Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. Firehed
    15 Feb 2004
    Totally agreed, I'm in a photography class right now. Can't say I've been a photo-buff since I was eight, but I'm definately having more fun with it recently. Maybe I'll get some scans of my prints up if we ever make any (B&W film SLR work)
    Agreed on the pressure thing. I just don't see how the decerase in pressure (by boring-out the intake hole) would change the calibration. It WOULD definately change the flow, but it seems to me that 1RPM in the meter would still equal x l/m. Must be changing how the water actually hits the impeller, rather than the actual pressure. You're right, as long as it's not zero, it's fine :)
    http://www.thinkgeek.com/tshirts/science/60f5/
    Just for the record.
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    COOL link..
    An SLR w/a 35mm lens is the minds EYE.. B&W photography can be lots of fun..Making use of light and shadow (the same can be said for b&w film)..A picture of "anything" can look great if you know what your doing..Photography is a very cool hobby.. ENjoY
    http://www.fredmiranda.com/
  3. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    I posted some of my modding activities in my FF thread with telescopes. :lol:
    The problem with the flowmeter is that when you open the hole the pressure drops and the RPM drops as well. Those flowmeters are designed to be used to meter liquids in vending machines (like coffee) thus they need small sizes. The reason that they say to open up the inlet port and then switch to the outlet port for your inflow is so that you still have a precision hole to base your flow RPM on. You can drill both sides, but then you have to do some exhaustive testing to get the flow parameters right.
  4. modsquad
    27 Feb 2004
    I just checked out your telescope_mod :thumb: Looking good as is your project.
    With an unmodified AC flow meter in my other machine (and prior to my pump impeller mod) I was getting 0.9 l/m..
    With this one I would expect something like 0.3-0.4 l/m (without playing with different pulse-rates) for the reason you stated.
    I understand that number will not be correct, but for me that is not important. In my mind a flow meter is a "early warning system"..If I see the flow rate drop from 0.4 l/m to 0.2 l/m, I know something is wrong and there is a restriction somewhere in the loop..
    You are 100% correct if your intent is to actually measure the flow rate of the H20 flowing through your loop the procedure you described above is the way to go (with a pulse-rate of 256).That being said you would still have a restrictive flow meter..I HATE to say it but the Innovatek flow meter is far better than Aqua-Computer's.. :waah:
    Have you noticed a change in flow rate with temperature? I have (a slight one)..with a reservoir H20 temp of 26.9C and above I get a 0.1 l/m increase in flow..I find that interesting...
    Now back to beer & HL2:
  5. ebola_one
    ebola_one What's a Dremel?
    22 Sep 2004
    Ahhh Ravenholm... I hated that place. :(
    So dark, so many things wanting to eat my face.
    I had so little ammo too :(
    Looking forward to the next update too :)
  6. Firehed
    15 Feb 2004
    Yeah, the grav gun and circular saw blades littering the ground help a lot. Didn't like RH but in all fairness it's probably one of the best designed levels I've ever played. So many irritating tricky things you have to do to get from A to B.
    I need to start up a fresh round. That game is just so fun. I've probably played through it six times and it's still not getting old.
  7. modsquad
    27 Feb 2004
    H20 Blocks & More Paint:
    I finally shot the clear coat on the Aqua-Computer HD cooler, the ATI block cover and the FMJ for AC's AquaStream Pump:
    The parts came out great, super-glossy..PPG clearcoat is good stuff..
    The AC 120mm grill and my mod-PSU plate..Well..
    The green looks to be a good color-match, but I seems..well bland.
    The two parts will face a wall and perhaps never see the light of day...But, GOD-is in the DETAILs..I have an idea.. :idea:
    First: lets get the AC blocks back together:
    I have not seen an exploded view of an AC Aquagrati X800/850 block..
    A close-up:
    I had a "bear" of a time getting the units O-ring back in place (honestly, I bet I spent .5Hour getting the O-ring to seat)..
    The HD cooler was EZ: only pictures:
    Back to those bland-green parts:
    I used another "old-school" (1950's) paint method on the Aqua-Computer 120mm grill:
    Fish Scales:
    after 50 years it still works: PrettyCool..
    I need to drill four holes in the PSU bracket (to custom-mount the Hiper PSU) before I paint it..I hate drilling stainless-steel..
    That "scale" pattern is a 4-step process, I will post a "how-to" soon.. Last picture:
  8. Firehed
    15 Feb 2004
    The scale pattern is very cool, a nice touch where skulls wouldn't seem quite right.
    Yes those O-rings are a bear to get back in place... I had similar trouble with my 6800 block. I found if you fill up the channel it sits in with some water it tends to stick in place much better.
  9. Top Nurse
    31 Mar 2005
    Glad to see something other than skulls! Skulls are nice, but not my thing. Now those grills are stupendous. :jawdrop:
    :idea:
    The key to getting the o-rings to stay where you want them is to use glycerin to hold them in during assembly. IIRC that is what AC uses during initial assembly.
  10. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    That grill looks awesome, a bit like the skin of a snake.
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Agreed. And it seems a lot better as it isn't that bright anymore.
  12. frodo
    frodo What's a Dremel?
    1 Nov 2003
    wow, those grills pwn!
    i like the fact you didnt go with skulls, as on the grill it wouldnt look right, because there isnt enough physical space to do it!
    i love the aquagrafix block now, just looks soooo good :) a 10000% improvement over the bland look.
    the hdd block looks pwnish, now paint the hdd *JOKING!*
  13. modsquad
    27 Feb 2004
    @Firehed and TN:
    Thanks for the O-ring install tips, I hope other AquaPhile's will take note..Glycerin, I wondered what that "greasy-junk" was..I purchased a Aquagra FX6800 block that was covered in the stuff (I felt the need to wash my hands after unwrapping the unit)..
    @Franklin:
    Snake skin or fish scales. Thats the Look.. :D I like it and plan on doing both the Aqua-Computer Aquaero VFD & AquaStream's face plates with the same:
    Infact all the 5.25" front panel inserts will get the "fish-scale"..I do not have them at my SlaughterHouse, so that will have to wait..
    Today, I found a very good candidate for the HiperPSU install-mod (better than what I was going to use).
    I think it's from a LL case, but I am not sure (it was in the parts graveyard).
    Needs a Dremel-cut :dremel: and the two centered holes will be drilled out for 5mm green (back-firing) LEDS :eeek: ..
    @Frodo:
    I am glad you like the H20 block's..So do I..I need to box them up so the owner can see them in person and not just look at pictures..It has taken me months to finish them..
    Update today PM (hope)...
    PS: I love my new Canon L-series glass, notice the contrast between the Alu-part's sanding marks and pebble-grain on the book in picute #1, good-stuff..sharp is a tack..(63mm ISO100 f/2.8)..Even @ Bit-tech's 650x433
  14. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Wow, this all looks incredible! Love the HDD blocks and the GFX cooler :)
  15. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    Wow, really like the HDD blocks and your vid cooler
  16. modsquad
    27 Feb 2004
    I hate stainless steel:
    The I hate stainless steel update:
    Sunday PM..
  17. modsquad
    27 Feb 2004
    PSU back plate
    The hiper PSU
    In order to have clearance for the top mount resevoir, I need to have the back-side of the PSU extend past the back of the case..This will involve cutting-out the stock mounting area of the case, making a new PSU mounting plate and bolting it to the case..
    I had originally planned on using this modified AC PSU plate:
    But after about five minutes of drilling (or trying to drill) through that German stainless steel I felt the need to look for other options..I guess I need a drill-press to work with that stuff. As luck would have it, I came across this:
    Nice soft Aluminum, I think this thing is from a LL case.
    I few minutes with the Dremel and it's a done-deal
    I also used a wire-brush (Dremel fitting) to start the sanding process on the plate.
    The cut edge needs a bit of file-action to clean it up. It should work out well (at least I hope it's tuff when you don't have the case or PSU to check-it).
    I also drilled out those two small holes on the center of the plate and added 3mm chrome LED clips:
    The clips come with those red LED's..They will get swapped-out for green ones.
    Next will be paint, more of than fish scale/snakeskin look..
    Until then..
  18. Firehed
    15 Feb 2004
    Cool idea there, glad to see stuff being reused. Looks like the backplate from a v2000. Anyways, what are the LEDs going to? And why red, with all that green?
  19. Top Nurse
    31 Mar 2005
    Me thinks you need a Multiswitch to control all those LED's you got in that case. :D If you want to drill that stainless you need a drill press, cutting oil, and fairly slow speeds with a high feed pressure. Helps if you use cobalt drills as well.
    BTW, if you want a really different look on the PSU plate you can take a standard pencil with an eraser and chuck it up in a drill press. Then dip the eraser in a fine grit paste and apply the eraser to the metal. Keep moving the metal so that the eraser size covers about 1/3 of the previous swilrl you create. Gives a very pleasing swirl pattern of the metal and is often seen on fancy weapons. Probably have an interesting effect with the green paint over it.
  20. frodo
    1 Nov 2003
    would give it a 3rd dimension of awesomeness!
