Something like this.
    First cuts.
    Using the workmate and clamps the legs are taking form.
    With some sanding they look now like this.
    Starting chapter three; the DOME
    The garbage bin lid. With the help of the R2-builders blueprints I measured the different panels.
    Good hard stainless steel, nice to cut with the dremel.
    First hole is in; this one is for the RADAR-EYE.
    And these two for the FRONT-DISPLAYS.
    Here with the blueprints, this is very tricky as the measurements are not in inches
    but in degrees, minutes and seconds. :(
    Back to chapter one, the BODY
    On the bottom, there should come a "skirt". I made it from MDF wood.
    First try with a rope and a nail......
    -sorry, one photo missing here-
    OOPS, miscalculated! Not 26 cm in diameter, but only 21. ( yes I forgot the 75 %)
    The skirt sides.
    After this I hollowed out the massive disc and cut out room for two mini CCLs.
    Made several holes in it with a milling machine. ( mill ? )
    Shopping time. Here you see a few mini table stands, two circuits from Velleman,
    spraycans, blue pinstriping and some spectacle glasses.
    More MDF and some aluminum for the support frame.
    Fitting in the case,
    Bolted to the bottom.
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    lol, looking at the bin, i can see why you picked r2d2 as a theme :D
    Keep going mate, we are lurking, looking lovin it and still not posting :)
  7. Frenkie
    3 Jul 2006
    Thanx!
    Made a Rader-eye holder from some MDF.
    Round it off and fitted the eye glass.
    For the two Front-displays I bought two Velleman circuits, originally with red
    LEDs, but I won’t be using those. Instead I bought in Hong Kong a few hundred
    blue and white LEDs for 0.99 Euro per 100 )
    Also from Hong Kong comes this el cheapo xmass lights, 100 white LEDs and
    8 different modes.
    Cost 0.99 Euro.
    A small mini-lava lamp, cost 0.99 euro.....
    It contains a micro circuit that fades three LEDs in and out.
    From Vikureen I made a small container to attach it to R2.
    The guys at Space Promotion gave me this
    ZALMAN fancontroller.
    A rectangular box into a round case...hmm I have to think of some innovation support brackets.
    From a lot of debris I made several little thingamajigs to give the legs more detail.
    Doesn’t look too bad.
    To attach the ankle-cylinders I screwed in a woodscrew and cut the head of it.
    Glue it with construction glue.
    And there it is.
    On the back a larger display, I used some PVC and cut grooves into it to help me
    bend it with the curves of the dome.
    Pre-drilled the LED holes.
    Bended it with a heatgun until it matched the curves.
    Then drilled the final 5 mm for the LEDs.
    Attached a few LEDs, then glued them on and waited 24 hours before I attached the next batch.
    All LEDs in and glued.
    Quite a mess eh ?
    Because it is originally white and blue, I made some blue transparent stickers.
  8. Colossous
    Colossous Minimodder
    28 May 2007
    Great project - loving the improvisation - Xmas tree lights Cheesecake :D
  9. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Thats quite a mess, but it looks worth it.
  10. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    Loving the Ghetto cheapness, but with the good results.
    Will watch this one.
    Good luck!
  11. Frenkie
    3 Jul 2006
    Made some strips of Vikureen for the rectangle parts that come into the round outer layer.
    Neatly follow the lines and break it off. ( the plastic, not the scalpel )
    Also from Space Promotion i got these
    Zalman harddisk coolers.
    At first I wanted to mount them on the bottom.
    Then decided to mount them as high as possible.
    Dremel dremel dremel..... A hole!
    The supports are the same as for
    theZalman
    fan controller
    . ( type QeD ;) )
    Preparing the table legs for mounting.
    Screw them on.
    An old cylinder that used to contain wire.
    Cut in half and measured it.
    Cut out a small piece where the table leg is coming out.
    Spray painted the dome and radar-eye holder.
    For use as a holoprojecter I got this antique webcam, gave it a spray as well.
    made a hole and glued it on.
    From the front.
    An old circuit I use to fill the gaping hole on the back.
    I had plenty of LEDs to spare to I drilled holes in it @ random.
    Glued it inside the dome with some quick and dirty supports.
    Started to glue the LEDs into it.
    When it is on, it glows and tingles a bit like this.
    With Gelly Roll pen's I colored the circuit a bit. With regular light you don’t see anything...
    .....but with some UV on it..... :)
  12. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    wow! that is surely an ambitious project wich is coming up VERY nicely. The low budget is giving u lots of good ideas for improvization.
    Very nicely done. Anxious to see the rest :)
    ooo, very well documented BTW :)
  13. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    Very impressive cheap mod,
  14. mutznutz
    mutznutz Cos Ive got a beard u label me evil
    18 Nov 2007
    Looking good that congrats
  15. ROB 636
    ROB 636 Ski-Ba-Bop-Ba-Dop-Bop
    22 Feb 2008
    I like the UV ink on the board.
  16. rambo
    rambo What's a Dremel?
    14 Mar 2007
    HOLY F*CK that looks realy nice i like R2D2 so i wnat to see how close you can come.
    keep it up ,rambo :dremel:
  17. Jipa
    5 Feb 2004
    What is it with people suddenly making loads of cool mods! Good job, gotta love cheap mods with loads of innovative details.
  18. JesterQ
    JesterQ What's a Dremel?
    15 Jul 2004
    this looks really good . and cheap too !
  19. rodeo45
    rodeo45 Who's your daddy ???
    4 Mar 2008
    That looks cool! Specially that old circuit with UV pen lines on it - WOOW!! Great idea!
  20. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Wow, this looks amazing. You've got some real ingenuity here.
