Project : SKULL march 10
Discussion in 'Project Logs' started by Stulp, 10 Mar 2006.
  1. Stulp
    Stulp What's a Dremel?
    18 Feb 2006
    Now here is my first mod. I have been looking at guides, worklogs and case mod gallery, to finally jump in the modding universe.
    I will mod a Aopen HQ08.
    I wil try to mod this bare case into to this.
    Front of case will have from top to bottom
    - DVD drive
    - 3 40mm fan duct
    - 4 x 20 LCD display
    - PWM Fan controller for 5 fans
    - Power button
    - SKULL cut-out
    - 120mm fan duct
    Top of the case is not a blowhole. It will be some kind off laser beam made of red leds.
    On left side I will be cutting out a big half skull with my friend The Dremel.
    And for the right side I do not have any ideas for the moment but I'm open for any suggestions.
    I have made my skull template and completed my dremel cut out of the skull on side panel.
    I printed this skull and made the cutting with a raser blade took me about an 1 hour I was then ready to trace ou the skull on the side panel.
    Sorry for the bad pic quality.
    And here is the result of a couple of hours of dremel cuting and major dust.
    You can see the frame of the in the skull that will be cutted out.
    Next I will make the 120mm fan duct.
  2. Stulp
    18 Feb 2006
    The project log SKULL
    Any comments or suggestion will be appriciated thanx.
  3. Stulp
    18 Feb 2006
    Project log discussion here
    Thank you
  4. MonkeyTurnip
    MonkeyTurnip What's a Dremel?
    23 Aug 2005
    WOW that is some serious Dremel skills!! i wish i could do that, the skull looks awsome.
  5. _Dan_
    _Dan_ What's a Dremel?
    19 Feb 2006
    :dremel: nice dremel work hope this goes well
  6. Stulp
    18 Feb 2006
    Thanx for your comments
    Just completes my fan duct here are my results
    First started with mesurement
    And after some dremel and bad plastic smell this is what it looks like
    I then applied some bondo to the fan duct and drive bays as well
    Here the sanded bondo
    More bondo
    Next wil be the 2 fan duct the LCD cut out and also the front SKULL bone like cut out.
    Thank you for looking my mod in progress
  7. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Nice dremel action, dude.....Keep it up.
  8. HapeMask
    HapeMask What's a Dremel?
    19 Jan 2006
    Quite a nice job on the window cutting, hope to see more :)
  9. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Amazing dremel work! :jawdrop:
    What bit did you use?
  10. Stulp
    18 Feb 2006
    I have used these cut-off wheels
  11. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Aaahhhh, nice, thank you :)
  12. Stulp
    18 Feb 2006
    Got up early this morning and did little things to my mod.
    Here I cutted out the two rear blowholes
    And the dismentled the hole case.
    Once dismentled I cutted the plate where the cd drive and psu rest so when all is mounted you won't see a bar going throught the skull
    After all this done I will prime and paint the interior of the case in red and will post the paint results tomorrow.
  13. Stulp
    18 Feb 2006
    Finished painting the interior of the case and here is the results, and i'm pretty happy and it was a practice with aerosol paint
    thank you all for your replies
  14. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    WOW! that skull looks awsome nice!
    Nice job on the painting ;)
  15. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    The paint job looks great man!
  16. Stulp
    18 Feb 2006
    Thanks..
    I just finished painting the MB tray and the power supply will post pics tomorrow.
  17. Stulp
    18 Feb 2006
    Painted MB tray and psu. I primed and painted. Here are some pics.
    My nest step will be painting the out side case.
  18. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Just a suggestion, though it would look a lot better if you remove and paint the brackets on the cards that are on the system. Also the I/O sheild. Other than that it looks very good so far. And awsome work on the skull cutout btw :p
  19. Stulp
    18 Feb 2006
    I will take your suggestion in consideration thanks
  20. Stulp
    18 Feb 2006
    Updated march 15
    Here's some off my work done on the front case.
    I cutted out the SKULL text made off bones letters
    I also made the cut for the LCD and the 2 small fan ducts
    And applied first coat of primer after some bondo work, sandind more bondo, sanding and first coat primed.
    After 30 minutes of drying there where to much bondo bumps and unevenness between the drive bezel and the frame. I wasn't to amazed by my work so decided to completly strip out the 2 fan ducts and lcd window.
    All of that remove made some minor touch up.
    I'm thinking of replacing it with some mesh or plexi I dunno. If you have any suggestion please feel free to help a fellow modder in is creation. Oh and the 120mm fan duct and skull cut out are staying the are perfect.
    Thanks.
