Case Mod - In Progress Project: Reverse² [completed]
Discussion in 'Project Logs' started by Reverse, 9 Dec 2009.
  1. Matticus
    Matticus ...
    23 Feb 2008
    Thanks for the info, and keep up the good work. I can't wait to see how this turns out.
  2. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    I love the colors you have selected for the mod. Excellent job mod on!
  3. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Thanks for the comments guys, keep them comming!
    The window, take 2:
    Cutting the panel, again:
    So, I’ll be fair to you guys.. I was not looking forward to this task..
    It was time to enlarge the cut window.
    But, the window I had was perfectly cut, filed and sanded! It was just a bit (read: way) too small. In fact. I decided it should be at least 10cm taller.
    So, after delaying the task for a few weeks (!) it was finally time to do it.
    I got myself together, grabbed all my courage, and went for it.
    This was how the panel looked:
    I covered the panel with painter’s tape to prevent it from damaging:
    I even taped the perfectly filed edges, just so I didn’t have to redo those:
    Then came the time to measure (once, twice, heck! I even measured three times) the area to cut.
    As said before, the hole should only get taller.
    The came the cutting…
    I wanted to drill a hole in the to-cut-area, but for some reason my Dremel wasn’t working properly.
    It simply couldn’t drill a hole in the panel…
    So, after a while I gave up.
    And took the jigsaw to make a rough cut.
    Of course, I was afraid the jigsaw would damage my panel, so it got the tape treatment as well!
    So 4 layers of tape between the tool and the panel, should be enough.. right?
    I said I would use the jigsaw to make a rough cut right? And when I mean rough…. I mean rough!
    After using the jigsaw I needed to file/sand away 5mm of the metal!
    But, I’d rather file for hours than mess up my panel.
    I started filing like a lunatic, and after about an hour I was getting close.
    I took off the masking-tape to check my progress.
    Turned out I was about 1mm off at some places.
    So, a piece of masking-tape as a guideline:
    And off we go again!
    3 complete hours after I started (it was dark at this time) I was finally done cutting, filing and sanding my sidepanel.
    Throughout the day a lot of snow had fallen. And together with the snow that had been there for a few days and the dark sky….
    You guessed it..
    I took the panel outside for a high-contrast picture:
    The black panel and the white snow… Aaaaah
    Here you can also see the clean cut.
    Soundproofing:
    The Fractal Design Define R2 comes with excellent soundproofing material. It’s called Bitumen, and it’s very heavy (it also smells a bit).
    So, I had taken the Bitumen plate out when I started the first cuts on the sidepanel, but I felt like sticking it back on. To keep it a bit more soundproof (HDD and DVD bays are the noisy parts.)
    So I took the panel back inside, when I thought:
    Aah damn, all that snow… Gotta wait for it to melt and dry before I can continue…
    So my snow picture may be good, It took away a lot of my time..
    Then I laid over the old Bitumen plate:
    Turned the panel over and marked the window on the Bitumen plate.
    Then I took about 3cm of clearance and cut the Bitumen.
    This is also when I noticed the Bitumen smells….
    Tadaaaaa! I’m done with that as well!
    I’ll wait with sticking it back on, at least until I receive my Plexiglas for the window.
    Done:
    I took a permanent marker (sharpie) to cover up the plain metal on the edges. Looks like it was ment to be like this now!
    After that I decided to clean the panel with some Glassex (Windex for you Americans) to make my fingerprints disappear.
    Then stuck it back to the case, for the final look:
    That shot was made with an angle, you can see the top and back fan guards through the window!
    And of course, a shot from a 90 degree angle:
    A shoutout to my sponsors, for making this mod happen:
    [​IMG] [​IMG] [​IMG]
  4. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Thats a window!
    Damn good job.
  5. stonedsurd
    11 Mar 2009
    Beautiful. That's a great looking case!
  6. Sennebring
    Sennebring Rookie Modder
    15 Jan 2010
    I hope it will work out great:) I just drilled up the rivets to remove the top temporary and now the hdd-bay is removed. Maybe I link some pics of it when i finished my mod.
    I really like your window! Normaly I hate windows but yours was just big enough :thumb:
  7. shakka65
    17 Jan 2010
    What stonedsurd said.
  8. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    An amazing mod with an amazing log, very well done!
  9. imersa
    imersa Parvum Princess
    9 Apr 2009
    doing a really good job man,
    whats next?!
  10. Reverse
    25 Sep 2008
    Thank you all very much!
    Thanks man! I try to keep the log as entertaining and detailed as I can =)
    Thanks!
    Up next, painting. :clap:
  11. Rotcrack
    24 Jul 2009
    How are you going to light up the front line? Getting a light with even brightness all the way down is going to be hard.
  12. Andersen1337
    Andersen1337 What's a Dremel?
    10 Apr 2009
    He could just put a CCFL-tube there, or a sheet of plexi that spreads the light evenly.
  13. Rotcrack
    24 Jul 2009
    Diffuse Plexi...
  14. Andersen1337
    10 Apr 2009
    Didn't know the name for that, so thank you! :D :thumb:
  15. Reverse
    25 Sep 2008
    I don't know for sure... I am currently discussing this issue with my sponsor (will announce this sponsor when i receive their stuff)
    There is about 2mm of space between the 2 parts of the front panel.
    There is no way a CCFL would fit there.
    Yes, but is there orange diffuse plexi on the market?
  16. Rotcrack
    24 Jul 2009
  17. Rotcrack
    24 Jul 2009
    Bump...
  18. Reverse
    25 Sep 2008
    I have already ordered some plexi (smoked and orange)... Will try to get the desired effect with the orange first.. If that doesnt work I'll have to be inventive =)
  19. Rotcrack
    24 Jul 2009
    :) Happy for you, mind sending me the link of where you found it ( if on-line). Looking forward to the first pictures of the lighting.
  20. Reverse
    25 Sep 2008
    The orange has been ordered (at the start of this project) at BouwPlastics.nl, but they have a DB-error atm, so i can't give the exact link.
    I just ordered the smoked plexi at WSV Kunstoffen today, after receiving excellent samle's of the stuff.
