Case Mod - In Progress Project: Reverse² [completed]
Discussion in 'Project Logs' started by Reverse, 9 Dec 2009.
  1. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Thanks man!
    I really think it's the compound that f'ed up the first clearcoats.
    I will be buffing the frontpanel's clearcoat later on, i decided i'd let cure for a while.
    Not at all, not at all.
  2. razerz
    razerz What's a Dremel?
    2 Aug 2009
    All that work really paid of, the finish looks better now than before(could be the pictures, but now it seems to have more depth, a "richer" and more black finish).
    And that drilled and sanded line looks like it is stock (meant as a good thing). The best mods in my opinion is those that makes everything look like it was there when the case was bought.
    Good work! :thumb:
  3. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    at first i thought he said loving the clean nuts....lmao i read these threads to fast and hey like the log so far i follow it everyday at school while in keyboarding class(i type 87 words per min and they make me take a keyboarding class....a study hall would of been better)
  4. Reverse
    25 Sep 2008
    Thanks a lot!
    Could not have said it better myself, thanks again!
    Haha, were you reading too fast? Or were you thinking about some clea- *uh..* never mind.
    :worried:
  5. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    What I meant was, that the box should have room for a top mounted radiator when stock. It was not a comment on your work.
    Hope thats sorted then....:hehe:
  6. Reverse
    25 Sep 2008
    Aaaah, i simply misunderstood.
    Now you mention it, if the case had about 5cm more room in the top, a radiator+fans would fit.
    That would have been awesome!
  7. Sennebring
    Sennebring Rookie Modder
    15 Jan 2010
    Really nice mod Agressions! :thumb:
    I got one Define R2 of my own and i was really happy wiyh it until i bought a liquid cooling system. Too bad Fractal Design didnt leave a couple of centimeters at the top and in the front for radiators. Im going to remove the harddrivebay to fit a 240 rad in the front and put my hdd in a Scythe Himuro at the bottom of the case. It was really fun to see the first real mod of this case, you must be one of very few that owns this case outside of Sweden. Subscribed :)
    Apologize if my english is too bad :rolleyes:
  8. Reverse
    25 Sep 2008
    Thanks man, i really appreciate it!
    I believe I am the first one to mod the R2 indeed, if not; I'd like to be linked to the 1st one's worklog.
    That said, I will be announcing a few new sponsors when I receive their stuff, but here's some teasers!
    The one who guesses the name and product of my new sponsor will receive 1 e-cookie!
  9. llPsyCholl
    llPsyCholl What's a Dremel?
    6 Sep 2009
    I think your sponsor is:
    ThermoLab
    And it looks like a "BARAM" =)
    Sponsor: ThermoLab
    Name. BARAM
  10. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    I agree too Thermolab
  11. shakka65
    17 Jan 2010
  12. Reverse
    25 Sep 2008
    Damnit, I thought it would be a hard one to guess..
    Guess I was wrong...
    Here you go guys!
    But yes, ThermoLab has agreed to sponsor this project with a BARAM aircooler.
    I am very happy to have them on board, and am looking forward to receiving and unboxing the package =D
  13. Sennebring
    15 Jan 2010
    Congrats to the new sponsor!
    I´m really looking forward tp the next update!
    It would have been great if you built liquid cooling in your case,then I could have stolen some ideas ;)
  14. Reverse
    25 Sep 2008
    Haha, indeed!
    Your idea about the 240 rad in the front (instead of the HDD-bays) sounds solid though!
  15. Matticus
    Matticus ...
    23 Feb 2008
    Loving the mod. That front panel cut is very clean.
    Wondering if you had any info on the fans, I was looking to buy some because they look great. I cannot seem to find if they are sleeve or ball bearing. Seeing as though you have your hands on the fans, and all the packaging etc I wonder if you know?
  16. Reverse
    25 Sep 2008
    What fans do you mean?
    You mean the Fractal Design fans (I had 2 with the case)
    Or the Xilence fans?
  17. Matticus
    Matticus ...
    23 Feb 2008
    Sorry the fractal ones. Pretty sure xilence are ball bearing aren't they?
  18. StEm
    StEm What's a Dremel?
    30 Nov 2009
    looks really nicee, good work with correcting the paint cause clear coat is a bugger.. its looking very clean, keeping my eyes on it!
  19. rocketjumping
    rocketjumping DIY ADDICT
    24 Feb 2008
    That front slit you drilled turned out really nice considering you did it all by hand. So many builds I see now are all "I put the metal on the CNC, then installed the computer and thanked my sponsors."
  20. Reverse
    25 Sep 2008
    The Xilence fans (i have 2 different ones) are sleeve bearing (140mm) and Hydro bearing (120mm Red Wing).
    I don't have the packaging from the 2 Fractal Design (120mm) fans, but I pried one open for you and took a look. It's pretty much identical to the 140mm Xilence.
    So, I'm pretty sure it's a sleeve bearing aswell.
    Thanks for the compliment.
    I agree, eventhough I love seeing one of those mods every once in a while (DarkBlade and DBRS). I still like the "traditional" way of modding more.
