Scratch Build – In Progress Project: Silent Shadow
Discussion in 'Project Logs' started by Bl00m, 17 Jan 2011.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice cnc you've got there ! can't wait to see how this turns out!
  2. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    m8, just run distilled water + kill coils (or PT Nuke). You don't want something like this happening: http://www.xtremesystems.org/forums/showthread.php?t=226632
    I know it's different product, but after seeing that I no longer run any other stuff on my loop except for PT Nuke + distilled water. If I want color, I just run colored tubing. PrimoFlex LRT has the main colors you'll ever need (red,black,blue,green,etc).
    As for being "non conductive" that's not exactly true. The fluid will turn conductive after about two or three weeks of continuous use.
    Anyways, good work so far.
  3. Bl00m
    Bl00m What's a Dremel?
    17 Jan 2011
    Thanks for all the awesome words!
    I will try to not disappoint you guys!
    Okey so you dont recommend me using PC-ICE? because of the Color in the liquid?
    but doesn´t that happen to every color that you ad to the water that it faints away and clogs up the blocks?
    The thing is that I would really want the color in the water to give it a nice effect in the reservoir.
    I got recommended this coolant from other people in other forums:/
    I have no experience with watercooling from before so all the feedback is great.
    I have another thing to ask, I´m in a bit of an dilemma, I don´t know if I the tubing would look nice clear with the color of the water or if I should sleeve it instead;)
    I know what the use of color if i would sleeve the tubing but I what the color to show at least in the ress!:)
    Again thanks:)
    /Patrik
  4. Shadow703793
    5 May 2009
    Sleeving the tubing as in the PSU sleeving stuff? I have not seen any one do that. May be pretty cool effect. You'll definitely want to look in to that.
    If you want to use colored dye, that is fine, however do keep an eye out for possible problems after a few weeks. Like I said, I personally stick to colored tubing over dye.
    Which forums? The best WCing forum I've used is XS and OC (formerly OCF). Most (actually almost all) there agree on just running distilled water + killcoils/PT Nuke.
  5. Bl00m
    17 Jan 2011
    Yep like in sleeving cables;)
    I will try and do a setup like that and see how it looks;)
    I will try to keep an eye out for problems like high temps and such, and if I see any changes or something like that I will have to take everything apart and have a look. probably I will have it to take some nice pictures and maybe later if any problems shows I will change to something else;)
    O I cant remember but I googled it and found some already existing threads and just asked in them.:/
    Love this advices like I said its the first time for me with watercooling.
    Shadow703793 likes this.
  6. Shadow703793
    5 May 2009
    That is brilliant. I haven't seen any one do something like this yet, you may be on to some thing here.
    If you are new to WCing, I recommend you read these, if you haven't already:
    http://www.overclockerstech.com/water-cooling-guide-for-beginners/
    (Mainly, pay attention to the assembly as this is where most newcomers mess up)
    http://forums.extremeoverclocking.com/showthread.php?t=312743
    Reviews: http://skinneelabs.com/
  7. Bl00m
    17 Jan 2011
    Oh what is this, a new update? well yes it is!
    Hi All!
    After a long brake, it's time for a couple of new updates :D
    Thanks to a graficcard crash I was forced to buy a new pair of cards:
    Everything looked alright, but at a closer inspection I saw that it wasn't the cards I ordered so I had to return them to the store.
    But I quickly found a new pair, but this time from another store:
    What cards could this be then? ;)
    Oh a pair of HIS 6970 ;)
    Keep tuned for more! :D
  8. Bl00m
    17 Jan 2011
    Oh what is this another big update? :D
    And what? might it be some new plates to the chassi?
    no false alarm! it was just some part for the watercooling.
    a couple of block for the gpus, backplates and a bridge.
    some more tubing, a tubecutter and a fancontroller.
    Tomorrow you will get some pictures from the workshop:D
  9. Sarakon
    Sarakon The German
    11 Feb 2011
    This looks very interesting :thumb: Nice hardware you got there and awesome looking case design!!
    Will be keeping an eye on this :D
  10. Bl00m
    17 Jan 2011
    Thanks in a couple of hours there will be more pictures up ;)
  11. Bl00m
    17 Jan 2011
    Okey so here we go again!
    After spending some time with drilling and tapping holes for screws, and at the same time letting the CNC do its work I finally got some more parts ready :)
    Not a gigantic update but hope you like it! :D
    Next up I will try to put some of the parts together :)
  12. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Creamy!
    Looks like a nice backplate /// keep them coming
  13. Bl00m
    17 Jan 2011
    as you might see, if you look closer, there is two separate backplates ;) wonder why! :)
  14. Shattriath
    Shattriath What's a Dremel?
    5 May 2011
    This is getting interesting!
    Keep up the good work!
  15. Atasimey
    Atasimey What's a Dremel?
    19 Oct 2011
    Looks like a clean smart build in making. Tagging along for the ride as well. :thumb:
  16. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    I agree with djzic
    :jawdrop:
  17. Bl00m
    17 Jan 2011
    Hell yeah!
    Here it is! Some pictures of a partially assembled Silent Shadow :D
    There is still lots of parts missing.
    Enjoy! :)
    (I know the pictures are not 100% but due to bad lighting it had do do the trick)
  18. Tribble
    Tribble Steals Avatars
    14 Oct 2011
    I had a 5870 once to go trifire with my be 5970 but was DOA, so used my be 5850.
    subscribed, and looks forward to seeing more. ;)
  19. Bl00m
    17 Jan 2011
    Update, With panic in the text!
    So now its only Two days until dreamhack 2011 winter beggins and I´m starting to feel panic crawling in.
    It was some time now since the last update due to some other stuff.
    But here we got some pictures from this weekend when I got lots of time with the CNC, Enjoy:
    Thanks to how much I had to get done, resolved in that I didn´t have to much time to take pictures. But hey some is better then nothing right?
  20. Bl00m
    17 Jan 2011
    Continuing: Update, With panic in the text!
    Here is some pictures on the frontpanel and the sides of the chassi :)
    The next update will probably come during Dreamhack but until then, Enjoy! :)
