Scratch Build – In Progress Project : Sors salutis -by AnG3L(15 April 2011 - Video is UP)
Discussion in 'Project Logs' started by AnG3L, 10 Dec 2010.
  1. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Wow I'm speechless :), awesome work Alex. The view from the front of that fan speed controller section look amazing. Is that a mirror that the speed control knobs are on?
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks Keir my friend!! :) No its sanded clear acrylic bro that I use along with the leds! :)
    Javerh and Waynio like this.
  3. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Wrapping up another great looking project!!
  4. cchr
    cchr Minimodder
    24 Nov 2010
    If anyone finds my jaw on the floor, please return it :jawdrop:
    Excellent work as always alex, each update is better than the last one!
    Mod on mate :dremel:
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe: For a change I don't know what to say :D but going off that night shot I'm also looking forward to MOAR night shots :D:thumb: the last few updates have had a ton of bits of awesome progress in them so I'll just leave this & some rep :).
    It's a smiley party :rock::D.
    :jawdrop::rock::dremel::rock::jawdrop:
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Quote this for awesome epicness take over this log :rock::rock:
    Have some +Rep Angel! Its awesome, Ur a verry unique modder:blush:
  7. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Looks like an epic surgery gone wrong. I knew a girl with hemophobia. This mod would make her flip out. +rep
  8. AnG3L
    19 Mar 2009
    Hopefully till the end, thanks bro!!! :thumb:
    Thanks Chris! Eha8ikes teleia empa je lio msn na ta poume! :)
    Smiley party cheesecake !!! :) :) I am glad you liked my progress brother Waynio and also I am glad that you couldnt find anything to say!!! :) lolz :p
    Thanks for all your support mate!!! :rock:
    Thanks Kenny I really appreciate your presence in here! :thumb: :D
    LooL that was a good one!!! I am glad that you understood my "sublime" message bro as indeed this is meant to show blood as the title of the mods says "sors salutis" which means my fade is against me! :thumb:
    matiss likes this.
  9. KidMod-Southpaw
    28 Sep 2010
    Erm... I'll be 14- but, sure, what the hey!
  10. AnG3L
    19 Mar 2009
    14? Oh sweet youth lolz!!! ;) Wish I could be 14 again but in a different country and different situations lolz!! :)
  11. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Keep it coming Alex.
    At the rate you are building these mods, what are you going to do with them? A man can only have so many computers.
  12. AnG3L
    19 Mar 2009
    This is my question too bro, not what shall I do with them but where to store them! I left out of space and now with this mod I have to sell a mod and that will be Totechnika! I wish I could find someone to buy it even though I dont want to sell it I have to now!!! :)
  13. Combatus
    16 Feb 2009
    This is looking fantastic Alex! It looks like it belongs in an art museum! Really, really fresh-looking too! :thumb:
  14. AnG3L
    19 Mar 2009
    Thanks Antony my friend happy to have you here commenting!!! I am glad you liked it too!!! :)
  15. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I was wrong! This is even more insane than I guessed! :rock:
  16. AnG3L
    19 Mar 2009
    Insane is my middle name lolz ;) Being different and extreme is a risk but as you might have guessed I love to risk! Thanks bro!! :)
  17. Watchtown
    Watchtown What's a Dremel?
    2 Mar 2010
    Im hoping that the colors combination, isnt going to be a fail. i will hold my breath to your next updates.
  18. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Bring the PAIN Alex:D I want to see this finished sooo bad! (even though the updates has a slight sexual satisfaction as well lol)
  19. AnG3L
    19 Mar 2009
    Artistic approach has always risks bro as not all of the people going to like it. Stay tuned for todays update and I will wait for your opinion! :D
    Pope the dope nice to see you again!! Pain is coming your way lolz :p Sexual satisfaction cheesecake muffin!!! :naughty:
  20. AnG3L
    19 Mar 2009
    Update no 26 guys and one step before the end!
    The only thing left before I finish this mod is some cable customization and management so
    my next update might be the final shots only.
    Lets move one with this update!
    First I realized that I painted the wrong side of the main compartments side panels, so I had to paint them again. I used black hammered paint for that technique.
    I also decided to use only one panel, the one on the top, as the second is useless as it will be used only in transportations.
    I used this sharp piece of acrylic to draw some lines.
    Last step pf this process is to add some random quick pass white lines over the black.
    Back to the assembly of this mod. Reservoir, fans, some cable management, uv cold cathodes etc.
    I also found this UV led thingy and disassembled it for me to create something for the reservoir later on.
    I also had to create a cover for the GPU's bracket to cover a distance that was created due to the mods design and also add a different touch to it.
    I used 5mm white acrylic for that which I painted later on.
    I also tried to create a housing for the leds from 1mm acrylic which proved a fail in the process so I have to make something else!
    Testing the side panel.... again!
    For the mods main support I am not going to use the wooden rod which I created at the first place, but instead I used an aluminum angle which I painted hammer black.
    More assembly and testing shots.
    Sata power cable modification.
    My various connectors collection lol! :)
    Here I created a custom slimline sata power connector out of a normal sata power connector.
    I cut it in half after I removed the middle pin so it will left with only two pins ( 6 in the interior)
    Attached the first sata power in the proper distance.
    Second one attached too.
    And the slimline power connector mod finished and sleeved!
    I also sleeved the two main hdd sata cables.
    Here is the PCI-E cable. It comes with 2 sleeved cables 6+2 pins each.
    I had to sleeve them all to reduce the clutter and also make the cable more compact .
    I cut the cables in size and with the crimping tool I added new pins and later connectors.
    Some more random shots!
    I hope that you are going to like the "different approach" I used on this mod and the artistic touch.
    Through my mods I ve shown that I can go in any direction I want, factory style or artistic but I prefer to be and create something different instead of the usual "one way" styles.
    Thanks for your time guys and I really appreciate your feedback and support.
