Case Mod - In Progress Project: Reverse² [completed]
Discussion in 'Project Logs' started by Reverse, 9 Dec 2009.
  1. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Nice mod!
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking great dude :)
    If the clearance isn't to big then 2 sheets of thin rubber may create enough friction to hold it in place. I know its probably safe but I'm always a bit worried about magnets and computers :worried:
  3. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    I know people that have used magnets to hold their side panel windows on. And they were pretty heavy duty magnets. If you use small magnets that you can buy at your local hardware store (they are usually rectangular and come in long rolls) then you shouldn't worry about it. Just glue them down to make sure they don't go anywhere.
  4. Sennebring
    Sennebring Rookie Modder
    15 Jan 2010
    WOW! This is really a work of art!
  5. jono51
    jono51 What's a Dremel?
    17 Jun 2010
    I loved the design you've chosen, great mod. Keep up the good work:dremel:
  6. bsoltan
    bsoltan What's a Dremel?
    14 Apr 2008
    Love it. Really like the design of this case and your mods are really enhancing it. Good luck!
  7. Pikey
    Pikey What's a Dremel?
    20 Jun 2009
    Updates?
  8. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Thanks man!
    I took my chances and glued 2 small rectanglular magnets to my divider. works like a charm!
    Thanks for the comments guys!
    yes.
  9. Reverse
    25 Sep 2008
    Full shots:
    Ok, so I took the case outside, for a few shots. The case is assembled, and ready fors ome glamour shots.
    I didn’t get any help from mother nature though, the weekend I shot these pics it started raining the minute I got outside. So these are the only shots I could make.
    A full shot. Again, the sky was completely clouded, so the natural light was very bad.
    The sidepanel, untouched.
    The backside, I just noticed I forgot to put the 6th PCI-slot cover back in place… oops!
    I love the glossy sidepanel, not a scratch!
    Overview
    Just to show how shiney and mirror-like the window is… I put it next to a brick wall:
    Now how nice is that?!
    Next, a couple of detail shots.
    How do I get my case to look like a monster? It looks HUUUUUUUUUUGE in this shot!
    Talking about gamourshots! This is the best pic I have ever made if I’d say myself…
    Once again, a shot from below:
    Then I took the case inside, to put some life in it.
    Dimmed the lights, closed the curtains and powered up my baby.
    All curtains closed:
    What’s that? You want to see how the interior looks? Well… h’okay, here you go!
    And a good shot to finish this update.
    I’m planning to build myself a proper photostudio/setup.
    A softbox, a small table with a black backdrop and possibly more.
    Tips and tricks are welcome, I want to make some awesome glamour shots!
  10. uber_cookie
    uber_cookie What's a Dremel?
    16 Dec 2008
    I love the cable braiding idea you had :) thank you ;)
  11. Matticus
    Matticus ...
    23 Feb 2008
    Looks fantastic. I like to see nice subtle mods, it is the sort of case that you can live with day in day out. You have really improved the look of the case while keeping the original feel of it.
    I am not sure if its just my monitor, or your pictures, but the outside shots, the fans and front "line" look a bit red...?
  12. Nicksen
    16 May 2010
  13. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    The final shots are very impressive. I like the subtle contrast of the colors of fans and LEDs against the black case. Low key and classy. :thumb:
  14. Editor22
    3 Jan 2009
    Great final shots dude :) glad the magnets worked out for you in the end
  15. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    This looks great man! Congrats on a job well done!
  16. Reverse
    25 Sep 2008
    Exactly, that's what I went for.
    Thanks man!
    It's true.
    The lightning wasn't optimal. That's why I am planning to do a proper photoshoot (glamourshots) later this week (or next week).
    Thanks.
    Thank you man!
    Thanks for the comment, I simply LOVE your build. So inspiring.
    Thanks man!!
  17. KingCake
    KingCake What's a Dremel?
    13 Jul 2009
    You, my man, you're a ****ing awesome modder! :D Lovable result!
  18. Chanc3
    Chanc3 What's a Dremel?
    22 Jun 2010
    I'm just into fiddling around with some my Fractal R2 case, and I was just wondering how easy is it to change the LED for the power? Looking to go to white instead of blue.
  19. Reverse
    25 Sep 2008
    Really easy, here's a small step-by-step:
    1. Remove the front panel.
    2. On the top of the panel, you will see a few ports and switches, the powerswitch and power LED are in the middle.
    3. Unscrew the middle screw, pust the little plastic rod to the side, and take out the powerswicth (with the LED embedded)
    4. The LED is simply glued into the plexi-ring, with a little bit of force you can take the LED out.
    5. Unsolder the blue LED and replace it with your own 3mm LED.
    6. Glue the new LED in place with a tiny drop of clear glue, thats all.
  20. Chanc3
    22 Jun 2010
    Thanks for the reply, just ordered 5 prewired ones off ebay as they were the cheapest and the least quantity. Thanks for your help!
    Are you going to be watercooling like in your concept?
