Scratch Build – In Progress Project : Sors salutis -by AnG3L(15 April 2011 - Video is UP)
Discussion in 'Project Logs' started by AnG3L, 10 Dec 2010.
  1. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Hey Angel,
    Last update that i saw was on page 8 (shame on me :( )
    With me up to date now again, all i can say is: Mod on !:D Love the plexi works.
    Grtz.
  2. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    WOW. let me say again WOW!!!! I can't help but wonder, considering how much you have done, what your next will be. To start this and be where you are so quickly after the last project. I only see a few who do this. so again WOW great work!
  3. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    ;) Thanks brother, mod on too!!! :thumb:
    Guess I am addicted lolz :D Thank you buddy for your support and your nice words, I wish I have the money and hardware needed to keep on modding forever, to always be amongst these wonderful people! :thumb:
  4. The boy 4rm oz
    10 Apr 2008
    Fantastic work Alex. I haven't checked in for a while but you have made awesome progress. Keep it up :thumb: :D.
  5. AnG3L
    19 Mar 2009
    Thank you my friend Jason! :) I have a lot more to do till the next update but it will be interesting I believe!!! :)
  6. Fedmas
    Fedmas Leader of the casemod watchers :D
    29 Jan 2010
    Good work Angel! Looking forward tothe end result
  7. AnG3L
    19 Mar 2009
    Thanks bro me too! :) Today I purchased my self an airbrush!! I dunno if it will work cause it was really cheap ;P
  8. Fedmas
    29 Jan 2010
    Pics or it didn't happen
  9. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Airbrush :O!
    Let the update's come :D!
  10. AnG3L
    19 Mar 2009
    It will be a while for you and me to see this airbrush in action as it rains a lot now and also I have to finish the rest first!!! Patience!! :)
  11. KidMod-Southpaw
    28 Sep 2010
    Awesome, meshyness.
  12. AnG3L
    19 Mar 2009
    ;) Thanks bro
  13. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    I've just read through all that I've missed over the past few weeks, and its looking great AnG3L :thumb:. The wood is a nice touch too, can't wait to see what you've got in mind for finishing thoughs parts.
  14. AnG3L
    19 Mar 2009
    Thanks brother, well a lot of improvisation will be involved too, a lot of extra details etc!!! Stay tuned bro!!! ;)
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nearly missed that latest update :blush:, structure looking good, mesh looking good, acrylic cut out patterns looking good, will look awesome & extremely unique when you start your paint thing AnG3L another classic in the making :jawdrop::clap::dremel::thumb:.
  16. AnG3L
    19 Mar 2009
    Thanks brother Waynio ;) Indeed, the painting it will change everything plus the extra details etc but its going to be tricky this time!!! Hope I will make it! An update is coming today probably so stay tuned guys! :) Peace!
  17. AnG3L
    19 Mar 2009
    Update no 11 guys and we move on!
    Lets see what I did these few days.
    First off all, the installation of the rad holders.
    Measured the right distance between them as they will be "sandwiched" (lol killer term!) .
    Marked the holes as I will use both screws and glue for maximum durability.
    Drilled the holes and also countersunk them on the bottom.
    Some glue, screws and voila, done!!!
    Then it was time to cut 4 pieces from white acrylic which I am going to attach on the main compartment to hold together the 2 pieces. (main + watercooling)
    First I draw the outline on the acrylic.
    Oh my trusty dremel, my great helper!! ;)
    Then I used the vise to hold them together in order to sand them/ file them.
    After 20 minutes I finished that step!
    Time for some drilling! I also tapped threads on the acrylic for the 10mm screw, just to hold it in place.
    Finished!!!
    I decided to put an extra screw on each of the supporters which are holding the chassis of the second compartment.
    The head of the screws are not going to be visible as I will cover them later with isopon.
    The screws are only for extra durability and safety.
    After that, I glued the remaining back piece of the main compartment. I used plastic welder
    which is really really strong and I advise you if you are going to use it first make sure that you are not gluing something wrong as it is impossible to fix it later on!
    I am talking from my experience as you will see in an upcoming update.
    After it dried I decided to take some pictures with the side panels on just for you to get an idea what I am up to!! Hope you are going to like it even if its too late yet.
    Thanks for reading my worklog guys, till next time, peace!!!
  18. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    GAAAAAAAAAA BREADBIN For the Win Cheesecake!!! :jawdrop: :rock:
  19. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    you really let your imagination and creativity go wild with this one... looks great so far :thumb:
  20. AnG3L
    19 Mar 2009
    LoL now I got it! It didnt cross my mind before lol it looks like this indeed :D Thanks bro! Double breadbin cheesecake!!!!:rock:
    :thumb: Thanks man I am really glad you like it!!!! :D
