Project:Rise Lord Vader (FKA RLV) Update 12/7/06
Discussion in 'Project Logs' started by best49erfan, 2 Sep 2006.
  1. best49erfan
    best49erfan New Member
    27 Dec 2002
    ok, so i should use plastic polish instead of painting and use bondo to fill in the gap around the DVD drive. So that leaves me with one question.....how should i paint the bondo?
  2. floppyeardbunny
    floppyeardbunny New Member
    4 Jan 2006
    first time seeing this thread and love your case idea. I am truly a Star Wars geek though. I had the case figured out from the first internal picture you took where you were cutting out the dividers. I have the same case in storage at home. hehe.
  3. best49erfan
    27 Dec 2002
    Thank you!
  4. 1e8o
    1e8o New Member
    13 Oct 2005
    I wass thinking of an sort of the same project. Now i can watch your good ideas :p
  5. best49erfan
    27 Dec 2002
    where can i get the plastic polish? I was also told bondo heats up and could melt the plastic????
  6. best49erfan
    27 Dec 2002
    Anybody????.
  7. Evenge
    Evenge Member
    16 Sep 2006
    Unfortunately I don't know anything about plastic :( , but I love your idea! Vader is a cool star wars character! :D
    Keep up the good work! :thumb:
  8. best49erfan
    27 Dec 2002
    Thank you!
  9. zhangmaster12
    zhangmaster12 New Member
    11 Jun 2006
    maybe wait for bondo to cool? it should stay workables for some time. er dont mix it on vader either. im kinda beginner bondoer 2. i have some never used it for plastic.
  10. best49erfan
    27 Dec 2002
    i still want to know where to get some plastic polish
  11. zhangmaster12
    11 Jun 2006
  12. best49erfan
    27 Dec 2002
    Ok. I have not quit on this project. I actually tried the plastic polish, but it did not work. I have some krylon fusion gloss black paint, but it is still too cold to paint right now. I also bought a glue gun for the speaker. So, when the temp stays above 50F, I will get back to this!
  13. best49erfan
    27 Dec 2002
    Well, well. I know everyone thought this fell of the face of the earth. but nah. I tried sanding the case and painting it. Bad results. The wife has been on to me about it and said fix that later and let the kid have his PC. So, it is up and running. I will get some pics soon. I am thinking about building another.........
