Hey, I Was Thinking About Doing A Resident Evil Mod Based After The New Movie, Resident Evil: Apocalypse. I'm thinking About Including The T-Virus Container, Like So.. as well as the Anti-Virus... ... (yes i'll add the tray in it too) And On The Side Have The Umbrella Corporations Logo... and Etched On The Window Will Be.... I'm just not sure what colour i should paint the case...any suggestions? Thanks..
Paint the case red and the skelleton black, or the other way around. Anyways, try to use the colors on this wallpaper, and try to etch on plexi or cut out that resident evil logo. Also try to use that map in the backgroud for something. If you have dremel skills, then that map can become quite a cool etch
Yeh, Like It's Just In It's Developments Stage So There's Alot Of Things I Could Do...But The Suggestions Are Helpful. As For Doing It On The Game, I'm Not Really Sure, It's A Possibility..I'm Trying To Tie Both Of Them In To Each other.. Anyway, Post More Later
LOL, i know what ya mean, i used to do that on everything i typed, had to stop tho cos it annoyed the teachers!
Yeh..See, I Have No Cash Untill The 20th (My Baby Bonus Comes In) Then I Can Start, No I Don't Have Kids, lol, I'm 16! Anyway, I'll Start By Getting The Paint and All, If I'm Not Accepted For The Male Modeling Thing On Friday Nite, It's $45 And If I'm Not Selected I Get My Money Back. Anyway, I'll Probably Start On Saturday By Getting Paint Or Materials To Build The T-Virus and G-Virus Containers...
Can I make a suggestion for the Virus containers. Maybe it will save you some headache/money. Ready? It's brilliant. Ok...here goes... Use Plastic Crazy Straws. Seriously, check it out... Plus, if you run them under HOT water, you can bend them even more, any way you want...keep them in that shape, let them cool, and they will hold the shape. Then just use and acrylic tube to house them. (if you can't find small acrylic tubes, I have HUNDREDS of them, PM me if you need some). Hope that helps!
cool colors hey, it would look cooler if the tubes were clear but you use colored liquid, you could even make it part of the cooling sytem, also you shuld find a S.T.A.R.S. fan grill to go with. P.S. it would also look good is there was a "broken" one with liquid coming out. you could use model railroad water with coloring
Those crazy straws are a great idea. Crazy straws inside something like this would be awesome too to create that spiral affect in those vials in the picture. Or! If you could attach some of your hoses to the ends of the crazy straws and put a vial around those crazy straws... That'd be sweet! And I think i'd also just make the case RESIDENT EVIL rather than adding apocolypse or zero or anything after it. It'd give you more freedom to use elements from all the games / movies. It'd be cool to have one res containing blue liquid and another containing green -- blue to CPU and green to GPU... I got lots of ideas! This could be a cool mod! Good Luck ! would that take two pumps though ?!
yikes its pricey, but based off the watermark on the image, i believe its this http://xoxide.com/wtank.html neat idea, i really liked resident evil and look forwarld to RE:A
I got one of these with the idea of making the virus tube. I havent finnished my thoughts on it so I will post a pic when I get it done too. lasoaaro, you have an awsome idea dude. I look forward to seeing it completed.
Hey, Thanks For All The Ideas, But See I'm Making 8 Of The Virus Tubes...4 T-Virus Tubes and 4 G-Virus Tubes (Anti-Virus) So Those Res.'s Would Be Alot Of Money In The End... Any Other Ideas For What To Keep Them Contained In? I Was Thinking Actual Glass If I Could Get It, Or Like Sumthing Along Those Lines...Help Me Out! lol Thanks
\ Yeh, It'd Prolly Take 2 Pumps..Different Colours Would Need A Different Pump, Don't Feel Like Having Green And Blue Mixed In My Tubes...Eww..lol..As For Just Resident Evil On The Side, That's What I'm Doing And As You Said, Allows For More Creativity. Thanks For The Idea!
