Project Spherebox(...Big pics...)
Discussion in 'Project Logs' started by Isuo, 29 Dec 2004.
  1. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Ok, I've been here in the forums a few months now I think and never done any real modding nor overclocking.
    So I decided to take the first step on the road where there's no return.
    What else; my current pc is a:
    AMD Athlon 1.410 GHz, with
    GF2 MX400,
    512 SDRAM and
    60 Gb HDD.
    But I will get better equipment the day after tomorrow when I'm going to assembly the pc in the local pc shop(My father didn't let me do that at home).
    That was the obligatory information, to the project.
    I laid first my eyes to the eggchairs known from the sims, but because the chairs are desing stuff, DESIGNED BY A FINN!, they are relatively expensive(cheapest one was 800€/$1,086) I decided to make on myself. And the sketches are here:
    Oi, one thing. Sorry for the big pics, will make the next ones smaller.
    First some poormans webcam shots:
    The case should look like something similar to this:
    The drawn by hand:
    And the same by fireworks:
    Then how to make it look like a sphere inside:
    And same with fireworks:
    The ventilation:
    And how the air will hopefully move:
    Then front:
    Plus side pictures:
    This should be everything for now. I will update this when I have time and money to buy stuff(half of my money went to the new pc parts)
    Materials I'll be using: Wood, wood and plywood.
    EDIT: About the cooling if anyone is interested. I'm plan(n)ing to use 2x120mm Titan coolers as intake and take the air out with 170mm Papst cooler from http://www.izzotek.com/ventilateurs.htm
  2. Isuo
    13 Oct 2004
    This is no good. About 250 views and no comments.
  3. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    Mabey you would get more post in modding :eyebrow: . People usualy dont post in project logs until there is some work done to comment on. Dont sweat it tho, project looks like it will be nice.
    JEEVES
  4. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    I'd just tell the mods to move this project to another section, since there's not ongoing projectism in this log... But hey, show us something good, and I'll post some serious comment :)
  5. SoylentGreen
    SoylentGreen What's a Dremel?
    27 Jun 2004
    its really that i couldn't understand what your project is from the drawings
  6. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    I came, I saw, I posted...
    Then I wondered why we are drawing stick figures...
    *Me shruggs... and runs away*
  7. Isuo
    13 Oct 2004
    I know, the drawings are stick figures cause I can't do the 3d models and my art nulber was 7. So anyways, the pictures should look like a box from outside, but there should be a 'ball' inside when it's fiinished. Anyways, I'll be going to assemble the components now and will post pics of them wjen I get back. And if I manage to get some spare time from the gaming with new components, I'll probably go and buy the wood stuff needed for the cade(the first stick figures).
  8. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Thank you! The name of your project gave me a great idea for a project of my own
