Case Mod - In Progress Project reborn, a simple PowerMac G5 mod, final picture 14/4/11
Discussion in 'Project Logs' started by tjay@TJ, 8 Mar 2011.
  1. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    it has been a year since i mod.
    now it is time to re-polish my skills.
    the victim for this project is
    it will be just a simple conversion for common form factor to be used.
    the initial plan is to keep the case form being chopped.
  2. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    some picture to do the talking
    some older lian li case to donate its panel for bracket.
    bended
    this picture will show u how it is mounted.
    beside that
    a psu mount bracket was also created.
  3. jhanlon303
    7 Sep 2006
    Another G5 mod. Several of us have done them.
    I watch.
    john
  4. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    thanks.
    i has been follow most if not all of the g5 mod, getting inspiration and tips from them.
    well, i started this project in febuary, i still have some more picture to post.
    more to come after i rearrange my photo
  5. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    since i dislike the 1st version of the bracket i mad, i decide to make a new one.
    fan mounting.
    cut some arcylic pieces
    this is how it looks like at the moment.
  6. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    I used to work on a G5 at my work and those are some nice cases if you ask me. I like to see people modding them, it kinda makes me laugh to see a Macintosh being stripped for its beautiful exterior.
  7. MarcosLFV
    MarcosLFV What's a Dremel?
    7 Mar 2011
    Great work with that case :thumb:
  8. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    thanks, i am the 3rd owner for this case. by the time i had it, all the internal had been gutted out. will try my best to work most out of it.
    thanks.
  9. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    update
    cut some slot for the pci bracket on the arcylic which use to mount the motherboard.
    and also cut the upper divider try for psu breathing hole.
    and also some hole for cable routing
    in the process.
    i break my jr saw.
    the blade was not broken even once.
  10. jhanlon303
    7 Sep 2006
    Nice cuts in the tray. sorry about the saw.
    john
  11. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    thanks john.
  12. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yay~ new update.
    tap the bracket using screw ( cant find tapper in this country :( )
    also the spacer is placed.
    original mac hdd cage
    problem :wallbash:
    the hdd cage will hit the motherboard.
    well i guess i had to find the solution.
    some other things
    this lian li bracket will be placed infront as intake
    thanks for watching and
    see you soon.
  13. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Aaaah too much G5 mods going on. I gotta make mine (which will start in a few weeks) better!
    mwahaha.
    But no worrines. I will watch and lurk :thumb:
  14. usagi
    usagi What's a Dremel?
    3 Mar 2011
    Hello!
    Nice work, I'm watching you :D
  15. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yea... suddently all the g5 mod are popping up in bit-tech.
    :clap:
    thanks. i will be watching urs too. :D
  16. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    been facing quite a few small problem.
    1st is the hdd cage. (not enough space for it and the g5 air baffle /deflector in place)
    2nd is the front IO cable. (not long enough for it to reach, i managed to burn a speaker by plugging in the wrong pin :wallbash:)
  17. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    before giving up or taking some rest form modding.
    i managed to do some test fitting with some hardware.
    hardware use will be going in the g5 case.
    processor - intel i5 750
    motherboard - asus p7p55d-e-pro
    ram - corsair xms3 2x2 gb
    graphic - gigabyte gtx 260+
    psu - gigabyte odin gt 550w (not seen yet)
    hdd - WD 808gb (not seen yet)
    u can see about the wire will have no space to route once the psu placed.
    the g5 and my current lian li g7b
    hardware gutted out :D
    that is all.
    more work is being done. seen u soon.
  18. sinner666999
    sinner666999 What's a Dremel?
    3 Jan 2011
    If Apple does one thing right every time its make beautiful cases. Me watch.
    Maybe you can mount the HDD rack standing up. Or if you can find a small enough one on its side.
  19. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    What strikes me is the genious way you made the bracket for the GFX. Just pushing it a bit further in. It's frikkin awesome! Why didn't I think of that!? That would have saved me 2 billion years in workarounds!
    Loving it! :thumb:
  20. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    yea. about the hdd cage. i got another lian li hdd cage. it will just fit into the place. the only thing is, it is not as striking as the original hdd cage.
    thanks, love ur work too. especially the waterblock for the graphic care.
    ur project was the inspiration for this mod.
    the bracket is design to be used with this converter.
    it will fit exactly into the space in between.
    beside that, the apple io port which i cut will fit into the original position without any problem with this bracket.
