Project: Sheet metal
Discussion in 'Project Logs' started by Xen0phobiak, 21 Jul 2004.
  1. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    This case is mainly for function over form, but the eventual finish will be satin black, with alu trim, and domed, stainless steel hex bolts.
    Its a 3 part construction, Bottom 1/2 & front, mobo tray, and top.
    Here is a link to what i'll be using in the top to cool the cpu.
    Here's a pic of the very early stage of the bottom section:
    Below its had a very quick coat of matt black paint to give it a more solid look to help me visualise/work on it:
    The whole lot will be sandblasted before finally being painted after all construction is complete.
  2. Xen0phobiak
    8 Aug 2002
    Minor Update.
    Cut some of the aluminium edging, test fitting 3 sections:
    Need a small amount of filing and sanding before bolting these peices in place, and working on the next peices.
  3. guy
    guy What's a Dremel?
    20 May 2004
    looks pretty sweet
  4. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    This looks interesting, quite big.. :D
    Hope to see more pictures soon!
    Good luck!
  5. Xen0phobiak
    8 Aug 2002
    Thanks guys. It is quite big yes. 480x480x400mm, the edging is 20mm wide each way.
  6. b!p
    b!p What's a Dremel?
    6 Jul 2004
    Why your paint for your case look's like this ?
    It's a big case, do you play in LAN's ?
  7. Xen0phobiak
    8 Aug 2002
    I do play in lans when i can yes.
    That coat of paint will be coming off before the case is finished. Its just to give it a solid look, rather than clear.
    The final finish will be satin black, with as good a finish as I can get.
  8. Mister_Tad
    27 Dec 2002
    oh he likes a big one :D
    looking loverly so far, you need to come back to nottingham so i can have my creative input as well though :)
  9. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    offtopic
    u moderators crack me up
    /offtopic
  10. Hiren
    Hiren mind control Moderator
    15 May 2002
    Good start Dan, though it needed bumping :D
    Q. What kind of paint are / will you be using for the satin black finish?
  11. Xen0phobiak
    8 Aug 2002
    Decided against satin now mate, long story (ish).
    cant be bothered with the perspex anymore, too much hassle, kept cracking etc..., so today i went to a builders merchants and bought a 1mx2mx2mm aluminium sheet, going to use that for all the panels instead.
    The finish will now be either:
    Sandblasted
    Brushed
    Gloss Black
    Hammerrite Gloss Black
    Most likely brushed :D
  12. Xen0phobiak
    8 Aug 2002
    A quick pic of a toy thats going in the front panel:
    Obviously the cd case will be removed, and the two small pcb's stuck to the back permanently.
  13. olv
    olv he's so bright
    23 Sep 2002
    Sweet :D
  14. Xen0phobiak
    8 Aug 2002
    Started the cutting of the aluminium today. By hand its more tiring than i expected, once its in peices small enough to fit in the car I can hopefully take it to a bandsaw :)
    Piccies later hopefully.
  15. Xen0phobiak
    8 Aug 2002
    Shineh!!! :D
    Thats a view from the "tool-mark" side, before i deburred the sawcuts. Hopefully I can do the rest of the cuts on a bandsaw now i can transport it.
  16. Xen0phobiak
    8 Aug 2002
    Thats what i meant by the tool-mark side, that was the more scratched side when i got it.
  17. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    omg ! that lcd is great!! it tells me all I want!! is it just a playstation screen?
  18. Xen0phobiak
    8 Aug 2002
    yeah, thats a PSone lcd.
    Im running samurize to overlay the info.
  19. Xen0phobiak
    8 Aug 2002
    been busy sawing and drilling today:
    Those two show the general "feel" of the case, once its complete
    The top and bottom panels.
  20. olv
    olv he's so bright
    23 Sep 2002
    it's coming along nicely! it's gonna be soo cool, super turbo blower fan power!
