Case Mod - In Progress Project: Reverse² [completed]
Discussion in 'Project Logs' started by Reverse, 9 Dec 2009.
  1. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Side panel looks much better now.
  2. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Thanks man!
    It's time to show the paint I bought for this beast.
    I was looking for metallic-orange in a spraycan (will only be spraying a few parts, no need to bring out the big guns)
    But, you guessed it... I simply couldn't find it. Not online, and not offline.
    So I opted to go for the best option I had, Fluorescent orange!
    As I always do, I tested it out on a white paintcap, just to see how the color would be in person (the color on the can/cap is always off).
    Here's the color:
    What do you think?
  3. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    its like neon orange almost
  4. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    FFFFUUUUUUUU--- Perfect!
  5. Andersen1337
    Andersen1337 What's a Dremel?
    10 Apr 2009
    +1, that color is just pure awesomeness.
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    A tad too much red maybe, but on smaller pieces this would not be that bad.
  7. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    That color is great! Is the paint a matte finish (might be just me), if so are you going to add some clear coat to shiny it up?
  8. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    Nice color indeed.
  9. Sennebring
    Sennebring Rookie Modder
    15 Jan 2010
    Great color! Your mod is getting better and better :)
  10. Reverse
    25 Sep 2008
    THANK YOU ALL! =D
  11. Reverse
    25 Sep 2008
    Painting the parts:
    Of course, some of the parts had the wrong color. And some of the new parts will have to be painted aswell.
    The tool of the trade, a green Scotchbrite pad:
    It gave me a great result, and worked better than sanding in this case.
    The black parts
    You might remember the casefeet, they were a glossy chrome-ish finish:
    Even though the casefeet look great, it simply didn’t match my ideas, so they had to be painted… Matte black!
    I taped the important parts (the rubber/silicon) parts, so they wont get painted aswell.
    The final outcome:
    AAAAAAAAAH! Much better!
    Same story goes for the backplate-slot covers, they were white and had to be black/orange.
    I decided to go for black (my original plans were orange, but this looks way more classy.)
    Before:
    After:
    NICE!
    The orange parts
    My original ideas were a color scheme with (matte)black and metallic orange.
    But no matter how many stores I checked, I simply couldn’t find a good metallic orange is a spray can.
    So, my original plans were scrapped, and (at the moment I saw the color) I decided to go for fluorescent orange instead.
    I bought the can, and sprayed a test piece (cap of an white spraycan):
    So, I painted the white HDD-racks orange:
    Before:
    And after:
    And, I found some orange PCI-slot covers in my “modding-bin”.
    They are orange, and UV-reactive (fluorescent), but they don’t fit the other orange parts…
    Sooooo, let’s grab the Scotchbrite pad again!
  12. Matticus
    Matticus ...
    23 Feb 2008
    Great job on the spraying, looks very professional. That orange is an amazing colour, it did look a bit red on the spray can top, but on the hdd rack it is spot on.
  13. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    Nice so far, really like it. Its a really clean mod too, so kudos!
    Plus I love orange and black, well, old gold and black :p
    Keep it up!
  14. Sennebring
    15 Jan 2010
    Great Paintjob!
  15. Rotcrack
    24 Jul 2009
    Nice Blo-- erm.. paintjob.
  16. stuartwood89
    20 Aug 2008
    :hehe:
  17. shakka65
    17 Jan 2010
    That orange color on the HHD rack is spot on man. Beutifully executed.
  18. Validus
    Validus What's a Dremel?
    25 Aug 2009
    That fluorescent orange is fantastic. And I know exactly how you feel with the window. Rather leave a margin of error, than have to scrap it.
    Quick question: The orange looks to be a glossy paint on the HDD rack, but matte on the cap. What finish did you choose?
  19. Reverse
    25 Sep 2008
    Thank you!
    Orange and black are my favorites too, and clean mods are what inspired me. Thanks for the comment!
    Thanks!
    Haha, thanks!
    Thanks =D
    On the cap it's just straight out of the can, so it's matte.
    I clearcoated the HDD-Rack afterwards with 3 coats. Hence it's shiny!
  20. Rotcrack
    24 Jul 2009
    Keep going... Whats the next step? :D
