Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. Rsx
    Rsx What's a Dremel?
    3 Jan 2005
    Looks very cool :thumb: I like aerographics
  2. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Looks sweet, i prefer it without the fogging, as you say less is more
    it looks better in smaller quantities
    those skulls look sweet man, keep it up
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Clear Coat
    With the end of the long holiday weekend drawing near, I wanted to get some clear coat on the case skins to protect the paint.
    This was the first time I used the PPG speed clear..It's nice stuff.
    Some random pictures:
    I shot a heavy coat to allow myself to wet sand without worry of "messing up" the graphics layer which is H20 based paint.
    So what remains is two more coats of clear with wet sanding in between.
    Then rubbing (glaze) compound and wax. I will post a few more pictures when the skins are finished and the case is put back together..
    until then::
  4. [ShoNuff]
    [ShoNuff] What's a Dremel?
    10 Sep 2004
    The black and neon green go well together. I like the effect along the edges of the window. Nice, very nice!
  5. -Erik-
    -Erik- Guest
    Damn I love it! Now with the clear coat it looks really amazing.
  6. grumblemarc
    grumblemarc What's a Dremel?
    12 Dec 2004
    Fine work. Although I had in my mind that there would be way more skulss than what you have. Probably because of the images of the stncils being tested and skulls being everywhere. Don't know why but I had envisioned a mound of skulls.
  7. modsquad
    27 Feb 2004
    Thanks guys.
    I had originally planned on lots-o-skulls, but decided to tone it down a little.
    It this point the finish is OK. It needs more wet sanding and another coat of clear..then wet sand again..then rub-out with glazing compound and finally, wax. So, lots of work to go...
  8. -Erik-
    -Erik- Guest
    Heard someone say: Less is more and that is surely the right way to discribe the paintjob.
  9. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    wow... it looks as if it's actually glowing..>!
  10. Firehed
    15 Feb 2004
    Great work (of course)
    Did you get that bit about slapping a skull on the aquadrive I mentioned a bit back? I think it would fit right in, especially as it's now black (btw, are those a fairly quick paint job if you're looking for a non-glossy look?)
  11. modsquad
    27 Feb 2004
    Yes, but the aquaDrive micro will hang-off the bottom of a 250GB hard drive. It will not be seen..Back in Black (ac/dc)..
    Yes, the inspection plate is not bolted down..
    I have only shot two brands of paint with my airbrush:
    House of Kolor
    AutoAir
    Both of which are two stage (pigment--clearcoat)apps..
    Without the clear coat the paint no durability..The clear coat is the outer-shell... A glossy case picture:
    You can buy a can of Krylon (which is pigment+clearcoat) and be done...BUT, it's not quite the same.
    So, to answer your question:
    "fairly quick" means "fairly good"...
  12. Firehed
    15 Feb 2004
    Oh how I'd love three or four of those for FrozenFire...but alas my hard drives don't run hot enough to justify that, especially with my current level o' cash. But great paint work anyways :)
  13. modsquad
    27 Feb 2004
    The aquadrive micro is a nice little HD cooler. I personally prefer the look of the standard aquadrive, but if someone needs to mount there drives in an 3.5" bay they are the way to go..
    I also noticed this projects rating has dropped to 4-stars. After the time I put into this paint job I have to say it is disappointing..I will have to try harder.. :thumb:
  14. Firehed
    15 Feb 2004
    I just "fived-it" for you, as it definately is five-star matierial. I didn't realize people acutally voted... ever.
    You wouldn't mind telling me how thick the Micro is, would ya? I've gotta see if there's a chance to put them between drives in the Lian Li drive rack without absolute modding mayhem (or removing hard drives... but chances are I'll be down to three when all is said and done so I'd have enough room then!)
  15. HellRazor
    HellRazor What's a Dremel?
    26 Jun 2005
    wo0t, looks like my 5 star upped it back to 5 star status!
    This is amazing.
    So another question about airbrushing, as I just bought one today, I'm sure the one you use is a nice unit, and prolly MUCH better (especially since mine can run on CO2...and was only $20), but I suppose my question is, does the quality of the tool make all the differnce in this as well, or is is more quality of the paint used. I doubt I'll ever be doing things like this with it, as anything detailed like this, but I figured for $20 it was worth it to be able to get a good paint job. Any Suggestions on paint, place to read how to do things, any advice in general would be nice!
  16. modsquad
    27 Feb 2004
    The micro is 18mm thick at it's highest point..
  17. modsquad
    27 Feb 2004
    This is a good site:
    Airbrush and it has links to many more..
  18. HellRazor
    26 Jun 2005
    Thanks, I'll have to check it out!
  19. Mondak
    Mondak What's a Dremel?
    27 Dec 2003
    Very talented! Great work on everything so far.
  20. DR_K13
    DR_K13 What's a Dremel?
    5 Jul 2004
    I got it back up to 5 stars for ya.
