Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. kempez
    kempez modding again!
    4 Aug 2005
    Whoa that's a lot of tubing :jawdrop:
    Looking forward to some sweet pics on this :thumb:
    modsquad your modding is top-class and I always enjoy drooling over the extreme details :)
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Slept long enough now MS! Get up! Time to update! :p
    I can't wait to see your tubing. And I like the idea with the PCI-E cables by scifi... give it a try.
  3. accro
    accro What's a Dremel?
    21 Aug 2005
    Clock is ticking.. we want that update!
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    the LOOP:
    The loop:
    First off "spring-up" the HD cooler
    then removed the Innovatek reservoir from the case skin and added the needed fittings.
    It will be necessary to mount the res. in a temporary-fashion in order to have access to the backside of the MB to finish wiring later.
    Ended up using a scrap piece of acrylic to serve as a support for the reservoir
    Then on to the tedious task of the loop:
    tight--
    very tight--
    Eight hours later:
    The springs on the CPU runs of Tygon give the tube a mind of there own. I want them to run together to mimic the look on the video block..Later..
    Lets add some H20:
    The good news, not a single leak..The bad, could not work a drain valve into the loop without it looking like crap..So, no drain valve. Would have liked to have one, but not the end of the world.
    As I said before, the Tygon runs in/out of the CPU did not want to sit the way I wanted them to:
    I think Billet Specialties should have a hose separator the size I need. For now,plastic tie: :hehe:
  5. [1N0V471V]
    [1N0V471V] What's a Dremel?
    27 Feb 2006
    Amazing...
  6. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    i think that a drain port where the pump power plug exits the case would be good... you could run the tube straight along the front edge to whever, or spring it and run it behind the pump...
    but wait! where would the pump's power come from?
    tie the pump power to the mains inlet on the PSU... *shifty eyes*
    [edit] im thinking of a fill port... not a drain valve... but why not use a fil port as a drain valve? it would look good where the power plug for the pump is... or vertically behing the pump where all the tubes run vertically...
  7. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Looks fricken amazing!
    But my only concern is that when you need to replace motherboard or something, its going to be very hard with the pump and all the other bits there?
    But man, WOW!
  8. Fahrenheit 541
    Fahrenheit 541 What's a Dremel?
    8 Aug 2004
    loop
    very clean and beautiful work there fella... I like what I see, keep pushing forward.. :thumb:
  9. customh
    customh conflagration.
    22 Oct 2005
    Great...Amazing...but the pink of the LPT port needs to be covered bad.
  10. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    It looks great.
    Say, is that one of those casio calculator watches? The ones I always thought were totally awesome?
    How much longer? Are we there yet? Are we there yet? are we there yet?
  11. scifi3018
    6 Feb 2005
    I agree 100% with this.. i didnt notice it until he pointed it out... either that or the alcohol made me notice this time around, but now that i oticed it, it does stick out a bit... perhaps some paint... or hell black tape...
  12. customh
    22 Oct 2005
    Green paint would be a nice touch but a hella pain in the ass to mask up.
    EDIT: I changed my mind, a silver/chrome/for the love of god something shiny!! cover. DO IT!!!
  13. modsquad
    27 Feb 2004
    You are 100% correct, I did not notice the forest because of the trees.. :hehe:
    You found it, now give me some options to fix it CH.........
    @ BoD: that is not my hand so I can't say...That session was done in the owners garage, the machine departed my SlaughterHouse to be finished at the owners abode..I was just the overseer and picture-shooter.. :hehe: I made him do the work.....
    BAD-NEWS guys..
    Yesterday, after finishing the loop..I hung-around for about an hour watching the pump-pump (and drinkin' beers)...no-problems..
    (10) hours later, there is a "moist-spot" under the radiator (this per the owner).. So, the loop has a Weep (mini-leak) in the vicinity of the radiator..
    I have been trying to trouble-shoot via email with him to pin-point the leak..
    Worst case scenario (and my guess) is that it is the radiator itself.. Those chrome hwlabs radiators are no longer in production... :eeek: I did mod-it (threaded rod through/around it's core) but I tested it with 30psi-air, and it was OK..
    SO- I am off to Google a 120mm Black Ice chrome.. :hehe:
    Will the madness never-end........... :wallbash: Will I ever finish this project !!
    I am starting to wonder myself....what else can go-wrong, how many hoops must I jump-through...I think my next computer will be a Dell...... :hehe:
    MS
  14. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    to keep those hoses together, what about a small block of aluminium bar or thick plate (say 6mm or so) in a rectangle or something, drilled to fit the tygon, and sanded around the edges so it was like an oval with the tygon running through it? :thumb:
    wouldnt that also be a hell of a lot cheaper than getting something made from billet? :naughty:
  15. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You are refering to the noticably ugly Parrallel port? Other wise the only thing is that GFX
    wire I say run it alogn the side of the Card and to the MB power line. And you could bend some plexi to make your own green tube holders or black. just make a S. Or you could sleeve it. that would be interesting sleeved
  16. hydro_electric_655
    13 Jul 2006
    I would test the Rad the same way again under water. Check is it sthe rad or a jushed O-ring or something. And even tho it is frusterating. You are having fun need I remind you.
  17. scifi3018
    6 Feb 2005
    hehe, sure doesnt seem like it :)
    i think hes doing it for his clientell :)
    but... with the h20 problems sorted... he can look at the loop drain, and the parralle port :)
  18. modsquad
    27 Feb 2004
    YES, fun.. :miffed: let the good times-roll !! :p
    as for the loop, the the BS seperator is on its way.. The loop may not hold-water but it will look good.. :D
    frustration-incorporation...
  19. Zds
    Zds What's a Dremel?
    3 Nov 2005
    Those springs make for a very neat effect. A big plus on the looks department (I guess they hold the kinking down, too..).
  20. Firehed
    15 Feb 2004
    I'm with CH - that pink is evil!
    Looks excellent though, it's some mighty impressive work. I've set up watercooling in a LL PC-6077 once (same size as the PC60 but different internals) and it was quite painful, so much respect for getting that all looking so great in a fairly small case!
