Scratch Build – In Progress Project: Silent Element! 15 JAN 11 NEW PICS!
Discussion in 'Project Logs' started by NavidsonRecord, 4 Dec 2010.
  1. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    Correction: I hope Na'ir al Saif makes it to (to MDPC)!!
  2. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    Looking good!
    Out of interest, how does the noise of the Corsair RAM cooler compare with the Noctuas?
  3. NavidsonRecord
    5 Jan 2010
    they are on a fan controller but the RAM cooler is way loud on normal speed and on low pretty much silent but doesn't push much air at all. All in all pretty bad compared to the Noctuas. Maybe once in my hopefully 100% silent case I can crank it so it dose its job without annoying the neighbors. :grr:
  4. NavidsonRecord
    5 Jan 2010
    The internal will slide out without the need to unplug anything but you will need to wait for me to start the internals before you know what I'm on about.
  5. gcwebbyuk
    16 Feb 2010
    Thanks for the info. I picked up a Zalman cooler second hand which was also noisy - a bit rattly is the best way to describe it, it ended up in the drawer and the RAM left to cool itself.
    Good luck with the build :)
  6. NavidsonRecord
    5 Jan 2010
    Today I'm getting a propane torch, 6m of right angle alloy, m3 tap, m5 tap and various bolts. Pics up when I get home!
  7. NavidsonRecord
    5 Jan 2010
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking sweet mate :thumb:.
    Earlier in the thread I was shocked at how thick the aluminium looked, must have been because of a zoom picture lol, thought it was about 10mm thick :D.
    Brilliant idea for bending the 3mm material, I've always had the mind set of if it's 1.5mm or more then I can't bend accurately.
  9. KidMod-Southpaw
    28 Sep 2010
    This is very abstract, taking shape well. What font are you using on your pictures?
  10. NavidsonRecord
    5 Jan 2010
    haha yea your comment before was like "WOW!! thats thick" I thought you were just being funny.
    the font is here http://www.dafont.com/jellyka-nerevan.d1166
    I stole it from Hannes here http://forums.bit-tech.net/showthread.php?t=196978
    Hannes I'm sorry, I feel bad :waah:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
  12. NavidsonRecord
    5 Jan 2010
    A small update where I started mocking up the internals.
  13. NavidsonRecord
    5 Jan 2010
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    My dad bought some of that stuff from a motorbike show a while ago, had an example weld & was an ultra strong fix, only way to seperate the pieces whould be to cut them off ;) but I bought the wrong gas to use it so wasn't getting hot enough for it to melt, should give it another try sometime, been wanting to get into aluminium welding for some time now.
    Looking excellent btw & good prototyping :).
  15. NavidsonRecord
    5 Jan 2010
    what gas were you using? I have propane but not sure if it will get the area hot enough cos the entire case acts like a heat sync.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Honestly I really can't remember, but I do remember when buying the gas there was 3 levels of heat & I chose the medium & had big trouble heating it up enough when I should have chose freaky hot lol, sorry for not remembering the gas type name.
  17. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    Mapp gas is hotter than propane. Maybe that's what Waynio is referring to.
    Nice project. It reminds me a little of Osidias by Craigbru.
  18. NavidsonRecord
    5 Jan 2010
    Yea I know. I saw Osidias a while back and thought the core of it was very similar to my concept sketches from way back. I'm glad his outer shell will make the finished case very different to mine. :)
  19. NavidsonRecord
    5 Jan 2010
    A little update showing things to come. I sanded 1 small part to make sure the deeper scratches would come out, the alloy had been sitting in an aircraft hanger for some time.
  20. NavidsonRecord
    5 Jan 2010
    Another update :) surprised how much time this took to get right... all day.
    Super sorry for the stupid spelling mistakes... In a rush when I'm editing... :wallbash:
