Hey, it's not a COMPUTER mod, but still... Here's my amazingly cheap/crap CD player in all its glory (to give you an idea of how cheap it was, the CD cost more than the player....): (img) (img) Now to disassemble it... (img) (img) (img) (img) Next up - sanding off all that horrible silver coating stuff The plan is to spray the lid annd bottom part dark metallic blue, and leaving the middle bit silver. I'm thinking of maybe putting a window in it, but that could be a bit over-the-top. What do you all think?
Argh! Think your piccies need a slight resize chap! How about a window with an etch and an LED or two lighting it up? As long as you're using rechargeable batteries and not buying new jobs everytime, using a little more power should be fine. Although electronics isn't and has never been my forté
BioSniper/ouija: Yeah, Muse rock Anyway, small update - I've sanded the nasty silver coating off all the bits i'm gonna be painting: (img) (img) SO, that's progress then... Also, I've recovered my paint from Mount. Mess (my desk) (img) (img) (img) Next up: Primer..... The window idea's kinda difficult to implement due to the slight cure of the lid, so I'm just gonna leave it out :bleh:.
I'm wating for the garage to be empty so I can spray in there. Hopefully I should be able to apply the primer taday after school, though
