Project:Rise Lord Vader (FKA RLV) Update 12/7/06
Discussion in 'Project Logs' started by best49erfan, 2 Sep 2006.
  1. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    Small Update. The DVD Drive is here. It was finally in Stock. I am not trying to figure out exactly how to mount it. I ordered bolts. It cost $21 for 200 bolts and I only needed six. Oh well. It was cheaper than just ordering the six. The AC adapter is also on its way.....Which brings me to my next question. can I boot the PC with no ram and get to bios??????
  2. ChiperSoft
    ChiperSoft What's a Dremel?
    27 Aug 2006
  3. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    looks like vader's helmut from a costume.
    nice
  4. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    AFAIK - no.
    Great project, interested to see how this turns out!
  5. best49erfan
    27 Dec 2002
    Somewhat of a big update. It has been a while since I updated the log, but a good bit of
    work has been done. It may not seem like much, but it was very time consuming. I had to do
    a lot of measuring and designing and remeasuring and redesigning.
    Also the AC adapter is here.
    First off, somehow I broke off the power switch! So now I have to solder up another
    Broken Switch
    After some careful measurements, I managed to figure out how to get the DVD drive in. There
    is only 3mm clearance between the DVD drive and the PSU and the PS2 header. First thing to
    do was to remove any plastic in the way of the drive.
    Drive Area Cut
    Then I drilled some holes in the remaining plastic to mount the angle that will be
    supporting the drive.
    Holes Drilled
    The next item of business was to cut out the slot for the DVD drive. Originally, It was cut
    to only show the slot where the disk goes in, but there was no access to the eject button.
    After some thinking, I did not see a reason to use the eject, so I went on with the cut and
    thought that I could drill a hole later for the eject button and glue something to the
    existing switch later. This was all going to plan until I decided to change to a blade with
    less teeth on the coping saw that I was using. I changed the blade because the fine tooth
    one was getting clogged up. This resulted in changing plans to cutting out the entire space
    for the whole bezel of the drive.
    Drive Area Cut
    Some angle was cut and drilled to mount to the plastic to support the DVD drive.
    Angle Made Up
    Another problem with the drive was that with the case open, the drive needed to be mounted
    in the upside down position so that when it was closed, the disk would be entered with the
    label side facing the user. This posed a problem because one edge of the drive had the
    mounting bolts near the bulk of the drive using M2 bolts. this was resolved by making an
    adapter plate that used the existing mounting holes, but moved the new ones to the edge of
    the drive.
    Adapter Plate
    Now the adapter is bolted in place.
    Adapter Mounted
    Some more angle was used on both sides of the drive for the actual mounting of the drive.
    Side 1
    Side 2
    Here is the drive in place. In the bottom left corner of the drive, there is a machine
    screw that is screwed into an existing hole in the plastic.
    Drive In Place
    The final part was mounted using the angle. All of it was bolted with M3 bolts.
    Drive Mounted
    Now it is time for some tidying up of the case. There are just too many wires everywhere
    that will no longer let the case close. I cut a patch out for the IDE cable for the DVD
    drive and drilled some holes below it for some zip ties.
    slot Cut and Holes Drilled
    Eureka! The light bulb above my head glows dimly. I got the idea to run the front panel
    switch wires in the holes also!
    Cables In Holes
    Now the IDE cable is installed
    IDE Installed
    Yet more holes are drilled and some of the power wiring is zip tied. This keeps it from
    being pinched when the case is closed
    Power Wires Zipped
    Now the IDE cable is Zipped
    Drive Side Of Cable
    Motherboard Side Of Cable
    That is it for now!
  6. elliod
    elliod What's a Dremel?
    1 Oct 2006
    wow man amazing project man .
    keep up the good work .
    (subscribed)
  7. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    nice cable management!
  8. best49erfan
    27 Dec 2002
    Thanks a lot!
  9. best49erfan
    27 Dec 2002
    Just a quick note. The final three hardware components: Memory, VGA cable, and Audio Cable are on the way!
  10. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    hey where did you get that slim line adapter?
  11. best49erfan
    27 Dec 2002
  12. best49erfan
    27 Dec 2002
    Wow! Christmas is coming soon and I need to finish up soon!!!! Good thing I have been working on this! The best news is ALL the parts have been ordered
    and have arrived. Now there are no more excuses (other than work)! What all has been done you ask? Well, here is a list:
    The Switch is fixed
    Memory installed
    The power adapter is here
    The VGA cable has been mounted
    the audio Cable is installed
    The Vader audio toy is installed
    The Bottom fan has been "fixed"
    And one more item has been done....will see that in a little bit!
    First off, the switch has been replaced. Thanks again to Dwayne for his awesome soldering work! Go D-Rock!
    Switch Fixed
    The memory is installed. This part was very labor intensive!
    Memory installed
    The power adapter. Not much to say about this one other than I plugged one end into the wall and the other into the back of Vader
    The VGA cable was a much harder job than the DVD drive. I tried to lay it out just like the IDE cable for the DVD drive, but it is so stiff that it just
    forced the case open in areas when it was closed. I managed to figure out a way to route it, but it blocked the bottom fan a little. There was no other way
    that I could figure out how to do it. Anyway, I mounted the template that I made out of some scrap steel. This was then mounted and the hole cut out. Then
    the cable was installed in the case.
    VGA Cable- I did not want to take the zip ties off of it for a real pic because of how difficult it was to make it fit!
    Adapter installed and hole cut
    Cable Routed
    connected to motherboard
    Mounted inside
    Mounted outside
    Now the audio cable was relatively easy. The only issue that came up was it was a little long. There was plenty off room above the top fan to route the
    excess cable.
    Hole cut
    Cable Routed
    Plugged into MOBO
    Back of Case
    PICTURE COMING SOON
    Inside Case
    Remember that Vader toy that says all the phrases from earlier in this log? Ahh, good! The idea was to install another switch for this to run
    independently, but I really didn't want to add anything else that would be excessive. so, instead, the reset switch that was already installed would be
    used. Of course, this means there will be no reset switch. But how often is one used? Not too often.... First step would be to figure out where the
    speaker would be mounted. I decided to mount it where his mouth is. Then some holes were drilled to allow some sound to pass through. They are small
    (1/16") holes and not too many. Next was to extend the wires for the switch and the speaker. I just used some CAT5 wire and soldered it. Afer this, the
    box containing the batteries and the circuitry was taped with black electrical tape to cover the old speaker and switch holes. The velco that was meant to
    mount the toy on the dash was taped to the bottom front of the case for ease of removal to change the batteries. The plan is to hot glue the speaker in
    place after the case is painted.
    holes Drilled
    Wires extended
    Box taped
    PICTURE COMING SOON
    Velco mounted
    PICTURE COMING SOON
    Speaker mounted temporarily with tape
    PICTURE COMING SOON
    Box mounted
    PICTURE COMING SOON
    The bottom fan issue was the fan blows in the case. It was sucking the screen into the fan blades and making noise. I tried to no avail to make a guard out
    of plexi, but it did not look good. Some expanded metal was installed.
    Fan fixed
    PICTURE COMING SOON
    So you ask yourself, "where did that vader go that was on that sound board?" Ah! The original plan was to give it to my son as a toy. But noooooooo, it
    had to be included in the project! So, I took some bolts and drilled some holes in the sub. These holes were tapped and the bolts were installed. Vader
    was mounted using the existing holes on the bottom.
    Bolts
    PICTURE COMING SOON
    Vader's holes
    PICTURE COMING SOON
    Vader on Sub
    PICTURE COMING SOON
    WOOOOOOO HOOOO!!! The hardware is done! I loaded Windows Vista RC1 on it. It installed fine. The first item of business was to see how it would handle a
    DVD movie. FAILURE!!!!! Vista had used 55% of the system memory before media Player could even play the movie. This is because it has the onboard video
    and reduces the system memory. vista is graphically taxing and this little board just can't handle it. With that said, Windows XP Home was installed as was
    PowerDVD. Fast and the Furious Tokyo Drift played just fine.
    As sad as it is to say, this is the end until the paint job is done. With that, I have some questions for you BTers!
    What kind of primer and paint should I used?
    What can I put around the DVD drive to fill the holes? It needs to be smooth and paintable.
    Can the paint be clear coated?
    I will post a video of the PC booting soon.
    QUICK NOTE; THE PICTURE COMING SOON MEANS I RAN OUT OF SPACE ON FLICKR. I HAVE NOW MOVED IMAGES TO MY OWN SPACE, BUT I NEED TO RESIZE THE IMAGES.
  13. best49erfan
    27 Dec 2002
    I did update this thread, but since there was no new post, it was not noticed.
  14. zhangmaster12
    11 Jun 2006
    to fill the holes how about BONDO?
  15. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    You should use some plastic polish (novus etc) at the end to give Lord Vader a nice scratch free shinny shell :)
  16. best49erfan
    27 Dec 2002
    is bondo good for a someone who has never used it?
  17. best49erfan
    27 Dec 2002
    should i do this instead of painting?
  18. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    I would. IIRC that kind of plastic doesnt look too good when its painted.
    Looking sweet. Vader F T W
  19. best49erfan
    27 Dec 2002
    F T W?????
  20. THEkorean
    THEkorean 42
    10 Jun 2005
    bondo is pretty easy stuff, just dont mix ALOT at once, just enough for your job, and dont put too much hardener in or it will harden insteantly or get chunky
