Scratch Build – In Progress Project: RAD GT (Updated 22-Oct-2007) Up-n-running, 98% complete
Discussion in 'Project Logs' started by radodrill, 25 Jul 2007.
  1. radodrill
    radodrill Resident EI
    14 Mar 2006
    I'm glad I got them :)
    I'll be posting another update this weekend.
  2. ComputerKing
    8 Sep 2006
    wooooooooot very kickass work
    I really love that.. Well done and show us more Come on :D
    good luck
  3. radodrill
    14 Mar 2006
    Update (18-Aug-07): Outer Panels
    Long awaited update :D
    Laid out Front Panel
    Cut out Front Panel
    Assembled Outer Panels
    Rounded the edges; note, only the outside edges have rounds
    Top and Bottom Panels
    Front and Back Panels
    Left Panel
    Right Panel
    Tomorrow I'll put it back together and sand all the edges and blend the corners. I hope to get it polished tomorrow as well; But I may work on a wheeled base for it
    Sponsors:
    [​IMG] [​IMG] [​IMG]
  4. radodrill
    14 Mar 2006
    Update (19-Aug-07): Outer Panels
    Just a small update today; but it give a good perspective of what the finished product will look like
    Sanded the edges to blend the corners together
    Assembled the panels with switches and FPIO to give an idea of how the case will look
    I still have to polish up the edges and install the drive bays; then the case itself will be basically complete.
    Sponsors:
    yan.jpg[/IMG][/URL] [​IMG][/B]
  5. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Looks really good mate! Whats all the buttons gonna be for?
  6. radodrill
    14 Mar 2006
    I'm still waiting on an LED indicator (will go in above the switches) for HDD activity.
    Switches are for:
    • Power w/ power indicator
    • Reset
    • CD eject w/ CD activity
    • UV CCFL
    • Red CCFL
    • Fan lighting
    • Case feet lighting
  7. TNash
    TNash What's a Dremel?
    12 Mar 2007
    It looks really cool, nice job!
  8. Teyber
    Teyber ******
    18 Mar 2007
    whats ac ryan hooking you up with?
    nice work mate...
  9. radodrill
    14 Mar 2006
  10. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Nice project you are working on here radodrill. I have a question about those Kameleon fans. Do they light up good enough to light up a (part of) a case? I'm not sure which fan to get, Kameleon or just the blue/blue UVLED Blackfire4 fans. I want them to light up very good.
  11. radodrill
    14 Mar 2006
    Thanks; The UV LEDs and CCFLs don't provide a lot of visible light. Even blue LED fans usually don't provide too much in terms of case lighting. To produce a nice glow I'd us3e either UV CCFL along with UV reactive components; or colored CCFLs and/or LEDs
  12. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    wow, the shell(case) came out great. how are you going to mount the drivebays? more arcylic?
  13. radodrill
    14 Mar 2006
    Just going to glue the bays to the front panel. I still have to finish polishing the edges before I get to that though.
  14. radodrill
    14 Mar 2006
    Petra's Tech Shop Sponsorship
    I've also received support from Petra's Tech Shop
    Here's what they sent me: Acrylic LED case feet, 3x 120mm chrome fan grills, and water additives (Biocide & Blue, Green, and Red dyes)
    The LED feet and wiring harnesses
    Case feet in action
    One drawback to the controller for the LEDs is that it defaults to a flashing mode when it's turned on; but I'll be eliminating the controller and connecting them directly to a switched 12V line, so that won't be an issue for me.
    Sponsors:
  15. ComputerKing
    8 Sep 2006
    WOW, Really WOW! I can see the photos now, OMG the work is amazing, Brother well done! You have amazing Sponsors too, Every thing is amazing with you ;)
    Good luck.
  16. radodrill
    14 Mar 2006
    Update (27-AUG-2007): Outer Panels & Drive Bays
    Some progress pics are missing since one of my memory cards died
    Polished the edges of the outer panels
    Also installed the PCI mounting bracket
    Cut out/polished the CD slot cover
    Placed in the slot on the front panel
    Made some side pieces for the 5 1/4" bay
    Glued them into place
    With a drive in place
    This evening I'll mount the drive bays; so stay tuned for another update
    Sponsors:
  17. ComputerKing
    8 Sep 2006
    DAm:( That idiot memory card :( dam man your work is amazing and I'm very sad because I didn't see that progress :( any way this last update is awsome, Every thing looks perfect and no wrong with it, Can't wait to see the next.
    Good luck.
  18. kimjor
    kimjor What's a Dremel?
    27 Aug 2007
    I just had to register on this site to say "DAMN NICE WORK"
    Im trying to design my own case, and have been searching all places for build logs so that i could get some info on how to do it. And this is definately one of the best iwe seen so far! Cant wait to see it finished!
    /Kim
  19. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    Looking absolutely fantastic, sponsors were definately right to get you on board. Subscribed!
  20. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    i totally agree 100% with that statement! Awesome work so far man!!
