Project :: SeRvEr :: ** Added Some Nice Candy Shots **
Discussion in 'Project Logs' started by CharlieCat, 26 Jun 2003.
  1. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    CC.
    Where did you get that tubing and corner pieces from...?
    Can't wait to see the updates..Keep us posted....
    It :rock:
  2. ernie
    ernie New Member
    27 Jan 2003
    sweeeeet!
    130gigs of music...
    i thought i had alot with ~10gigs
  3. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    And here I am thinking my ~500mb is beefy, not anymore :waah:
    Those Maxtor drives are nice (I have 2x 160s as well), but they do run a bit hot. I had to move a fan into the front of my case to keep them from overheating :(
    Looks like a great project :thumb:
  4. RaptorLord
    RaptorLord New Member
    6 Aug 2002
    Your frame and your layout are top notch! when I saw the pic of the TFT mounted in the frame I was like :jawdrop: ...
    Your choice of skinning material suits you I hope - I personally don't care for the look of patterned metal.
    What do you have left to do? - it looked pretty complete in the last shot...
  5. CharlieCat
    CharlieCat New Member
    12 May 2002
    Thanks for the comments guys...I'll do my best to answer your questions.
    Iamgoodyy Thanks...all my cases seem to end up having a smiley face...I guess it's 'cos I like symmetry. I only added the top fan over the PSU to even things out...I don't think it's really needed.
    RAMeLaiR Cheers mate :thumb:
    olv Thanks...it took an awfull lot of filling to get it to that stage.
    fivecheebs If only I'd have had my magic torch it might have been a quicker job :D
    Cyberbob:) Thanks mate...I too can't wait to fire it up :p the steel tubing came from B&Q and the corner joints I ordered from a company called Ross Handling. They have a minimum order value but it's pretty low.
    sinizterguy Cheers...I used the blanking plate from the shuttle case as a template, then roughed it out using a drill with various sized bits and finished it off with lots and lots of filling.
    bard Thanks...TBH I do not know if the airflow will be enough but it should be. As for colour I am thinking green...or maybe blue..or possible red. Hmmm...decisions...decisions. What do you think ?
    pranks7er It took my about 3-4 hours of messing around with SketchUp and going through the tutorials before making a start on the model of the case. So...yep it's pretty easy.
    ernie 130gigs and growing. I have ripped all of my own CD's and download approx 1-2 albums a week of the net :naughty:
    Yo-DUH_87 Yep they do run a little hot hence placing the 120mm fan directly in front of them.
    RaptorLord I too was unsure about using the texture stuff again but I had lots let over so it seemed daft not to use it. I was planning on painting the whole thing black but am not sure now.
    Still To Do
    I have quiet a few small jobs let to do. The main structure is now complete but I have to:
    Mount the VFD
    Obtain 2 more 80mm fans for the top
    Decide whether or not to trim all the cut outs with blowhole trim
    Finish the PSU
    Sort out a fan controller
    Decide what to do about the cutout for the DVD/CD-RW
    Work out what colour lighting to use
    Wire up the TFT to both power and VGA
    ...and some other stuff that I can't think of right now.
    Cheers, CC
  6. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    I could have lent you mine mate. Let me know next time you need one and ill email it to you :lol:
    For what its worth. I like the idea of it painted black, or maybe that anodized look paint i saw someone mention around here. I dont like that plastic blowhole trim much but thats just me. Your cuts look really neat so why hide them.
    Looking forward to the rest mate.
  7. Hiren
    Hiren mind control Moderator
    15 May 2002
    Dude that looks amazing. Although doesn't that huge Zalman heatsink take up most of the room inside the back of the case?
  8. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Congrats nice work :)
  9. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    Can't wait to see the VFD. I bet that will look sweet....:cooldude:
    Where can i get some 2mm thick aluminium from in the uk. Most i've looked at only been 300mm wide. I need it a little wider than that.......:clap:
    And again nice work......:D
  10. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Yeah, that VFD is gonna be such a nice touch. I have to say the metal tread worked so much better than i thought.
    Great work!!! :thumb:
  11. olv
    olv he's so bright
    23 Sep 2002
    obtain u say :worried: hehe
  12. pcjabber
    pcjabber New Member
    24 May 2003
    :clap: :rock: :hip: :jawdrop: :jawdrop: :thumb: :dremel: :cooldude:
    Sorry for the all smilie-post, but I am speechless! the :jawdrop:s explain it all =)
  13. Neema12
    Neema12 New Member
    13 May 2003
    Where did you get the screen from, plz explain... Thx
  14. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
  15. Ouches
    Ouches New Member
    27 Jul 2002
    He had said earlier that he salvaged it from a flat panel display he had purchased on ebay.
    Gotta love the backround in your desktop screnie =P.
  16. Neema12
    Neema12 New Member
    13 May 2003
    I ment from from a flat panel display, or a desktop moniter? What type?
  17. Jivecat
    Jivecat New Member
    26 Feb 2003
    Do you have any pics of when you were bending the top/side panel? I would like to understand the process more. It looks very nice!
  18. CharlieCat
    12 May 2002
    Just a small update...will answer questions later :D
    Was not sure about putting blow hole trim around all the openings but after spending a hour or so wrestling with the stuff it's on and looks tops :rock:
    It seems to highlight everything nicely and makes the metal work stand out more.
    I am now toying with the idea of sticking these handles on the top of the case...what do you guys think.
    Cheers, CC
  19. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    Nice ! ! !
    That blow hole trim really does finish it off....
    And yes the handles on top really does add to it....
    I'd go for that.
    Got my documentation today from ross handlings......My turn next. Not yet thou going on hols first, will start it when I get back hopefully. Also hoping to buy a digital camera while i'm away.
    Keep up the good work.....:D
  20. [twig]clown
    [twig]clown New Member
    1 Jan 2003
    OMG at the work and look of this server. Most people hide there servers in a corner. That would be in the middle of my front toom for people to oogle at! Brilliant work. Very nice modern industrial look. Love the idea of TFTs in cases, just wish i could afford one :(.
    -cLoWn
    P.S. 130Gb of mp3s :jawdrop:, thought my 20Gb was nice. Care to share?? :D :D
