Case Mod - In Progress Project Refl3ctoR 900D by Twister7800gtx -Complete-
Discussion in 'Project Logs' started by twister7800gtx, 20 Oct 2013.
  1. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
    Project Refl3ctoR 900D -Twister Mod
    Hi Guys! After the last Mod I made last year, the 8.0.0.D, a mod built upon the Corsair 800D, this year i deceided to create a new project based on the very new Corsair 900D.
    This work shall be an evolution of the previous project tryng to solve some of the limits that had occurred previously with some evolutions and graphic optimizations ( i hope you will approve them ).
    This is the summary of the used hardware...
    HARDWARE:
    CPU: Intel® Core™ i5-4670K Processor (6M Cache, up to 3.80 GHz)
    RAM: 4X4 Gb Corsair Dominator Platinum DDR3
    MOTHERBOARD: MSI Z87 MPOWER MAX
    ALI: Corsair AX1200i
    VGA: 2x770Gtx 2GB Gainward
    WB: Full EK
    Sponsor:
  2. MattoDaLegare
    MattoDaLegare What's a Dremel?
    7 Oct 2013
    Subbed! I remember your last project in Lucca last year. I hope this project will be amazing like the last one!
  3. twister7800gtx
    2 Nov 2011
    The presentation starts with the imponent Case kindly supllied by Corsair... Godzilla 900D!
    Before unassembling it let's a view of it!!
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    If this will be anything like your previous project it will be epic.
  5. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    I have your other mod bookmarked in my inspirational worklogs folder, If this is anything like that It will be amazing! I cant wait to see this!
  6. twister7800gtx
    2 Nov 2011
    it's a honor!
    mi fa piacere vedere un italiano da queste parti che si ricorda di me :D grazie mille
    Thanks you so much!
    Thx everybody for following me in my new project i am cajoled!
    we may start with something interesting like a marvellous MSI Z87 MPOWER MAX brand new!!
    this is the choice for the motherboard for its aggreesive outlook and very high overclocking properties....but about the color....yellow....maybe a little brush could help!
  7. twister7800gtx
    2 Nov 2011
    And Now... New Psu Corsair! the best 1200i
  8. twister7800gtx
    2 Nov 2011
    before proceding I care to remember the whole project will be around the trasnsformation of 900d in a full Btx with some surprises of course! so i can begin to disassemble the rear and frontal panel to invert them and using my beloved dremel!
    It can be seen the cutting path with the pencil
    Next stagei make a partition !:dremel:
    e voilà!
  9. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Nice will follow this :)
  10. twister7800gtx
    2 Nov 2011
    next stage!
    After trying several ideas, I decided... the tank was designed .... and here it is just the final closure!:dremel:
    filet here :)
  11. twister7800gtx
    2 Nov 2011
    I proceed the work ...
    I'm trying to transform the 900d in Btx, and it is necessary to make extensions for Motherboard...
    the support motherboard black with holes ,where cables pass under the motherboard ...
  12. Derick
    Derick Senpai Studios
    26 May 2012
    Looking forward to the results :)
  13. twister7800gtx
    2 Nov 2011
    Shopping list :rolleyes:
    Waterblock EK for 770 GtX
    CPU I7 4670K
    The Glorious MSi Z87 Max Power!
    770Gtx Time!
    Some of the Sponsor Corsair
    And now the Pci Express cable for the my particular btx!
  14. twister7800gtx
    2 Nov 2011
    This morning i deceided to work on the frontal panel of 900D...using a mirrored panel a made a new one!
    How does it seem to you?
    And here Corsair logo Brightned! with a little treat in the bottom-right corner for brighting I used the usual Led stripe 7000k 600smd/1MT:D
  15. twister7800gtx
    2 Nov 2011
    next step! :idea:
  16. twister7800gtx
    2 Nov 2011
    well, we can continue with some measure for safety and we place the reservoir for the first time ..
    measurements for the holes passers...:dremel:
    :dremel::dremel:
  17. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    looking verry good already :D
  18. twister7800gtx
    2 Nov 2011
    tnx K.3nny :D
    Finally I have started to build "Vein" for the liquid ... as many expected is composed in two parts and pasted with ACRIFIX-evonic-
    quick photo of my girls cooled :hehe:
  19. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking incredible as per usual dude!
  20. Hukkel
    20 Dec 2012
    Will you glue the covers in the midplate?
