Project: Resident Evil Apocalypse Mod? Lack Of Funds...Set Back
Discussion in 'Modding' started by lasoaaro, 19 Aug 2004.
What Switch Should I Use?
Poll closed 10 Sep 2004.
  1. Key Switch Or...
    11 vote(s)
    17.5%
  2. Keypad Switch
    52 vote(s)
    82.5%
  1. BvBart
    BvBart What's a Dremel?
    29 Jul 2004
    As for the tubes, you could probably use something like a Tennis Ball container? Although that may be too large.
  2. lasoaaro
    lasoaaro What's a Dremel?
    10 Aug 2004
    As For The Tennis Ball Container, It's Too Big, I Need Something Smaller, I'd Say, Ohhh About 7.5" and about 1.5" Diameter...Anyone Know Anything Of That Size?
  3. bbigboy101011
    bbigboy101011 What's a Dremel?
    27 May 2004
    if you need somthing that size look in the kitchen ware section of like walmart, or target, and if don't find it there walk around the hardware store for a whileall you need is somthing to make the tube. :search:
  4. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Well, the crazy-straws would be the lowest cost you could go. As for real glass, check with a neon sign maker, they could bend the glass tube stock customer for you - but it is going to cost you an arm and a leg. Again, crazy-straws = cheap! :thumb:
    Well, like I said, I have hundreds of scrap acrylic tubes. About 1" side by 5.5" long. Might be too narrow for you, but if not, drop me a PM and we could work something out. :idea:
  5. bbigboy101011
    27 May 2004
  6. lasoaaro
    10 Aug 2004
    Thanks For The Sites But The Prices Are That Of Which I Can't Afford, I'm Not On A Big Buget..And It's All About Me Getting Pay Checks, So It'll Prolly Be A While Before My Mod Is Complete, I'd Say 2 Months..
  7. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    hmm. i like the idea of the res, but why not have dual reses? One feeding blue spirals, and another feeding green spirals (of tube of course)
  8. lasoaaro
    10 Aug 2004
    I Was Thinkin' About That But I'm Not Sure If I Wanna Do Watercooling On My Comp... I Know ALOT Of People Are Doing Watercooling And All..I'm A Noobie At Watercooling And Knowing My Luck, I'll F*** It All Up, Lol...
  9. Kurtis
    Kurtis What's a Dremel?
    9 Apr 2004
    I think putting the virus in somewhere in your mod would look cool, but i would leave out the tray from it, as it is sorta big and wouldn't make it look any cooler.
  10. lasoaaro
    10 Aug 2004
    Ok, thanks for the Idea.. Will Do :thumb:
    Later...
  11. lasoaaro
    10 Aug 2004
    Hmm, This Just Crossed My Mind..Has There Ever Been A Resident Evil Mod??
    Anyone Know? :confused:
  12. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    has anyone suggested acrylic tubes?... probably could find some at a local craft store, or acrylic retailer!
  13. lasoaaro
    10 Aug 2004
    Yeh, We're Way Ahead Of Yah..Read The Forum...
  14. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Oooooo, Michelle Rodriguez!! :blush:
    Do the mod!! I already love it!
  15. sk8phreak88
    sk8phreak88 Minimodder
    8 Aug 2004
    An idea mabey?
    I'm not sure if this would work but.. If you could get the spirals made of plexiglass you could use blue and green leds to get the color, just place one led at the botom of the spiral on the plexiglass... It should work. If you get what I mean...
  16. G-gnome
    G-gnome Peter Dickison
    8 May 2003
  17. lasoaaro
    10 Aug 2004
    I Started Modding Today, I'll Have Pics Up By Monday..
  18. bbigboy101011
    27 May 2004
  19. lasoaaro
    10 Aug 2004
    Yeh, Thanks For The Site But Only One Problem, I'm 16 And I Don't Have A Credit Card Aswell, My Parent's Don't Either..
  20. bbigboy101011
    27 May 2004
    then find a mail order plastic company
    :wallbash:
    hey if you can't find it there go to the home depot and ask for the parts
    :idea:
