Modding Project s^2
Discussion in 'Modding' started by Da Dego, 3 Sep 2004.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Ok all, the plexi is here, some of the LEDs are on their way, and the pics will be going up starting this weekend (I hope!). I'm starting on building a new case from scratch!
    It will start out as a simple dark-tinted acrylic cube, 12.5" each way (which is a bit larger than my last build, which measured 10.5") edged with polished aluminum. It will look a little more unusual, though, as the motherboard will be suspended in the middle of the case, and the (majority of the) drives on the bottom. It will also contain a minimum of 6 fans, at least one of which will be piped directly to the processor to give that breath of fresh air. Finally, and the whole reason that I'm building instead of just modding, I wanted much better access to my components...so the case will include a rather unique way of opening that should make everything easily accessible with no "tight fits."
    Once the case is built, the modding will begin (well, I wonder if it's modding if it's a custom case to start?). There will be a custom rheobus built into the case to control all of the fans, along with a few temp sensors and a backlit LCD screen. UV lighting and super blue LEDs will be plentiful. And, when my electrical engineer friend and I get done, there will be a custom built peltier unit that takes away a lot of the dangers of TEC cooling.
    I hope you all will offer comments, ideas, and criticisms as I build this thing...It's been a while and the technology and techniques have changed a bit on me! :)
  2. Chimpz
    Chimpz What's a Dremel?
    22 Aug 2004
    Sounds very very promising man. but mine will be better... just kidding! :D guess that's a good time to thank you for helping me with my questions :thumb:
    i'm definately looking forward to some pics.
    Good luck!
    :dremel:
