Case Mod - In Progress Project: SILEO 500 HTPC
Discussion in 'Project Logs' started by almamater, 2 Oct 2009.
  1. almamater
    almamater What's a Dremel?
    25 Apr 2009
    Sorry for my English (Google help me)
    Hello, as I have no where to spend money and to spend time (both lies :D ) Decided to start this project ...
    Objective: Turn a box into a kind of HTPC to put beside the TV, providing all the services of a HTPC and something else.
    I know that there are already HTPCs ready to use (Mini ATX, etc.). But honestly the look and size does not bother me and is not a strong point.
    Case: Cooler Master Silent Case SILEO 500
    Brief Description of Changes: Well, the box will take on the front:
    • an LCD Drive Bay of iMon
    • a 20x4 LCD connected via USB to pass system information
    • a 16x2 LCD connected via USB to pass custom informations
    Add a bar of LEDs (12) VU Meter style that captures the sound abiente through micro and makes the LEDs light up as the frequency (Like This, I was thinking about putting in the bay 3.5 "covered with acrylic ..)
    On Case side .. (I chose this Case because have a lateral "clean") I put a 250mm Fan, and i will lose the objective of protecting existing acoustic .. yes a little but there will be no problem ...
    At the top will also lead a Fan 120mm ..
    All fans will be controlled automatically by 2 temperature sensors that make them working more or less depending on the detected heat, here's the table:
    Will provide voltage depending on the temperature sensors
    I will put LEDs and buttons to indicate and control the states of LCDs Fans .. .. etc..
  2. almamater
    25 Apr 2009
    Some things that i prepared:
    My Tools:
    Done the hole of 250mm in Side:
    Time to cut 120mm from the top:
    Results:
    Time to put the crimps:
    I set the side fan just to see how it is, because it will take a grill between the plate and fan:
    Inside view:
    I connect the fan at 100% and there is a lot of wind inside the box. You can see here the VÍDEO
  3. almamater
    25 Apr 2009
    I cut and stuck a front bay to put an LCD and its LEDs (like the microphone for LEDBar):
    Invention to put all the buttons that I need on / off fans, LEDs, cold cathodes, etc. ... cut a bit of acrylic and will stay with the stand offs behind the Case ...
    The Top is ready ..
    50/50cm acrylic, will be to put on the side.. let's see how it is..
    The cold cathodes ...
  4. almamater
    25 Apr 2009
    I cut the side lacked to put the acrylic behind:
    The perforated plate to put in front of the 250mm Fan:
    The plate is very thick but is not impossible:
    here already sanded and painted with primer:
    Cover with LCD 16x2 plus 3 LEDs and a microphone (for LEDBar):
    The front cover with small acrylic for the LEDBar:
    The pcb I am doing to add all the connections of my electric circuits..
  5. almamater
    25 Apr 2009
    Tchan Ran... the iMon arrived to my hands (with some difficult):
    Done the perforated plate:
    Lot of wires to get ...:
    After storage:
    Digital thermometer to measure temperature:
    I made this hole in the other side to fit the thermometer
    Screws to the box:
    Panel with Buttons finished:
    Platform to handle the LedBar:
    start to engraving in the acrylic:
    Result:
  6. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Interesting project bud, coming along well but thats a LOT of switches, what will they all be doing?!
  7. almamater
    25 Apr 2009
    Yes, lot of them.. the purpose it is for turn On or OFF every Fans..Leds..etc. immediately
    General explanation:
  8. almamater
    25 Apr 2009
    Hi again, I mounted a AMD2600+ just to see how it is ..:
    This here is a light sensor... I put two blue LEDs at the bottom of the case and
    only light when it is dark (and when the button is ON):
    They are 2 LEDs below the box .. but here you just can see one:
  9. St3ph
    St3ph What's a Dremel?
    8 Aug 2009
    That's what I call control :D
    Nice work ;)
  10. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Whowawuwa, thats a lot of wiring :p
    You're doing great, i watch.
  11. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    The whole point of the sileo is that it is closed and very silent, but besides that it is a nice looking case.
    It looks interesting. I am going to keep watching this one.
  12. almamater
    25 Apr 2009
    Hardware..
    Asus M4A78-HTPC AMD 780G SKAM2/AM3
    AMD PHENOM II X4 955 BE Quad-Core 64Bits 8MB BOX SKAM3
    G.Skill DDR2 2x2GB PC8500 CAS5 PK
    OCZ ModXStream Pro Power 600W
    Samsung F3 1TB + Keyboard (Logitech DiNovo)
    I change de CPU Cooler: Noctua NH-C12P + Artic Silver MX-3:
    SAMPLE VIDEO
  13. almamater
    25 Apr 2009
