Scratch Build – In Progress Project : Sors salutis -by AnG3L(15 April 2011 - Video is UP)
Discussion in 'Project Logs' started by AnG3L, 10 Dec 2010.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    hmm excited..... yes I think so :D
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Very nice. Love the curvy design. :thumb:
    And great job with the polishing!
  3. Attila
    Attila still thinking....
    22 Feb 2008
    Are you serious?
    The man lives and works in one room. Although I'm guessing, I'd say he goes without a
    lot to pay for the laser cutting and materials. Dedication and perseverance is what he has
    tons of and you don't get those by wishing..
    Great work AnG3L, I'm always watching and can't get enough of your unbounded enthusiasm.:thumb:
  4. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks mate!
    Thank you my friend! Nice work too! :p :)
    My islander bro long time no see!! Where have you been?
    Thanks for your comment man, about my resources well the only thing I am lucky is
    that I have a good friend with CNC, the rest is saving money and patience!! :)
    I enjoyed your comment man lol smoke on even we have to quit one day lol ;)
    I will send you a keyboard cover next time :) :thumb:
    Thanks G! :)
    Thank you my friend! :) Its more dulling than polish ;)
    Thanks brother ;) Yeah you right, my tools sucks but I have access on CNC machine ( cheaper than others) and my only weapon is passion and dedication! Well I try to do my best with my pension (450 Euro...) and my consistence! :D
  5. perplekks45
    9 May 2004
    True... let's just say it was early, shall we? ;)
  6. AnG3L
    19 Mar 2009
    LoL okz then! ;)
  7. matt...
    matt... Slacker
    18 Nov 2009
    That is looking awesome mate- but I have to ask: are you planning to use it as the sail for a boat?
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    good work so far. :) just keep yor pace and quality work, and this will be awesome. Man I had this passion to make CAGE, and now I hardly make time for it..
  9. DeadP1xels
    DeadP1xels Music Enthusiast
    30 Nov 2009
    Im seeing some intresting shapes! a sure thing of an AnG3L mod :)
    Im like the way this one is going you seem to be able to work with any material... i just don't get it are you some sort of modding android?
    I can't imagine for a second how this was is going to turn out if its anything like the standard you have set in the past then its sure to be a great read (i still have'nt picked my jaw of the floor from future shlock)
    Keep it up mate!
  10. AnG3L
    19 Mar 2009
    Thanks mate! Nice idea! ;) :p
    Thanks dawg I ll do!!! :) Wish you more free time!! :)
    I A M A M O D D I N G A N D R O I D! ;)
    Your comments buddy is always a pleasure to read!
    As you probably might noticed I suck at 3d designing so my mods are always a surprise! :)
    Thanks mate! :thumb:
  11. KidMod-Southpaw
    28 Sep 2010
    You see that helix set your using? I have the same one.
  12. AnG3L
    19 Mar 2009
    Nice! :) I have them 18 years now!!
  13. phinix
    phinix RIP Waynio...
    28 Apr 2006
    OK! I was busy couple of days and when came back I saw another amazing project by AnG3L.
    Dude, this is awesome! How do you find time to do this all?! All those curvy shapes must have been a pain to design and cut, not even mentioning finishing it!
    Mod on! I'm watching:)
    Oh, amazing "modding suit" you have there! Sweet!:)
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'd have thought laser cut would leave the edge perfect, nice job on perfecting the edges :thumb:.
    I really should invest in some basic marking tools like a compass so I don't have to search around for the perfect circle object :lol::duh:.
    Just looked at your side panels & they are quite similar to the ones I'm going to make lol, we'll have slightly matching panels lol :D :thumb:.
  15. AnG3L
    19 Mar 2009
    Thanks mate, well I find time cause here and 4 years after a series of accidents I cant work full time so I have time for modding :) The suit was a must after I ruined half my clothes lol ;) Welcome aboard to our journey bro! :)
    This is not a side panel this is the back piece ;) I am working on the side panels right now! :) Update soon! :thumb:
  16. AnG3L
    19 Mar 2009
    Here we go with the third update.
    My attempt on the side panel failed completely as the flexible wood part proven to be not so durable even I was going to add a second layer on it. And because of that I am changing my plans to acrylic pieces plus the wood cylinders.
    Here you will see the progress.
    First I finished sanding the main 2 side panel holders.
    Then I reinforced them with some isopon which was also used to cover some minor imperfections.
    Sanding again!
    Here I mark the pieces of flexible 1mm pine wood.
    Preparing some epoxy glue.
    I attached the piece with some "temporary screws".
    It might seems nice but my experience says that its better to build something durable instead of nice looking and very fragile.
    Here I dulled the 2 remaining clear acrylic pieces. 2 and a half hours to get that perfect look on the edges!!!
    To open the side panels I am going to use an aluminium tube 1cm which is going to be held in place with 2 solid acrylic tubes of 0.9cm. I had to file down the 2 parts so they wont be tight, to be able to insert and remove the aluminium tube in order to remove the side panel.
    Here you can see them attached on the case parts and also on the removable parts too.
    So as you have seen I aint a guitar maker lol to be able to bend wood like a pro but that wont stop me from searching alternative ways to achieve perfection in what I do.
    Thanks for reading my worklog guys, till next time, peace!!
  17. Raceface
    Raceface RMC Customs
    16 Dec 2010
    Wow :eeek:
    Look´s very nice....
    More, more, more :thumb:
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    It's brilliant how you manage to take pictures even during time sesitive work bits like adhesive, something I don't seem to always do but know I should, I only sometimes get action pics :), with project logging like this you could release a modding guide book mate :thumb:.
    Nice progress too AnG3L :thumb:.
  19. The boy 4rm oz
    10 Apr 2008
    Really nice progress there Alex, can't wait for more of this one :D.
  20. AnG3L
    19 Mar 2009
    Thanks man, well its aint easy but I usually take the harder shots instead of the easy ones lol, I am a backward person ;P
    Thanks J, its going to take a while as I have a lot of problems now, broken pieces and a broken laser machine....
