Project Reactor Core - 95% Finished - Sneak Preview 15-07-04
Discussion in 'Project Logs' started by RaZoRbLaDe, 5 Apr 2004.
  1. DLXV
    DLXV What's a Dremel?
    10 Apr 2004
    Too clean! :rock:
    Me like :D
  2. Zion
    Zion What's a Dremel?
    11 Apr 2004
    Thats kick ass man :rock: :rock:
  3. toss
    toss What's a Dremel?
    6 Jun 2004
    Love it dude so awsome :p
  4. LabRat1
    LabRat1 What's a Dremel?
    23 Jun 2004
    If my case turns out half as good as that i will be happy
    real nice job
  5. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Yes it is truning out great... now what are you going to do with the front of the case... :sigh: as to the cdroms, power, etc...
  6. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    WOW, that's simply a beautiful case and nice craftmanship on it! I like how it's looking and can't wait to see the finished case! Keep up the good work!
    DDK
  7. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    :read:
    Slot-Load DVD-ROM
    As for power, I don't know. Please inform us!
    - tf
  8. Chii-wan
    Chii-wan What's a Dremel?
    2 May 2004
    verry good mod and clean, en gaat als dat door
  9. Morpheon
    Morpheon What's a Dremel?
    21 Aug 2003
    OH PLEASE GOD tell me where you got the spring loaded 1/2 ID tubing....I HAVE NEED THAT STUFF SOOO BAD ....sorry having a heart attack after finding what I have searched and searched for :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    lol, thanks
  10. RaZoRbLaDe
    RaZoRbLaDe What's a Dremel?
    19 May 2003
    The springs are individually from the tube. I got the springs with my first watercooling set long long ago. It came with the Senfu set and I inserted them in this tube. I don't know where you can buy them. But just search for really long springs or something like that. Sorry if I can't help you.
  11. saint
    saint What's a Dremel?
    26 Jun 2004
    RaZoRbLaDe......How did you mount that pump up the top of your case??
  12. RaZoRbLaDe
    19 May 2003
    As you can see in the picture. I mounted it with 4 screws and nuts. And I used a rubber between each screw and the chassis for vibrations.
  13. saint
    26 Jun 2004
    I can see where you put screw through the metal, but how do these attach to the pump?
  14. RaZoRbLaDe
    19 May 2003
    The pump has got a big piece beneath it which is removable. That piece got 4 holes in it. First you remove the piece from the pump, screw the piece to the chassis (like I said in the earlier post) and then click the pump to the piece again. I hope you understand what I mean.
  15. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    What are those springs made out of? probably steel or aluminum... watch our for galvanic corrosion.
    What size tubing is that? 3/8" ID? That level of bending would be impossible with 1/2" (or I'd have done it too.)
    Real nice project man! I'm looking forward to the completition.
  16. Thizen
    Thizen What's a Dremel?
    27 Jun 2004
    OMG that is very very nice! i wouldn´t dare cutting holes in a brand new Lian Li chassie :worried: Maybe it´s because i don´t have that much money :waah: But your Lian Li is really nice :)
  17. saint
    26 Jun 2004
    Yeah, I understand what u mean now, so the pump can be removed, but the bit it fixes onto will still be on the chassis.
    I want to do the same, I have the same case(but black) and am most probably gonna get the same pump and seems like a good way to secure and hide the pump!
    Where did you route the power cable?
  18. ejd3r
    ejd3r What's a Dremel?
    29 Jun 2004
    me like! :thumb: :clap: :clap: :clap: :clap: :clap:
    btw. im new! Hello :naughty:
    edit: what is a dremel? :confused:
  19. WeldZilla
    WeldZilla What's a Dremel?
    22 Apr 2004
    Sweeeeeet!
    you have done some icredible work here. you know in my experience modding is not hard it is just time consuming and requires only a great imagination and you certainly have that!!
    WZ
  20. saint
    26 Jun 2004
    Woohoo, just got my new Lian Li PC-61, maybe a log will follow.......
