Case Mod - In Progress Project SH-B
Discussion in 'Project Logs' started by CircularCore, 28 Apr 2016.
  1. CircularCore
    CircularCore What's a Dremel?
    6 Feb 2015
    Here I am again after a grueling summer session. :D
    I again thank Aquatuning / Alphacool for a new full package of fittings:
    Here I created two holes 20mm on midplate for bulkhead, finally I connected two adapters g1 / 4 Rotary.
    Finally I started with the first test, of course inside missing several pieces, as you can see the fan controller was placed on the MB tray.
  2. CircularCore
    6 Feb 2015
    MDPC Sleeving :D
    [​IMG][​IMG]
    Inviato dal mio LG-H815 utilizzando Tapatalk
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I don't want to be an asshole, but you didn't crimp the wires as you should and also melt the sleeving tip at the correct point. You risk pulling the wire from the pin like that.
  4. CircularCore
    6 Feb 2015
    Thx for reply to my peoject... Don't worry you don't an asshole lol .
    Wires it's correctly crimped ,from the photos there is probably a wrong perspective...I already sleeve many other PSU ;).
    Update, 24 pin complete :
    [​IMG][​IMG]
  5. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    agree with Hukkel
    that one 'closest' to us looks like there is a gap between the wire's plastic cover and the part of the pin that has to go onto that cover
    the back blue also doesn't look like any of the wire cover is crimped into the pin
    how does that sleeve actually stay in place? must have had to melt quite a bit to have it stick to the plastic of the wire
  6. Vault-Tec
    30 Aug 2015
    +3. That is begging to pull away and show its ass crack.
  7. CircularCore
    6 Feb 2015
    I will check again the cables,and yes the blue it's not correctly crimped :( ,but the other are crimped correctly .... I repeat are not a neophyte of the sleeving :) I thanks everyone who intervened :D
    Today I do some test for check the correctly working of the 24 pin ;)
  8. CircularCore
    6 Feb 2015
    After much work we have come to the conclusion of this project :D
