Case Mod - Complete Project: SNOW
Discussion in 'Project Logs' started by AML_customs_pc, 17 Feb 2018.
  1. AML_customs_pc
    AML_customs_pc Minimodder
    24 Feb 2017
    Project : SNOW
    I am back with a new build for 2018, I want to start by saying a big thank you to Thermaltake for supporting this project.
    I am doing a Ryzen 1600 build paired with a MSI 1070 gaming x8 graphics card. I will be building in the core P3 from thermaltake, this will be fully watercooled.
    I have set myself a big challenge to think more outside the box for when it comes to where to place the reservoir and radiator. I have also set myself a challenge to make everything white so I will be doing a lot of painting and resleeving and a lot of cables.
    Here what I will be using,
    The thermaltake core p3 snow edition,
    Ryzen 1600,
    MSI Tomahawk Arctic B350
    The thermaltake Pacific W4 Plus CPU water block,
    Corsair Vengeance RGB 2x8gb 3000Mhz could upgrade this two 32gb,
    Samsung 960 EVO m.2 250GB this will be used for OS,
    WD HDD 1TB,
    Thermaltake Toughpower SFX 600w PSU,
    MSI GTX 1070 Gaming X8,
    Thermaltake Pacific RL 360
    Thermaltake Pacific P1 Black,
    Thermaltake Pacific RGB Hard Tube Fittings,
    Thermaltake C1000 Green and White,
    Some of the cable and connectors, I am using mdpc sleeving.
    Thanks for checking out the post if you have any question or suggestion, leave a post and I will get back to you as soon as I can.
  2. AML_customs_pc
    24 Feb 2017
    Welcome back,
    I have a little update for you all,
    I wanted to move the radiator to the bottom of the case where the PSU would be, I have not seen this on a core P3, I needed to make sure to would support the radiator, as I do want to mount this to the wall.
    I am using 19mm x 19mm aluminium to start the framing of the holder.
    Mark where I need to cut,
    The bits I need,
    Marked where the hole will go,
    Drill a 4 mm hold for the rivets,
    Test fit,
    The 360 radiator sat very nice in the space now needed to make the support,
    Now to make a new GPU bracket, but thought I would be easier to mod the one I have, I need this to be shorter.
    Before
    After, I am going to add some 19mm x 19mm aluminium to the outside of the bracket.
    Here is the end result, I just want to stress that this is not the finish product for the brackets, this will give me a feel on what it will look like.
    Hope you like the update the weather, not been good
  3. AML_customs_pc
    24 Feb 2017
    I have a big update, most of the painting has been done, and I have started to do the cables.
    I will start with the Pacific RL360 Rad, I have painted this snow white, covered the fins and did light coats, the spray paint I used is Montana.
    Before,
    After,
    I have also painted the heatsinks, I am thinking about adding some green to them.
    Before,
    After,
    I wanted to paint the Thermaltake tough power 600w PSU white, this was a lot harder than I thought it would be, I striped the full PSU down but couldn’t find the last screw so I needed to cover all the enteral components. I also made sure to save the labels as I want to add these back on to the PSU.
    Before,
    After,
    Next up to paint was the thermaltake Pacific W4 plus CPU block and the Pacific RGB fittings. I started with the CPU block, I heated the front of the block to loosen the glue of the black back ground as, I want this to be white, I had already made some little TT logo’s to cover the TT logos on the back ground, then I just lightly sprayed it white. I also added the bracket for Ryzen and painted this white too. The fittings were very time consuming, I wanted to get as much detail of the fitting as I could.
    Sorry for all the photos, think I have went over the top, I have a few more then that it. I have started to sleeve the cable here is the 24 pin.
    Hopefully the next update will not be as long, need to do the pump and the GPU, then that’s all the painting done.
    If you have any questions or feedback please let me know.
    Richard.
  4. Icelander
    Icelander Minimodder
    3 Mar 2015
    nice start. like the Rad position
  5. AML_customs_pc
    24 Feb 2017
    Thanks, should have the next update soon, had issues with CNC.
  6. AML_customs_pc
    24 Feb 2017
    Hi Everyone,
    This is just a small update, I have had a few issues with my CNC and it no longer works I have blown the spindle, so I have not done as much as I can hoped.
    I have been painting the thermaltake Pacific P1 pump, this has cause me loads of issues, as I only get to mod on a weekend. I have painted this 3 time and I can see I am 98% happy with it. The photo below is showing you the process the 1st time I did it.
    Before,
    I needed to sand the parts done so the primer would stick to the parts, can I use spray can you apply the paint.
    You can see the paint looks a bit bumpy, I then did some vinyl logos and added them to the pump and airbrushed the green paint on.
    As you can see it looks ok but I want it looking better. So I striped the pump and started again.
    This time I used the airbrush for every layer I also wanted to add green to the D5 cover and to the bracket.
    I did this over a few nights adding one layer at a time,
    I am much happier now with the end result.
    I still have a lot to do, I still have a lot of wires to sleeve, fans to paint and a graphics card to paint.
    I did hope to show more but I thought it would be best to post something than none at all.
    Until next time,
    Richard.
    zogthegreat likes this.
  7. AML_customs_pc
    24 Feb 2017
    Hey,
    I have been really busy the last few weeks working of the build,
    Let start with the biggest issue, I broke my CNC which I have only had for about 6 months, I got this from china, have been able to do a few mod with it but not the main reason I got it. This meant I needed to ask Praetex Design for some help in cutting the design I made for the custom reservoir,
    Here is the design I made in fusion 360,
    Alex was able to produce the product and it turned out great.
    Here is me leak testing it,
    I then need to add the reservoir to the case. I must taped and marked the holes about 5 times I didn’t want to mess this up.
    Before,
    During,
    After,
    Think it turn out great.
    Now the Thermaltake Riing Plus fans as you can see from the photo above I needed to paint the fans so I strip them down.
    Before,
    [​IMG]Next update by Richard Ord, on Flickr
    I have taken these fans apart before with out breaking any of the clips, this time I must of broke 5 in total, the fans still hold together well.
    I didn’t take many photos of the painting but I just made sure I gave a lot of light coats
    I think the end result looks great,
    What do you think?
    Next up was the MSI 1070 Gaming X graphic card,
    I followed the same process with the fans and striped the card right down. If you are going to do this and paint the fan you are going to have to bend two metal clips over (cable management) which holds the cable for the fan.
    I need to take the sticker off the fans before I paint these I wanted to reused the stickers.
    I made sure I did lots of light coats of the paint.
    Here are the after photos,
    Fans [​IMG]
    Housing,
    End result,
    Just want to make it clear I am going to add a bit of green on to the card. I have also add a white ring on the MSI stickers to hide the red.
    I need to add a little bit of white vinyl where the MSI logo glows, again this was just to hide the red.
    I was not going to show this next photo until the build was completed, what the heck here it is anyway.
    We still have work to do I need to support the GPU better so going to add an enclosure to the PSU this will then support the GPU. I am also changing the green out of my cable I made early to a better match green. I want to added as much detail as I can to the build.
    I am wanting at add a enclosure behind the case to hide the internal wires.
    Like always I hope you like the build log so far, if you have any question or feedback please leave below or come find me on Facebook / Instagram
  8. kim
    kim hardware addict
    10 Jan 2016
    very interesting build, a lot of cool ideas, but what I admire the most is your paint job on hardware or WC parts...:jawdrop: absolutely perfect :clap:
  9. AML_customs_pc
    24 Feb 2017
    Thanks kim, the build has been nominated for case modding update for may.
  10. zak
    zak Build Clean people, build clean
    18 Apr 2018
    i have never seen that msi card painted before, i like it. it would be dope to paint the fins that were red, green. or just like, reverse the colors to green and white, but keep the theme of color play like they had. great work so far.
  11. AML_customs_pc
    24 Feb 2017
    Funny you should say that I have another update coming soon, but here is a little peak.
  12. zak
    18 Apr 2018
    bingo whammo!
  13. AML_customs_pc
    24 Feb 2017
  14. AML_customs_pc
    24 Feb 2017
    The build is all most completed, I have had a little delay due to me moving house and all my gear is in storage, should have been in the new house on 27/07/20108 but now it will be 10/08/2018.
    so the last time I posted we can everything white and in place to where I wanted everything, I was not to please with the color of the cables so I redid them. I wanted the green to match the rest of the build so painted the cables green with the airbrush.
    I think they turned out great.
    I cut some 3mm perplex to make a cable cover for behind the motherboard, this is not going to be on show but thought it will be a nice touch.
    The build is almost completed, need to run the hard tube and do a small PSU cover then the build we be completed.
    Here is a little sneak peak.
    Thanks for taking the time to check out the build log.
    _Prometheus_ likes this.
  15. zak
    18 Apr 2018
    If someone not very knowledgeable about PC's looked at your build, they wouldnt understand or appreciate how much time it takes to do the little things like your doing. It looks nice man keep it up. Only advice, is buy some yellow coolant or dye. Add it to your current green dye. Your cables and GPU is a very light lime green and the reservoir is a darker rich green. Also make a white IO shield out of acrylic if possible.
    AML_customs_pc likes this.
  16. AML_customs_pc
    24 Feb 2017
    Thank you,
    The green in the res is not the green I am using, I am using the c1000 clear and the uv green dye.
  17. AML_customs_pc
    24 Feb 2017
    Hey everyone,
    Sorry for the lack of updates, Project:Snow is now completed, if you were at EGX 2018 @ NEC in September you would have seen Project:Snow on the Cyberpower booth. I have also been doing design work for the Thermaltake UK Modding Trophy 2018 sponsor by thermaltake, Asus, AMD, Adata, Bit-tech and Scan. This build log is live.
    I just want to say a massive thank you to Thermaltake for sponsoring the project, I think the build turn out great.
    Final Photos,
    [​IMG][​IMG]
    kim likes this.
  18. Cheapskate
    13 May 2007
    That came out lovely. :D
    Of all the wacky ideas we tossed around on the forums that magically became a product, I still like the lights in the tubing runs best.
    Only just noticed you mentioning the cnc dying. What happened? Maybe someone here can troubleshoot.
  19. AML_customs_pc
    24 Feb 2017
    Thanks cheapskate, it turned out great.
