Case Mod - In Progress Project: Rage (Complete)
Discussion in 'Project Logs' started by Fuganater, 23 Sep 2011.
  1. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    I didn't host my worklog on here but I wanted to show you guys the case mod I just finished. Very simple mod. Enjoy.
    [​IMG]]
    Cheers.
  2. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    what sort of temps you getting ??
  3. Fuganater
    6 Jul 2011
    When folding neither GPU gets over 62 C. Water temp never goes over 40 C with the room temp set to 22 C. CPU gets up to about 72 C when folding.
  4. lilgoth89
    12 Mar 2011
    thats really good...thought that an i7 and two 560s might overwhelm a double rad...its it 140mm ?
  5. Fuganater
    6 Jul 2011
    Yup 2x140 with a kinda push pull action. 2x 140mm yate loons and 2x 200mm fans in the top of the case.
  6. andrew8200m
    andrew8200m Modder
    4 May 2009
    No images ??
  7. Fuganater
    6 Jul 2011
    Sorry my images got jacked up on Photobucket. They are fixed now.
  8. Fuganater
    6 Jul 2011
    Edited the photos. Some came out better than others.
  9. Fuganater
    6 Jul 2011
    Final Pictures Revisited
    Ok so I tried yet another program to edit the final pics. Let me know how they look.
  10. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I like this almost exactly how I want my Haf done nice one mate
  11. Fuganater
    6 Jul 2011
    Thanks!
  12. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    Are those little pegs that you have attached to the RAD to suspend those cables? I cant quite make it out.
    Really nice build, hope you're happy with the end result. Certainly looks great from here!
  13. Fuganater
    6 Jul 2011
    To suspend the LED strips? There isnt space between the rad and the case where they are hanging to mount them. :( I think the "pegs" you see are the actual LEDs. They are held in by clips through the rest of the case.
    Thanks!
