Project: Silence of The Fans **New Pics Mounted IR Reciver**
Discussion in 'Project Logs' started by Redwolf, 8 Apr 2005.
  1. mattthegamer463
    26 Nov 2004
    stupid pics are gone again. i suggest photobucket man, they work a lot better.
  2. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    After alot of thinking I decided to stick to the original plan an make the height of the case 1.5" inches. The only thing is like I said before that cd drive will be loaded from the leftside of the computer but that not a proble we put an eject button in the fron't and the tray will slide out from the side.
    I will not be using the logitech Amp heatsinks maybe for another project.
  3. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    I was bored and I had a pice of sheetmetal so I decided to make the bottom plate so I cut a 7.5" x 9.5" pice and I screw some motherboard stanoffs. I decided to go with all lexan case sheet metal just won't work.
    I mounted the hardrive ontop on the PCI ports.
    dvd drive moounted.
  4. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    I had to modify the 2.5 to 3.5 converter because when I connected the hard drive the power connector hit the ram.
  5. Jipa
    5 Feb 2004
    I dunno how is it possible to take that sucky-quality pics, but U seem to do that all the time... However project seems to get lowprofile and that's the point :)
    And that magazine looks worth of better look :p
  6. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Is that stuff magazine. I think i might have that copy lol.
  7. |3|ackAc|D
    |3|ackAc|D What's a Dremel?
    11 Apr 2005
    BOOOOBIES!!!!!!
    nice work btw
  8. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    can you take a copy of that magazine to me
  9. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Yeh the pictures are crappy but it's still good enough to see what you are doing.
    Keep up the modding dude, looking good so far :thumb:
  10. NoMercy
    NoMercy What's a Dremel?
    23 Nov 2004
    Well the background image seems to be in perfect focus for some of them :naughty:
  11. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    the reason that the quality sucks is that I didn't have money to buy a digital camera so I bought a $30 webcam. I broke my laptop and I bought another one for like $850 so I am broke if you guys don't like the quality please etheir donate a camera or donate some money other wise I will keep posting lowe-quality pictures.
  12. PhatMatt
    PhatMatt What's a Dremel?
    31 Oct 2003
    im with you redwolf, dont let spoiled kids like jipa with 3000 dollar cameras bring ya down.. im quite impressed with the low-profileness of the computer, i'll keep checkin in to see how its coming along
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    some webcams have manual focus on them - you should also check the minimum distance you can film from
  14. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    I was bored yet again so I did some modding.
    sinse mi IR reciver is serial you have a nasty cable but I wanted a clean look so I solder the wire to the motherboard and eliminate the cable.
    then I cut the IR reciver.
    thats it for now, have to go back to work.
  15. mattthegamer463
    26 Nov 2004
    looking good so far, might i suggest you find out how to get your camera to focus at close range? the blurry pics are kinda annoying.
  16. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    But the nice magazines used as modding field are very well focussed!!!! :D
  17. Bloody Mary
    Bloody Mary What's a Dremel?
    15 Apr 2005
    Man, ur the best picture taker ever :naughty:
  18. mattthegamer463
    26 Nov 2004
    ya, i like it too.
  19. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    This is probabli the last device that will go in after the dvd drive. I am just waiting for my lexan to arrive so that I can start the case.
    I mounted the IR reciver ontop of the parallel port.
    and I got some lowprofile ram .
    I know you guys hate the magazines :naughty: but I use them as mousepads or to protect the mobo. :D
  20. infered101
    30 Oct 2004
    Funny thing is you use a different magazine for each set of pictures. You go from catherine bell to daisy fuentes to carmen electra. That and you like to zoom in right where well there boobs are. This is just my watchful eye. HMMMMMM :D :D :hehe: :hehe: :eeek: :eeek: :naughty: :naughty:
