Project: Square, practical and watercooled (35% done)
Discussion in 'Project Logs' started by ZeroHerO, 21 Apr 2005.
  1. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looking good:)
    Lovely waterblocks.
  2. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    if it's ain't broke you finally fixed it
  3. ZeroHerO
    ZeroHerO What's a Dremel?
    17 Dec 2002
    a little progress
    Hi ppl,
    I found a window of time where I could finish the Chipset block, and mount the PSU.
    I tried a newshape for the Chip Block, I tried like the CPU block, to keep an easy flow, a hight Cobber/watercontackt surface, and a small block.
    And finally i cut a hole for the PSU, and made abracket for it to rest on.
    A rearview look
    And I have decidet to do another sanding and polish og the CPU block.
    To come next week, Final plating and GFX waterblock work.
    ZeroHerO
  4. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    Super nice mounting of the chipset .. well done me like :)
  5. ZeroHerO
    17 Dec 2002
    Cpu block repolished
    I found another ½ hour today, and decidet to repolish the CPU block (the damaged block) and I managed to get a decent finish on it, so I might just keep it anyway.
    NOTE: The fitting are not the ones to be used, they are just there so the clear coat won´t get into the blocks :cooldude:
    The cpu and Chip block, I think i´m in the clear, with the finish :thumb:
    thats it fortoday.
    ZeroHerO
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Very nice and clean work.
    One question: What will this rig be used for? I mean... 8 SATA drives?! GeForce6600GT ?! :eyebrow: Gaming? Storage? Download? Movies?
  7. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Why are you using a nickle plated barb and a nylon barb on the CPU block? i love the chipset block!
    edit: RE-read it, and sorry :D
    keep up the awesome work
  8. ZeroHerO
    17 Dec 2002
    Frodo, the fittings are just there so the ClearCoat won´t get into the block:)
    aon`aTv.gsus666, I will run my 4 80Gb sata disks and one big RAID0, to get fastload times, the last 4 160Gb disks will be run as 2 times Raid1 giving me 2 times 160Gb storage for a lot of digital photos and videoclips. So yes it´s for gaming and storage
    Sincerely ZeroHerO
  9. ZeroHerO
    17 Dec 2002
    I testet the waterblocksfor leaks today, and I found one,small drops came out from the corner of the chipblock :eyebrow:
    So I sandet he clearcoatof and resolderd the block and did arepolish after that, when I testet the block again this times there was no leaks.
    So I mountet the fittings, and monted the block on the motherboard.
    And I have paintet the Eheim pump white, think I want to paint a red "DANGER - high presure" on it :hip:
    So now I just need to finish the new GFX-block, and the sides for the case itself.
    ZeoHerO
  10. ZeroHerO
    17 Dec 2002
    Hi again, I did a little more fidling today, and madethe first two holes to the cabletunnel.
    Cabletunnel ismaybe a big word, I have made a double buttomplate so i can hide the cables.
    But right now I can´t decide what color the case will be.
    1. I´m gonna give the case i White powdercoat.
    2. I´m gonna polish the aloyplates,(chromelookalike)
    please give me your thoughts on the color.
    sincerely ZeroHerO
  11. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    mat black like black lian li's
  12. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    i would say gonna give the case i White powdercoat.
  13. ZeroHerO
    17 Dec 2002
    Another small update, things are starting to take shape
    So I found a little time to mod again.
    I´m trying to mount the first four harddisks today, and if possible the radiator,pump and reservoir.
    But I´m eating Lunch right now, an uploaded the diskmount :)
    Should go well with the two 120 titan fans
    Hopefully the watersystem is mountet in a few hours
    ZeroHerO
  14. arkadur
    arkadur What's a Dremel?
    3 May 2005
    WOW!!
    very great work!
    i love the home made blocks!
  15. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    WHy are you using RAID 0 + 1?
    RAID 5 is just as fast, and gives you a storage efficency of something like 75%, with redundancy, you have the three disk minimum.
    With RAID 0+1 you get 160Gb with RAID 5 you would get 240 Gb.
  16. Firehed
    15 Feb 2004
    I think it's just two seperate raid1 arrays, and if I had to guess it's beause the controller doesn't support RAID5 (it's far less supported than 1 and 0, although becoming more popular)
    Nice work... that's a ton of storage! Better hope one of those 80GB drives doesn't go down though, or else you'll have some serious problems.
  17. ZeroHerO
    17 Dec 2002
    55# that would be ideal, but first of all, my raidkontrolers don´t support raid5. Second of all, i like the way, that 1 raid 0 and 2 raid 1, gives me flexibility. My plan is (4x 80Gb in raid0 for the OS and games etc., 2 times 2x160Gb in raid 1 for pictures, videoclips and my Ghostimage) My ghostimage in one with a clean installment and one complete with games and all :),for fast recovery.
    And I think 8 disks looks awsome :D .
    But thatnksfor you thoughs, I might look for a kontroler that supports raid5 at somepoint.
    Thx for the commenst ppl
    sincerely ZeroHerO the Battlefield series rules
  18. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    i think 2x raid 5 with 4 discs for each. Total 8 discs. the best configuration is 4 wd raptor for windows, programs and your favorit games. and 4 other for picture files and movies and other stuff.
  19. ZeroHerO
    17 Dec 2002
    So I got a few more hours of dremling done today, so now the diskmount,reservoir and radiator has been mountet. (temporary mounting screws, still not final)
    Motherboard mountet
    The front
    The rear
    HD, DVD and SPU mountet. Andthe front has it´s first raw polish.
    I have decided topolish the plates, andgo for the chromelook when I´m done building :dremel:
    ZeroHerO
  20. ZeroHerO
    17 Dec 2002
    temps, initial test runs
    I have booted up the system, installed BF2 and played it for a few hours to see what the temps would be. (Also to play this game, wich is very fun :naughty: )
    The room temperature was 34 degrees
    CPU full load 47~48 degrees C (fans on 3/4 power), iddle 44 degrees C
    MB full Load 41 degrees C (fans on 3/4 power), Iddle 39 degrees C
    GFX not measured.
    The temps is from asus Probe 2, and the room temp from a ordinary thermometer.
    new pics soon :)
    Cincerely ZeroHerO
