Project Sonic Started of with a ugaly pre-modded case for £ 30 odd. the inside had this paint on it like gray and wasent very effective. pollished the paint of with brasso and some car chrome products. Then Polished the PSU up (like a mirror) then put in a thermaltake orange fan low noise. Then i cut out the rear 2x 80mm fan grills that slow the airflow down. added 2x Blue-eye thermaltake Case fans. Then i decided on watercooling so the Thermaltake Aquarius 2 i have placed the radiator on the top of the case with an 80mm fan blow hole cut out. I havent had time to finish the 80mm fan mods at the rear off. also the case needs tideing such as the cables ect just havent got time to do it lmao Also put in a ultra bright blue LED for the power Led and a Red Bright LED as the Hard drive LED also behind the power button is lit up as there is a blue ring around it The Spec of this pc is: MSI Neo 848p Motherboard 512Mb DDR Pentium 4 2.53Ghz @ 533Fsb 64Mb Geforce 4 Graphics card (need upgrade looking 4 a cheap card) Segate 120Gig Hard Drive 7200Rpm 8mb onboard cache (needs CD-ROM / CD-RW) Some pics: Preping the side's and top and front for painting. 1st coat after the primer. 2nd coat after the 1st coat There was a final coat. but i dident take a pic of that here is the case back 2gether. I am still working on the front of the case. This should be finished in a few days. And here is the top of the case with the 80mm Fan for my watercooling. There is a 120mm fan at the front of the case to replace then 2 80mm fans at front Also i painted it black now insted of been silver and like i am makeing a new front for it. tell me what you think of it so far.
Is this a project? It sounds like it is done, maybe it should be moved to the modding forums By the way... red x's
2day is the day of the dremal i am going to cut out the 120mm fan blow hole at the front ill post pic's later once ive finished
I suggest you PhotoBucket It's really fast and simple and it gives you the opportunity to organize your pics into different directories; moreover you can simply copy and paste the codes for inserting the pics into your forum posts.. Hope it helps.
okay so i dident have the time 2day to cut out the 120mm fan hole lol. ho well i am looking for a Bay Res that has barbs for a Thermaltake aquarius 2 does any one no were i can get one from ? i am working on the photos and i do no about the Red X lol thanks for telling me hope to here from yas soon thanks sonic
project update i have made a VU meter from the LTP port which runs from a plug in from winamp 2x. i am running 5x Ultra bright LED's. ill have some photos uploaded to some better web space. Some people say i need an hex buffer so i dont kill the LTP port is the ture ?. And if so how do i go about adding one to my VU meter. also i am going to cut the 120mm blow hole out one day and well i am tidying up the rear 80mm fan hole's. come one people tell me what you think
hmm. Good ideas so far, but there's a few things you have to do. First, get a second grille for that second fan. Next, make sure the top blowhole fan BLOWS IN over the rad - trust me - if you use an aquarius for exhaust, expect barbeque.
hiya update. Right i need some Good Free Webspace to uplaod my pix 2 any one got any ideas Also i will take a Video of the VU meater in action its class blind's you the LED's are that bright. The fan for my watercooling is blowing in over i am not stupid lmao and i have finished of the back fan's with another grill And Then the Bad parts. okay i sort of punched my front of my case and well sort of killed it now i need a new front panal like to cover the floppie bays ect also i could do with re doing all my front of my case i will need help i am thinking about perspex and carbon vinal behind it. i need help for the front any ideas also i need to make a new power button i need ideas fast and loads. and i cant buy a new case that is not an option as i am skint. hope to here from ya soon
