Scratch Build – In Progress Project : Sors salutis -by AnG3L(15 April 2011 - Video is UP)
Discussion in 'Project Logs' started by AnG3L, 10 Dec 2010.
  1. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    You are the King of Etching! Simply great work buddy!
  2. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Damn dude. very interesting!! I like it!
    Reeeeep rep rep rep
  3. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Most of the mods, even if some of them are complicated and beautiful, they dont use abstract art as painting or something extreme, instead they are using 1-2 plain colors. I, as an eccentric person (lol) I like to try new things and create something different. Remember that Salvador Dali wasnt accepted by everyone but his art got really famous afterward. In this mod there are many and different painting techniques which some of the are really difficult. I wonder if anyone noticed that they are 7 different techniques! I will probably update with more details on that! Thanks buddy your comments and presence are always appreciated!! :)
    Thank you my friend, I really appreciate your support! :thumb:
    Thanks buddy your comment made me smile!!!! :D
    Glad you liked it my friend!!!!! Thanks!! :D :thumb:
  4. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    love your sense of artistic style! :)
  5. AnG3L
    19 Mar 2009
    Thank you my friend!!!! :)
  6. Squirrel-666
    Squirrel-666 What's a Dremel?
    24 Sep 2010
    wow wow wow hurry up i need more :D excellent work mate
  7. AnG3L
    19 Mar 2009
    Thanks matey, I will hurry up!!!! ;)
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    some amazing work there. i really like the forms you've chosen. it's great to see builds that aren't a box. i've really been into these architectural styles of builds lately. some interesting painting techniques you are doing. another great example of functional art.
  9. AnG3L
    19 Mar 2009
    Happy to see new people commenting and appreciating my work! Thank you my friend glad you liked it,
    it will be a pleasure to have you here with us !! :)
  10. XxS4CR3DxX
    XxS4CR3DxX What's a Dremel?
    24 Jan 2011
    It's looking great so far can't wait to see it all finished keep up the good work!
  11. AnG3L
    19 Mar 2009
    Thank you my friend!!! :)
  12. D-Mon Taurus
    D-Mon Taurus What's a Dremel?
    15 Mar 2011
    It is different it is ART. A real piece of art.:rock: I am loving it. The raw paint job with the smooth and soft curved lines. Its a case with expression
    Wonder what it would fetch at Sotheby's? :D
  13. AnG3L
    19 Mar 2009
    Your comment made me smile brother!! Glad you like and understand art, and I am happy that all my efforts are appreciated by other people!!! Thanks buddy, Sotheby's is a high standard art institute I dunno if I can manage to have a place there ;)
  14. KidMod-Southpaw
    28 Sep 2010
    You probably could Alex, I'm still trying to get a spot in my local gallery.
  15. DeadP1xels
    30 Nov 2009
    Wow that is wicked cool :)
    Im inspired to take on my own project with focus on more of the art side of it
    Great work as always man!
    -DP
  16. AnG3L
    19 Mar 2009
    I never tried before, good luck with the local gallery buddy! :D
    Glad I could inspire you my friend, thanks for your nice comment, I am looking forward for your mod!! :thumb:
  17. AnG3L
    19 Mar 2009
    Look at your pc.
    Now look mine.
    Your pc will never look like mine.
    Now look in my pc.
    You see 2 graphic cards with the waterblocks you love.
    Look again.
    The graphic cards are now diamonds!
  18. AnG3L
    19 Mar 2009
    Time for a new update as we are near the end... hopefully!
    This is going to be a very random update as I work on the final touches, cable management, water cooling, extra details etc.
    First some of the work I did on the main compartment of this mod.
    Leds cut in size and installed. I forgot to take some pictures with the cable management finished but I will post them in another update.
    The cable management will be done in an artistic way and also as neat as possible. Due to the mods theme the cables must be arty too!
    Mobo i/o shield installed
    Double sided tape and the logo illumination acrylic is in place!
    The DVD eject switch, and how it looks on the case. I also installed the DVD but more on this in an upcoming update.
    In some of the screw nuts I used MDPC caps. The rest left uncovered for a different contrast in the overall design.
    The installation of the fan controller and its cover. More pictures outside with some natural sunlight in a while!
    1mm clear acrylic for the small window on the main side panel.
    As I promised here are some super macro and macro shots of my painting techniques.
    The "golf ball" texture technique. Its done by using a piece of newspaper. To finish the texture you need to use this technique 3 times in a row before the paint dries completely thats why I used paints that took longer to dry. Its applied on the side panels edges.
    A technique which is applied only on heavily textured surfaces.
    See the details on this technique.
    Random shots of more painting techniques and also of the second compartment!
    See the 2 different layers of white.
    This is a technique where you have to scratch the paint underneath and paint over. To do that you have to apply at least 5 heavy layers of paint before so the scratches will be deeper so therefore the technique will be applied better!
    More leds to be cut, soldered and sleeved!
    I decided to use less leds on this compartment cause firstly I needed two more to cover my needs but also I am going to play with the lighting effects and overall "night" looks of it!
    Windows installed!
    A shot from the led tests I did.
    Here are the shots from the final build steps of the second compartment of this mod.
    Custom cable with heatshrink arty design, re-did some of the cables, installed the radiators, tubing, pump and done!!
    Thanks for reading my update guys (and not only stare on the last picture! :p )
    Till next time, peace!
    k.3nny likes this.
  19. KidMod-Southpaw
    28 Sep 2010
    INCREDIBLE! What more can I say Alex? It's an absolute pleasure to read through this log and look at your wonderful artwork. It's my birthday on Friday, so I'm feeling nice, I'm linking this mod to MDPC because that's thew only way to describe this piece.
    Well done.
  20. AnG3L
    19 Mar 2009
    Oh happy b-day man all the best and above all health and love to your life! Thanks for the support man I appreciate everything! Drink a beer for me too on your b-day and have some good time!!!! :)
