Case Mod - In Progress Project: Snow White
Discussion in 'Project Logs' started by ColdzeroTeam, 10 Dec 2010.
  1. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    Snow White TJ07
    Case: Silverstone Silver TJ07 White.
    PSU: Silverstone Strider plus 1000W
    Motherboard: Gigabyte X58-UD7
    CPU: Xeon i7 X3520 D0
    Memory: Gskill PC12800 Ripjaws CL8
    HDD: 2x Seagate 500Gb 7200.12, Intel X25-M G2 80Gb
    Graphics Cards: 3x XFX HD 5850 in Crossfire X.
    Water Cooling:
    CPU: EK Supreme Cu HF Nickel
    Graphic Cards: 3x EK for HD 5850 (Nickel)
    Pump: Laing MCP 355.
    Radiator: Thermochill PA 1.480 + 1.240
    Reservoir: 2x EK Multi Optinon 250
    Fittings: Enzotec Conpression Fiting G1/4" 16/10 shiny silver adapter
    Fittings: Enzotec Conpression Fiting G1/4" 45º shiny silver adapter
    Coolant: Thermochill Blue :D
    Fans: Fractal 120mm x8
    Sleeving: Sleeving Coldzero
    Photos to come soon
  2. ColdzeroTeam
    9 Dec 2010
    NEWS
    Interior, and the radiator supports
  3. ColdzeroTeam
    9 Dec 2010
    NEWS 10-12-2010
    The HotSwap System
    Pumps Tray
  4. mav2000
    mav2000 In Training
    16 Oct 2010
    Very nice. I like the way this is going.
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Topnotch :)!
  6. Richy1204
    Richy1204 What's a Dremel?
    7 Dec 2010
    Look great (Subscribed) :)
  7. Razarach
    Razarach Minimodder
    28 Jan 2009
    nice work :)
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Bravo Cold Zero :)
  9. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    Good work man!
    sub'ed
  10. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    Wow! Very clean!
    subbed
  11. error404
    error404 What's a Dremel?
    11 Oct 2009
    where can I get the hardware to create my own custom hot swap bays?? :jawdrop:
  12. masterchief9615
    masterchief9615 PC builder / Modder
    4 Nov 2006
    Great work so far!!
  13. paz45
    paz45 What's a Dremel?
    12 Nov 2010
    Nice like the hot swap.
  14. ColdzeroTeam
    9 Dec 2010
  15. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    This is looking damn fine piece of work so far
  16. ColdzeroTeam
    9 Dec 2010
    News: 15-12-2010
    [​IMG][​IMG] [​IMG]
    Hello today we made some progress, here are some photos, not all of them, tomorrow we will add some more and we are going to start sleeving and assembly de power connections
  17. error404
    11 Oct 2009
    just a friendly recommendation (learning from my mistakes :worried: ) Move your radiator as close to the front of the case as possible. I Never put the fans on the rad while I was measuring (I though that I would lose 1 fan at the back because of the PSU ). Well, I end up losing 1 and 1/2.... If I would have placed the rad closer to the front, I would have clear up the 3rd fan.
  18. djzic
    djzic Bokehlicious!
    8 Nov 2010
    God I love TJ07s, absolutely awesome, even if they're so popular nowadays.... just means you need a better mod to make it stand out :)
  19. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The hot swap bay idea is brilliant. The color scheme should be great. Sub'd. :thumb:
  20. ColdzeroTeam
    9 Dec 2010
    I can fit all the 4 fans. the custom psu plate i did allows me to position it either way, so i can have the psu fan suck the air from the 4th radiator fan.
