So ive been a star wars fan my hole life and a computer enthueast over half of it. you can see where this is going... anyway ive been tinkering with a design for awhile and ive wanted to build a reall beast so here's what i came up with. (also i'm a team red fan boy... hold your breath.. here we go) Project: "Sith Lord" http://www.vonetech.com/ https://www.facebook.com/MineutSystems http://ultimatepersonalcomputers.com/ Sponsored in part by V1Tech, Ultimate Personal Computers, and Mineut Systems You guys rock! Assembled and designed by Myself (Bishop Computer Design) http://bishopcomputerdesign.com Projected Internal components AMD FX8150 8-Core 3.6Ghz (to be OC'd +4Ghz) - in hand 16G G.Skill - 8G in hand 2TB hdd 128SSD ASRock Fati1ity 990FX Killer - ordered, in route AMD Radeon 290x Rigid acrylic tubing above the midplate 360mm rad front - in hand Swiftech D5 Pump - in hand MIPS CPU block - in hand Aquacomputer Kryographics Hawaii Radeon R9 290X Full Coverage Liquid Cooling Block - Nickel crammed inside a Fractal Design 3000 - in hand, still some work left to be done NOTE: Some watercooling parts may change updates TBD (sorry for the gigantic immages i'll try to resize them and create a gallery later)
So long little guy. you have surved me well. your off to a new home and new master. make them proud! Hello my friend. your time has come. shall we begin?
Temp set up. currently running 32c idol with crap thermal paste. crap fans, push . under 50c under load at 100% cpu. not too shabby. waiting on fans, thermal paste, and a whole lot more! stay tuned
tiny update GPU relocation bracket installed, tested, working - done! next will be GPU support bracket. temp set up below. much much more to come. this is my daily driver so i tear her down and rebuild her after each upgrade LOL good times.
