I have Decided to start my first real mod. It is going to be based on a Coolermaster Wavemaster. It is going to have a side window which will be tinted in 'limo black' and it is going to be watercooled. To get the log off to a start i will wet you appetite with these pics. What Do we have here then Lots of parts (yummy) The fill port, this we be explained later Chipset Block Maze 4 Cpu Block TDX Socket A 1 Pump The Fan To Go On The Rad The Radiator The Res (Tank-O-Matic) That is the lot for now, the case should be here later today so we can expect some more pics when it arrives Until Then Enjoy What You See Rich
Minor Update The case has arrived and i have tested some of the parts out in the case to see if they will fit. Here are some shots Richman out
