Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Wow, sorry if I made you angry somehow. Or i'm looking wrong at your caps lock use. Seemed to me like you were made of money with the costs of the etching etc. :sigh: (On both projects)
    I never trust factory reviews and if you look at aerocool.us you'll see there are no db rates given.Only kinda of manipulated reviews. Nor high nor low db levels shown. Only 'Quiet'. Recon ,RPM up to 2500rpm ,Air Flow 27.6cfm ,Noise Level 24.6dba or higher on it. Atleast if they are fans of Aerocool themselves.
    The same with the Ultra Products.
    Later I found a review claiming a db of over 55!!! from 1" distance ofcourse.
    Back to the Aerocool, it's a nice PSU. 3Fans though already say it get's hot at high usage. I really, really, really recommend you to do this:
    http://zfz.com/projects.asp?request=liquidenermax550w&page=2
    No it isn't a excuse that you don't want to put the time effort and costs in it.
    Wake up the child in you and show me what you can accomplish besides chroming everything so much. :thumb:
    And don't think i'm flaming fool for saying this stuff. I really like your mod. I don't post alot and mostly only where I see a real potential. You rock! :cooldude: keep it going!
  2. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    I'd say so. The etching isn't much, IIRC they charge/charged something like $20USD for the etching.
    On the PSU side of things I only use Forton/Sparkle/Enermax after I had an Antec blow out on me killing an HD.
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    No..I am not angry at all, I was just playing.... 55db is pretty loud. I actually need a length measurement for whatever PSU I end up with. The case is compact and I may have a problem with a long PSU hitting the reservoir. As for "being made of money" I wish. This case is not mine, and while I have a free hand in building it..I am not paying for it.
  4. Rh1n0x
    15 Nov 2004
    Doesn't matter I'm still in envy. :naughty:
  5. modsquad
    27 Feb 2004
    Large Update
    I am photoshopping/uploading pictures for a long over-due Large Update..
    Soon.
  6. Tricky
    Tricky What's a Dremel?
    29 Jan 2005
    Silverstone Cases
    Mate, will be following with interest...
    Yup, I got one too. Case arrived the other day, I just need to learn to solder properly and do some peliminary testing / fabricating before I post a project log. Oh, and from the look of the above image learning to take a 'proper' photo might not be a bad idea either......
    As always, I'm enjoying the chrome and water cooling. Bring it on!
    Pete
  7. Tricky
    29 Jan 2005
    Tisn't very tall or deep, but it is 44 1/2 feet wide. :) I can hide undergraduates in there and everything!
    Pete
    EDIT: UK supply of UV acrylic sheets (various colours) can be found at www.glowshop.com
  8. modsquad
    27 Feb 2004
    MAN, you have me pegged, Chrome and H20 cooled is my MO.. Still working.
    Update soon.. :thumb:
  9. modsquad
    27 Feb 2004
    2/14/05 Update
    The power supply for the project is the AeroCool black/silver line (550W).
    No major mods on the unit. I cable sleeved/heatshrinked the wiring black on black and changed the chrome fan grills for black powder coated ones.
    An Aqua-Computer PSU/Radiator grill was dremeled for it's top half (which will be chrome plated).
    Moving on (or should I say back) to the top of the case and it's acrylic reservoir mount. I cut the hole needed in the green acrylic window and drilled the four mounting bolt holes for the units top plate.
    I also ran across these.
    They are carbon fiber isolation feet for high-end stereo equipment made by
    Black Diamond Racing. I only needed to inlarge the case's stock feet mounting holes for the new ones.
    They will work out well in this application, I only need to get a few bolts to install them. That will do it for today. I have some more work to show you, Aqua-Computer radiator mounted and the interior of the case being painted satin black. Soon..
  10. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    I like the UV Green and Black, I'm also using that same color scheem for my case when i start it
  11. Jipa
    5 Feb 2004
    I like those feets! Usually there are only sharp feets, but those seem to be nicer. Sharps make nasty marks to table or floor...
  12. modsquad
    27 Feb 2004
    They are nice, but not cheap (real carbon fiber) $15US each!!
    I will get you guys the rest of the 2/14/05 update tomorrow.
  13. crimandevil
    30 Jun 2004
    :eeek: May I ask were you got them?
  14. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    umm they dont look like carbon fiber to me, unless its unidirectional ( non weave)
  15. modsquad
    27 Feb 2004
    Local stereo shop..
  16. modsquad
    27 Feb 2004
    You read/looked at this update and your reaction is "they don't look like CF to me"? Nothing else. Love/hate the look of the BOX?
    I am no CB expert..All of Black Diamond Racing's stuff is carbon fiber. I can say they look like plastic (no weave/pattern), but feel like "something else" very heavy. There density is not equal to that of the size/shape of plastic.. It seems Black Diamond Racing does not have a website, but here is some information.
    http://www.tricell-ent.com/BDR.htm
  17. modsquad
    27 Feb 2004
    Update 2/14/05 PartII
    I had originally planned on using a Innovaek 120mm radiator for this project, but went with an the Aqua-Computer AirPlex Evo120.. Copper VS Aluminum and my love for all-things Aqua-Computer..
    Radiator to sidepanel clearance is "like" mm
    Paint next....Part III
  18. Rh1n0x
    15 Nov 2004
    that's a very close call :D
    lucky you..
  19. Firehed
    15 Feb 2004
    Love it :) Isn't the UV green tubing in a UV green window a bit... well... redundant? Still, good rad choice :thumb:
  20. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Looks really good, the top window looks awesome, hopefully it performs aswell as it looks
    close call with the rad there!
    was that planned?
    or just pure luck
