Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. bLu3
    bLu3 What's a Dremel?
    25 Sep 2004
    nice work also over here. i love that green uv plexi. i first thought of using such color for my v2000b also... but then i got stuck to the blue/white/chrome theme :) keep on that clean/exact work
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Thanks bLu3, your project looks great as well..
  3. modsquad
    27 Feb 2004
    Small Update
    I had plans to install the Innovatek reservoir this weekend,but that is not going to happen. After looking at the 1/4" acrylic I am going to use to mount the res. I came to the conclusion that I will need to use the stock aluminum mounting plate. With the acrylic on top of the reservoir it would be very difficult to remove the reservoir's fill plate so adding/changing H20 would be a major undertaking.. So I started polishing the mounting plate..
    Not finished, but getting there (slow process)..
    I also want to see how the Innovatek LCD would screen from blue/white to green UV.
    That will work! Until next time....
  4. modsquad
    27 Feb 2004
    I just finished polishing the Innovatek reservoir mounting plate. It came out nice.
  5. TheDon
    TheDon What's a Dremel?
    21 Oct 2003
    Nice polish job there. I like it alot.
  6. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    ill get my sunglasses
    the glow of the uv green plexi combined with the chrome may blind you
    :hip: ok i'm ready for your next update
  7. Pistol
    Pistol Guest
    That settles it, I'm polishing all my metal in the future. How long did that take?
  8. modsquad
    27 Feb 2004
    A few hours. My problem is the only drill I have is cordless, and I had to stop and recharge the batteries a few times. You can only polish soft metals (aluminum,copper,brass) steel needs to be chrome plated.. Good luck.. I am thinking about polishing the reservoir as well.. we will see..
  9. Firehed
    15 Feb 2004
    I did that except in a 3/8" system, still pretty high flow though, and flow rates didn't drop at all as far as I can tell (going by the flow in the res). Different block but still adding in a tiny area to squeeze lots of h2o through.
    Excellent work as always :) That polished plate is just :eeek:
  10. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    damm thats stupid.. i have a green innovatek lcd :) and i want a blue one :)
  11. modsquad
    27 Feb 2004
    The Aqua-Computer is a very nice GPU block. Honestly thinking about switching and using one in my other project...
  12. modsquad
    27 Feb 2004
    I just wanted to post and say I am moving forward on this project... It is not EZ .Working on this mod from a remote location, as well as project BN and my real-world job. The only part I have is the front panel..
    The "super-small" power-on/HD LED's will get drilled out for 3mm green leds. The SivlerStone case only draws air for it's 120mm intake fan from the bottom of the case. I am going to add (drill-out) four 9/16" holes on either side of the front panel to draw air from both sides and the bottom. I have all the ingredients for the top mount reservoir. I only need the time to install it............Stay tuned........
  13. koola
    koola Minimodder
    11 Jul 2004
    Very nice mod!
    That plexi is so nice, it's gonna look so good under uv :D
    Keep up the high standard of work mate!
  14. modsquad
    27 Feb 2004
    Progress
    I just got a Pioneer DVR-108 optical drive for the project.. Let's skin_it..
    Pioneer did a good job of affixing there label (I had to sand it off), but the unit is ready for CHROME PLATING.......The Innovatek Reservoir will get installed Saturday...For_Sure..
  15. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Nice work, my compliments on the front panel :thumb:
  16. P3rRRrY
    P3rRRrY What's a Dremel?
    24 Oct 2004
    Nice work m8 :thumb:
  17. bLu3
    25 Sep 2004
    good polishing job :thumb:
  18. modsquad
    27 Feb 2004
    Big update soon....
    Big update later today guys. I am uploading the pictures now (23 of them). The Innovatek reservoir is installed and it came out nice.....Preview
  19. Lord Kordir
    Lord Kordir What's a Dremel?
    5 Nov 2003
    subscribed! :rock:
  20. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Whens that happening, I am beging for an update
