Scratch Build – In Progress Project: R5 HardDisk External Case
Discussion in 'Project Logs' started by ranlai, 22 Mar 2008.
  1. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Aw, I think it wouldve looked great with some of the acrylic clear, as a see through hole.
  2. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Looking good. I think it would look even better if you made the top piece in three parts (as drawn in the sketchup), and then glued em instead of bending. You'll get a cleaner angle, and since you are painting it the joint wont show. =)
  3. ranlai
    ranlai What's a Dremel?
    20 Oct 2007
    I have same feeling~
    I think that I ought to make an once again with the top piece.
    There is the power supply inside~
  4. ranlai
    20 Oct 2007
    Today working log~very nosie all of day~
  5. ranlai
    20 Oct 2007
  6. ranlai
    20 Oct 2007
    Some EFFECT IN NIGHT MODE~
    But the top side part will make again:wallbash:
  7. Cheapskate
    13 May 2007
    Nice mesh. I have done that kind of stuff BY HAND, so you shouldn't complain about it taking a long time on the CNC.:D
    You make us feel bad!:hehe:
  8. ranlai
    20 Oct 2007
    When the CNC MACHINE is running, I can mak the other parts at the same time,
    But the Chief Axis Motor is out of order when this had used a long time~:waah:
    And estimate that need about $500 to $1000 HK to cahnge the other new one.:wallbash::wallbash:
    At thie month , I have finish a Front Parts ~
    There are so busy at this month, I have working a long time per day more that 10 hours~:duh:
    And I spend for all time to make this toy when I stand at home ~:D
  9. ranlai
    20 Oct 2007
    There're the progress wiht the Front Side Parts.
  10. ranlai
    20 Oct 2007
  11. ranlai
    20 Oct 2007
    Paint thsi~
  12. ranlai
    20 Oct 2007
    I have used the PS-49 SKY BLUE COLOUR wihe the brand od TAMITA~
  13. ranlai
    20 Oct 2007
  14. ranlai
    20 Oct 2007
    At the next hoilday~
    I will start to done the Framwork~
  15. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    sweet :D i like it :D
  16. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Nice work with the project. bummer to hear about the motor failure. Looks really cool and awesome.
  17. fungry
    fungry What's a Dremel?
    14 May 2006
    Shaping up very well :D
  18. ranlai
    20 Oct 2007
    THANKS ALL GUY ,
    But I have question~
    I have seem the post right head side have the "STAR" logo,
    How to make this??
  19. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    could you try to explain that a little better..
    to make a star logo i would use the CNC with a engraving tool.
  20. ranlai
    20 Oct 2007
    I see~
    I want to try~
    Spend my all english power:D
