Case Mod - In Progress Project: Rogue (NZXT Rogue SFF) It lives! Aug 13, '08
Discussion in 'Project Logs' started by craigbru, 28 Feb 2008.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Thanks phinix, and everyone else! Yeah, I really don't want to know how much money I've spent either... :jawdrop: It's something I love though, and it makes me happy. So why not? Don't just live it, mod it!
  2. -Nick-
    -Nick- What's a Dremel?
    23 Jan 2008
    wow awesome looking, can't wait to see more, very impressive
  3. craigbru
    28 Feb 2008
    Time for another update! I've made some pretty good progress in the past few days. What have I been doing? Making holes... Big holes, little holes, rectangular holes, and round holes... I'm starting to dislike holes a little. I'd much rather be fabricating, but it all starts with those dang holes.
    In my last update you saw the work I did on the DVD drive slots. So, I'm picking up right there. With the slots completed, I needed to make a hole for the eject button. You'll see that I made the hole larger than the button itself, but there's a very good reason for that. I'll go into detail on that a little later, but for now, you can see what I have so far.
    Now I need to make the holes in the front of the case for the gauges. This whole process has been a little time consuming to say the least. There are technically 3 layers I need to make holes in. It starts with the door, then the front of the case, then there's another panel behind there yet...
    One hole done, another one started.
    It's a perfect fit!
  4. craigbru
    28 Feb 2008
    Well, it's time to get the hole made in the face for the LCD screen. Here I've got it marked out and ready to cut.
    After the cutting is finished, a little filing and sanding gets things in to shape...
    The LCD drops right in place.
    More holes you say? Of course! Here I've marked out the hole for the Matrix Orbital display.
    Another cut, file and sand completed.
    At last, I move my way to the inner most panel. Here it changes from aluminum to steel. It's thinner though, and the cutting should be easier. Instead of dust, I'm gonna make sparks. In this picture, I've already got the holes for the Dakota Digital gauges made.
    Now finally, I do a little work on the Matrix Orbital display housing. Naturally, this thing isn't going to be sitting a bay as it was designed to. That's where a little modification comes in. Here I've got the mount marked, and ready for cutting. The left pencil line is where a bend will be, the right line is where the cut will be.
    After it's cut and bent, this is the end result.
    More coming soon...
  5. Fyve
    Fyve What's a Dremel?
    4 Mar 2008
    Are you using a dremel for all of the cuts? Awesome work!:dremel:
  6. craigbru
    28 Feb 2008
    Yeah, I use a Dremel for almost all of my cuts, with the exception of the round holes. I'll use a hole saw for them. I do have a jigsaw I'll occasionally use, but it's rare, and I only use it when I think the Dremel is to hot to continue cutting. I added the tag 'Dremel Killer' under my name, because I tend to be a little hard on them... :D
  7. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    very nice mod ......... :thumb:
    great work put into it , actually it did kind of hurt to see you
    cut out the beautiful side panel grills , but the new grills with the red
    plexi sandwiched that you added there does make up for "destroying" :hehe: the original ones.
    I love the digital gauges and the Matrix Orbital display.........it will look very good :thumb:
    Alan
  8. craigbru
    28 Feb 2008
    Yea, it hurt me to cut into those grills as well. At the time I got the case, there were only two in existence. I believe this is even the case they used to take the product photos. So, Johnny was sure to tell me that if I screwed something up, there wouldn't be replacement parts available for a while. That first cut was a little stressful...
  9. rodeo45
    rodeo45 Who's your daddy ???
    4 Mar 2008
    That's what I call a MOD! Those cuts are pretty pro I say! That project must cost you a lot, but it's worth it. Damn good job, pleasure to watch Craigbru!
  10. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    interesting..... lets see what comes of this, BTW were did you get that pico-itx?
    edit: and where do you get those screens?
  11. craigbru
    28 Feb 2008
    Thanks! I bought the Via system here.
    The Matrix Orbital screen was bought directly from Matrix's site. The 10.2" screen was bought from an electronics supplier. They don't sell to the general public though. If you want more details, PM me...
  12. Jipa
    5 Feb 2004
    I tested the Rogue a while back and noticed that a full ATX board could be easily modified to fit in there... But oh man you're doing it with style! Crazy amount of stuff going in there, can't wait to see how you can make all that stuff fit. Interesting fans there, I've always thought all the 35 mm versions are noisy as hell and mainly ment for some server use where only CFM and reliability matters. Also interesting to see how the peltier performs, haven't seen one of those in action for years! Keep up the good work.
  13. DXR_13KE
    14 Sep 2005
    thank you, when need arises i will PM you.... but i am mostly sure that it wont do any good.... i am in the middle of the ocean and you are over there in the US were you can get anything from your local store :waah:... again thanks :thumb: and yes, i will keep an eye on the progress of this mod.
  14. craigbru
    28 Feb 2008
    Man, I love updates! Updates mean progress is being made. It's a little bittersweet though. I can see the end in sight, yet building is so much fun. I don't want it to end, yet I have other projects (home related) I need to work on.
    With my last update, I was still making holes. With this one, I'm still making holes, although they'll be a little smaller in the end. To start here, I needed to finish the hole in the frame for the widescreen LCD. Luckily, there really wasn't that much cutting involved.
    Now, here is a shot with the LCD's and gauges sitting in place.
    Okay, now that's out of the way. So, what's next? Well, I need a fan controller. Not just any fan controller, I have a Zalman ZM-MFC1 Plus.
    Okay, that's a fine controller you say, but where the heck am I going to put it? If you've been paying attention, space on the front of the case is at a premium. That doesn't mean I'm out of room though. In fact, far from it. However, it's not exactly a 'drop in' procedure. As with everything else so far, a lot of cutting and modding will make it fit.
    Well, let's get on with it! Here you can see where the controller will sit.
    That brushed aluminum face sure looks nice, but it's gotta go.
    Here I've got the holes for the knobs marked out and ready to drill.
    The holes have all been drilled, and the fan controller is test fit in place. Everything seems look good. You can see how the LED's in the fan controller will show though the hole in the case.
    To be continued...
  15. craigbru
    28 Feb 2008
    I'm going to get sidetracked for a quick moment here. While working on the face of the case, I thought I'd take a little time to make the holes for the Bulgin switches that will find a home there.
    All marked out...
    Here's the secret to getting great large holes. Only a nice step drill bit will do. They're not exactly cheap, but they're worth every penny spent.
    Moving back to the fan controller, this picture shows you a little bit of the problem I've got to work out. The inside frame on the case is in the way. Well, not for long... A few holes and filing will take care of the problem!
    More coming soon.
  16. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    that's a great spot to put the fan controller! i like how the leds are perfectly aligned with the hole in the front panel now.
  17. craigbru
    28 Feb 2008
    Thanks! I've been pretty lucky so far. Everything I've wanted to include, has fit. Well, 'fit' is a relative term here. Everything has fit with some modding, but that's different than simply not having enough room at all.
  18. craigbru
    28 Feb 2008
    Although not directly modding related, my new motherboard has arrived... I'm not sure on the processor yet, but I do have two new sticks of 2x2GB Mushkin DDR2 Redline that I'm going to drop in here.
    I can't wait to get this thing up and running. The fact that I've now got almost every component I need, only makes me realize that I'm very close to pulling this whole project together. From here on out, I shouldn't have to spend my time picking out parts, and wondering what I yet need or want. I've got to take what I already have, and a find a home for all of it. Only a little over a month to go!
  19. Guest-23315
    Guest-23315 Guest
    I thought that this was an mATX case?
  20. craigbru
    28 Feb 2008
    It is...:D That's why I had to mod in a new i/o panel on the rear of the case. :dremel:
