Case Mod - In Progress Project S - Suspended Indefinitely
Discussion in 'Project Logs' started by B[x], 4 Jan 2007.
  1. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    I mentioned before (at least I think I did) that everything will be sanded down and repainted later on. I'm not in a rush to finish this project so that will be farther down the road.
    Thanks, CK.
  2. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    that's one good looking front, great job on that :thumb:
  3. exitus
    exitus What's a Dremel?
    25 Apr 2007
    oops, must have been too quick in reading there. my bad :D
  4. B[x]
    3 Jul 2006
    Thanks, Bas. On a bit of a side note, the quote in your signature has always made me laugh.
    No problem, Exitus. I know I'm guilty of just glancing at the pictures when breezing through most logs.
  5. Dira
    Dira What's a Dremel?
    1 Sep 2005
    The mix of black, silver & plexi is very nice on the left side there :) Still there is something missing. Can't put my finger on it :) But I just feel it ;) Keep up the good work mate!
  6. B[x]
    3 Jul 2006
    I have yet to finalize my paint scheme. While the case itself will be black, I'm undecided when it comes to the interior as well as the aluminum overlays. I might paint the interior black and the aluminum overlays white, thus ridding the case of silver/gray. This coloring would probably be accompanied by blue lighting.
    Any suggestions or comments are welcome.
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks amazing, great job!
  8. Lupo_IM
    Lupo_IM ItaliaModding staff
    30 Jul 2007
    great work!!! ;)
  9. TeChY_07
    TeChY_07 New Gaming Rig Underway!!!
    4 Aug 2007
    in the sketchup model, did u make that mb model yourself or did you get it off of sketchup internet thing?
  10. ComputerKing
    8 Sep 2006
    Update Come on!!!!!!!!!
  11. B[x]
    3 Jul 2006
    Thanks guys. I just recently returned from working out in St. Louis for 3-months. In that time my motivation for this project has waned, unfortunately. In addition to this, I feel like I was too ambitious for my first case mod. I should have started off with a few aesthetic changes rather than trying to alter the case's structure entirely. This project is now on a temporary hiatus.
    However, while out in St. Louis, I worked on a design that I'm very excited for. It has room for four HDDs, a full ATX motherboard, the largest of GPUs, an optical drive, and a PSU. All of this is crammed into a SFF-sized case. Since I said I was being too ambitious with my previous mod, it may seem hypocritical to be making a scratch build. However, I'm sure that this build will require less work than Project S. Hopefully I'll be able to start work on this in the next couple months. Here are a couple shots.
    [​IMG] [​IMG]
    I pulled the motherboard off of Jazzle's site.
  12. Brett89
    Brett89 Minimodder
    15 Dec 2005
    awww, I'm sorry to hear that, but from what I've seen, you'll do that new case justice, I loved the style of the windows and touches you added to the S mod. Good luck!
  13. Teyber
    Teyber ******
    18 Mar 2007
    sorry to hear that too. My first mod was a scratch build, and i can safely say its not a disaster lol(rtx). and i have confidence in you!
  14. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I'm guessing you're throwing in the towel because of the bondo and I can't blame you if that's the case. Bondo is a biotch! But I like the new project as well. Maybe you could send the case out to a fellow modder who could help you out with the trouble area? I know I'd be down but I suck with bondo lol. I'm more of an aluminum/plexi guy hahah
  15. B[x]
    3 Jul 2006
    Thanks for the vote of confidence, Teyber.
    Fozzy, I actually had a lot of fun with the Bondo; it was a lot easier to work with than I had imagined. I just don't look forward to the steps that lie ahead in this project. Knowing what I have to do, I get the feeling that the case won't have a clean look when I'm finished with it. It just got to the point where I decided I'd be better off cutting my losses than sinking more money into the build and winding up with something I wasn't satisfied with.
  16. ComputerKing
    8 Sep 2006
    That design sounds amazing, Can't wait to see it. Brother Go on on the S project I want to see it done. Come on.
    Good luck
  17. B[x]
    3 Jul 2006
    Sorry to disappoint, CK. Like I said, I just don't have it in me at this point to carry on with Project S.
  18. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Sorry to hear that you are not going to complete the case, because that S window was one of the nicest case windows I've ever seen. How ever I think the front looks alittle bit to simple compared to the advanced structure of the S window. I think a similar holow S design on the front would fit nicely.
    I totaly understand the lac of motivation if it doesent feel right. It happens to mee too often too. I can spend hours and hours on something and then i just throw it away cause it's not perfect. You could always try to solve it by taking the pieces you like and start all ower from there.
    Anyway god luck no matter wich case you'll finish.
    /GNU
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    Your new design looks great, do let us know when you start a thread for it.
  20. ComputerKing
    8 Sep 2006
    Dam!! It was a kickass case and with the first letter of my name :( I'm sad, sorry to hear that but I was the best, The front and the side was amazing.
    Any way the new case look hot too, wait to see it in action :D update me soon, Good luck
