*not really much of a worklog anymore because ive gotten alot of main parts done on it but it still has a ways to go so keep checking back* well i got probably the crapiest raidmax cases ever this thing was beige and jsut ugly. so i decided to take the case i got it for $5 and completely redo it and here is the project log for it, enjoy. the case and goodies window mod next Front Pannel soon to have a grill Fans Sanded for raw metal it doesnt look to bad Painting Process has begun First Coats A few coats later and a nice gloss clear coat there it is all together i need to fix the molding some but thats what it looks like im going to add a really cool style window and then i have the front to do i gotta order some stuff still but it should turn out rather nice. ill keep you all updated
i think... the plexi is to more on the front. and you will not see your ( i think ) beautiful motherboard hmm... but nevermind.... good work
may i suggest this I think this would solve your problem of not seeing the motherboard. Just a suggestion.
good point, unless you have 20 10k rpm Raptors in there HDD's are fairly uninteresting. The original purpose of a window is to show of your mobo, vid card and cpu. but, c'est la vie
you see i havent told you what the window will be like tho... when its done you wont see the inside of the case very clearly i put the window there just to reflect more light off the racks
Unfortunetally my host died so i will just run the worklog from my website http://www.blades.overclockedgaming.com/worklog.html
