Case Mod - In Progress Project: Rogue (NZXT Rogue SFF) It lives! Aug 13, '08
Discussion in 'Project Logs' started by craigbru, 28 Feb 2008.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Thanks! The brake cost me $33 from Northern Tool. It would have been worth it at twice the price...
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_34995_34995
  2. craigbru
    28 Feb 2008
    Thank you very much. I loved the case and it's potential from the moment I saw it. In fact, it was because of a comment to that fact, that I made over on Hardforums, that led to this whole project. Johnny (from NZXT) saw the comment, and made me an offer I couldn't refuse... :thumb:
    No problem man. Good luck with your project! :dremel:
  3. craigbru
    28 Feb 2008
    I'm on a roll tonight! I've got lots to do yet, including some more fabrication, but I thought I'd get a few assembly shots posted.
    Since the side panels will be illuminated, I had to drop CCFL's in the lower sides of the case. These things fit like a glove...
    Next up, I attached the radiator mounts in place.
    Mounting the reservoir...
    The LCD mounted...
    Front panel back on, and gauges in place...
    Bulgin switches mounted...
    The work continues...
  4. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Looks wicked, keep up the good work on this beast! :D
  5. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Oh man...I just drooled on my desk :lol:
  6. mr00Awesome
    mr00Awesome YEAH SWEET LEMONADE
    23 Jan 2008
    I like the metal-flake paint. Is that automotive grade or from a spray can?
  7. MrWizard
    5 Feb 2008
    :thumb:
  8. Nix
    Nix What's a Dremel?
    22 Nov 2005
    This mod is coming along fantastically Craig. Probably been asked or said before but what material you using for the internal chassis?
  9. Supra55
    10 Oct 2006
    Night shot pleeeeeeaaaassseeeee? :lol::lol::lol: :hehe:
  10. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    This continues to look fantastic!! =D I notice that you had to take a piece out of the reservoir because of the case top. How much clearance do you have there now?
    @Nix: If it's the HDD tray you are referring to, then it's 2mm alu. =)
  11. craigbru
    28 Feb 2008
    Multi-quote Cheesecake! :rock:
    Thanks guys! Of course I'm biased, but I'm really loving the way this is pulling together. It all started with a vision in my head. You never really know for sure if it's going to live up to your expectations. So far, this case has exceeded them... :clap:
    Yep, good ol' Rust-Oleum... I think I'm only an average spray painter, but quality spray paint is a must. Don't go cheap if you want it to look nice. Believe me, you will notice a difference! Also, all parts were baked immediately after being painted. 200 degrees for 30 minutes, then 170 for an hour. As long as you've done decent prep work, and your parts are clean and dust free, the finish ends up rock hard and almost automotive quality.
    All interior parts are 1 and 2mm aluminum.
    Oh, it's coming. Be patient my friend... :D
    Yeah, I did need to take a little material off of the reservoir. I dremeled it out, then flame polished the edge. I suppose there is about 2mm clearance between the reservoir and the top of the case.
    Yep, 2mm it is!
  12. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Its looking great as you already know from all the praise youre getting on the forums but i just thought id tell ya again! immense project!
  13. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    those shots actually made me check if i had placed my vote for MOTM on you. I was afraid i made a mistake and selected some1 else :worried:
    No worries though, you had my vote a few weeks ago. Very nice realisation of your plans :clap:
  14. Elio
    Elio What's a Dremel?
    4 Oct 2007
    I cant wait to see this finished!
    this is going to be unbelievable !!!
  15. x06jsp
    2 Apr 2007
    you get my vote aswell
  16. craigbru
    28 Feb 2008
    Just a quick update here before I get to work tonight... The fan grills have arrived! I don't care how wrong it is... These things turn me on! :rock:
  17. soulliea
    soulliea What's a Dremel?
    2 Apr 2008
    yikes those look terrible... ;)
  18. Matticus
    Matticus ...
    23 Feb 2008
    holy hell! :jawdrop:
    They look beautiful, the end ones remind me of CD players with the clear glass/plastic lids. Just about the perfect size for it too.
    Also funny you saying "before I get to work tonight", I am just about to grab a cup of hot something and get to bed!!
  19. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Looking soo good, really come together in the last couple of updates, cant wait to see it finished, keep it up!
  20. craigbru
    28 Feb 2008
    I'm on to mounting the grills, and just had to show you guys what it looked like. I think I should have done these last... 'cause I keep getting lost in the red anodized dreamy sweetness...
    These stickers gotta go...
    A little sleeving...
    The six-pack...
    This picture needs no explanation...
