project: random generate *OMFG an update 100205*
Discussion in 'Project Logs' started by th3ory, 30 Dec 2004.
  1. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    The second handle looks sweet on there. goes well with the rest of the case.
  2. th3ory
    th3ory What's a Dremel?
    13 Dec 2003
    the orange stuff is cable sleeving that i had left over, i was just using it to see what it looked like and the other stuff is plastic tubing i got from my local mod shop, its uv reactive and came with wire that u threaded thru it and twisted it to whatever shape u liked, to put around ide cables and psu cable etc etc
    im not sure what ill use for the end result, im thinking aboot getting some cable sleeving to use, possibly blue or green
  3. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    nice mod so far... cant wait to see it completed. I'd say go with the second handle... poll, maybe?
  4. th3ory
    13 Dec 2003
    OMFG its update time lol
    OMFG its update time again
    sorrry for the delays guys, i was gettin my floors polished in my house and had to spend several days gettin it ready, but finally thats done and lookin noice :thumb:
    ok so i finally had a day off to do some work, i guess ill let the pics speak for themselves
    oh and ive decided to use the square handle, i like the design of the first handle but as many of you have said the second handle goes better with the front of the case
    ok time to start on the side panel
    all taped up
    rough idea of what i plan to have on there
    starting to cut it out now
    completely cut out now, cept for the rough as edge that will take me a while to sand back
    some more angles
    i was cleaning up my garage and came across these cool feet from another case that im gona use
    and an overall shot of what ive done so far with the new feet attached
    so thats aboot it for now, ill be spending the rest of the day sanding i think :grr:
