Project: Simplicity - Working the Plexi - 11-03-2007
Discussion in 'Project Logs' started by Jhonyb, 5 Feb 2007.
  1. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    EDIT: I decided to name my project Simplicity, because i think its a simple\pratical\(and if i may say so)beautiful mod :hip:
    I hope you guys enjoyed watching it step by step, its almost ending. I hope tuesday to have it up and running. Thx to all that replied and watched my case getting shape and form. TY ALL :clap: :clap: :clap:
    Hey
    I wanted to buy a new case for my new parts, since money was lacking :p i decided, Well lets just try to mod her :)
    Parts:
    MSI 975X PowerUp Ed.
    MSI Nvidia 8800GTS
    Cooler Master HYPER Intel LGA775
    CPU INTEL Core2Duo E6600
    Samsung 1Gb DDR2 800 x2
    Creative X-Fi Fatal1ty
    WD Raptor 10k 74gb
    WD 250GB 16Mb Cache SATA2 x2 (Raid0)
    5x Cooler Master WhiteLED Fan 120mm
    Seasonic M-12 600W
    I would like you guys to criticize my work and tell me what you think so far, its my first mod ever. I took some ideas from ALOT of ppl in order to set my own.
    So here it goes:
    The parts (missing PSU)
    Dismounted case
    Marked to cut
    Cutting process
    Radgrilz 3x120mm will be on top
    Painting process (Black paint WAS CRAP but its done now i wont be fooled again)
    Primary on the aluminum sides
    Painting process II (Bourdeaux this is GOOD PAINT :D)
    Status: Im still painting the "red" parts, ill give it some 2\3 more coats of paint. Then im starting the mesh interior part to hide the PSU and the holes opening only small holes for the PSU cables to get through; Mounting the Radgrilz and doing 2 plexi led holders on the bottom and on top. Ill update has soon has possible (paint takes a while to dry)
  2. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    looks like a promising start, I'm curious for the result of that painting job...
  3. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Me too :p lol
    Just gave another coat just now, tomorow ill prolly sand it good and give it the last coat.
  4. Archtronics
    Archtronics Well-Known Member
    27 Jun 2006
    Looking nice so far could you please explain more about how you painted the black i think it looks quite good
  5. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Heres a Small update:
    4\3 fully painted with the HDD's
    DVD-R \ DVD-ROM and Floppy
    My new cables ORANGE :D (Contrast of them with the black paint)
    Status: just checked paint, case is fully painted ill let paint rest tomorow and ill remove the protections and make an update tomorow also. Also start mesh "hiding place" for the PSU.
    To sirkillalot617 the point isnt in the how i did it, its in the paint itself, i bought the paint thinking it was good but when i painted it left some "waterly" traces only after 3 coats they disapeared a little. Then i found out the paint could be diluted in water and i learn NEVER AGAIN TO BUY WATER DILUTED PAINT :| Well 1st timer error, wont happen again for sure :D
  6. vortex46
    vortex46 New Member
    30 Dec 2006
    nice work,keep it up :clap: :clap: :clap:
  7. Archtronics
    27 Jun 2006
    oh i thought it looked very good
  8. kylelnsn
    kylelnsn New Member
    19 Dec 2006
    Looks sweet and prmising! like the cables not so sure on the red but cant wait to see a final product. ncie job!
  9. Igore
    Igore New Member
    2 Feb 2007
    Looks promising, looking forward to an update :D
  10. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Heres another update:
    The Case Fully Painted
    For a 1st timer i think its fairly good, black paint could be WAY better. Oh well next time ill buy good paint :D
  11. Archtronics
    27 Jun 2006
    mmm black looks good to me but im not to sure on the red looks kinda orange
  12. Infenro
    Infenro New Member
    7 Oct 2005
    If you live in the UK Halfords do good paint i used it for mine and i got good detail out of the cans.
    The mods looking nice btw, did you find the case hard to take apart as i have one of these and was looking at how to do it and looked confusing and gave up.
  13. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Im too lazy, i didnt take it apart :p
    Thou u can paint it very nicely without taking it apart.
    Theres lots of logs in here and in other forums that u can see a stacker being taen apart, imo isnt very hard but its ALOT of work, and im just too lazy :dremel:
  14. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Ok, here's another update on my workprogress:
    The PSU cover in card:
    Mesh waiting to be bend to make same for has the card one:
    Mesh to be cut to fit the holes in the case:
    Mesh cut:
    Grill for the top:
    Painted screws for the back fans:
    Case Holders:
    Sanded side panels (rdy for another coat):
    Ready to cut plexi:
    Plexi roughly cut:
    Plexi + Painted top of case:
    Photo without flash so that you see that its a dark red and not orange :p
    Status: i intended to start bending the mesh to make the "PSU hideout", finish the painting of the dark red, open holes in the case\plexi to put some white 5mm leds, AND HOPEFULLY start puting all together with the parts next week.
    Ty all for your opinions
  15. eegg
    eegg New Member
    29 Aug 2006
    nice
  16. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    Heres the Update:
    PSU "hideout"
    Grilz!!!
    Grillzzzz!!! II
    Side Panel fully painted
    Side Panel fully painted II
    DVD \ HDD holder
  17. P.P InDaHouse
    P.P InDaHouse New Member
    30 Jan 2007
    really like this photo :D :
  18. darren1678
    darren1678 New Member
    20 Jan 2007
    nice case ,red looks sweet :rock:
  19. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    thx alot for comments guys :)
  20. Jhonyb
    Jhonyb New Member
    5 Feb 2007
    PSU ARRIVEDDDDDDDDDDDDD :D
    :rock: :rock: :rock: :rock:
